Lawnmower pushed down at 45° with friction
3 replies · 4K views · last reply
flawlessbrown
A gardener pushes down on the handle of a lawnmover, applying a force of 250N. The handle is inclined at an angle 45* to the horizontal. If the coefficient of the kinetic friction between the wheels of the lawnmower and the ground is 0.40, what is the acceleration of the 20-kg lawnmower?
Fnet=0=Fn+Fsin45-Fg
Fn=mg-FSin45
a=(Fx-Ff)/m
Fnet=ma
Ff=(UkFn) Uk=coefficient of friction miew? or meiu
Answer is 1.38m/s^2
Your first equation applies on the y direction, but you have a signage error. The weight acts down and so does the vertical component of the applied force. The normal force acts up ; solve for it. Also, be sure to identify the horizontal component of the applied force, Fx.
so are you saying my expression should be Fn= -mg+Fsin45 ?
You must be very careful with plus and minus signs, or else they will get the better of you. . Draw a free body diagram of the mower. The weight acts down on it, the vertical component of the applied force on the handle acts down on it, and the normal force of the ground acts up on it (normal contact forces are generally 'pushing' forces). Choose the up direction as positive and the down direction as negative. The algebraic sum of these three forces in the y direction must equal zero. Watch plus and minus signs, and solve for N.
