Learning 1D Ising Model With Nearest Site Interaction
  • Context: Graduate
  • Thread starter Thread starter KFC
    Ising model Model
The forum discussion centers on the learning process of the 1D and 2D Ising models, specifically focusing on the Hamiltonian and transition matrices. The Hamiltonian for the 1D Ising model is defined as H = -J∑_i S_iS_{i+1}, while the 2D case introduces complexity with H = -J∑_{i=1}^{2}∑_{j=1}^N S_{ij}S_{i, j+1} + S_{ij}S_{i+1,j}. The transition matrix for the 2D model is a 4x4 matrix due to the four nearest neighbors of each site. The discussion also references the exact solution by Onsager and suggests resources like the book by Baxter for further learning.
  • Understanding of the Ising model, specifically spin 1/2 systems.
  • Familiarity with Hamiltonian mechanics in statistical physics.
  • Knowledge of transition matrices and their application in statistical models.
  • Basic concepts of periodic boundary conditions in lattice models.
  • Study the exact solution of the 2D Ising model as presented by Onsager.
  • Learn about the transfer matrix technique and its application in statistical mechanics.
  • Explore the Bethe Ansatz and Yang-Baxter equation for integrable models.
  • Read Baxter's book on the Ising model and related techniques for deeper insights.
Researchers, physicists, and students interested in statistical mechanics, particularly those focusing on the Ising model and its applications in condensed matter physics.
KFC
I am learning the 1D ising model (spin 1/2), without external field and considering the nearest site interaction, the hamiltonian for 1D chain is simple
H = -J\sum_i S_iS_{i+1}
Since each spin can only take either +1 or -1, we can write the transition matrix as
<br /> T = <br /> \left(<br /> \begin{matrix}<br /> e^{K} &amp; e^{-K} \\<br /> e^{-K} &amp; e^{K}<br /> \end{matrix}<br /> \right)<br />
where K=\beta J
Now I try to learn 2D case, I read some book on it but seems quite complicated, so I started with the simplest case (no external field, only nearest interaction, rectangular lattics with only 2 rows and N columns and perodic boundary condition). The hamiltonian is
H = -J\sum_{i=1}^{2}\sum_{j=1}^N S_{ij}S_{i, j+1}
right?
What I am really consfuing is how to find the transition matrix? Now each site has four nearest neighbor (of course, to avoid double counting, we only need to count two one at a time, let's say we count the one next to and below the current site) and each spin can take 2 values, so what's the dimension of the transition matrix? and what does T_{ij} means?
Here is my idea. Since we have to sum over all possible sites, so consider the site (1, 1), and (2, 1) (i.e. the current site and the site below it), the energy is
-J\left[\left(S_{11}S_{12}+S_{11}S_{21}\right) + \left(S_{21}S_{22} + S_{21}S{11}\right)\right]
All other sites has the same case as this specific site (1, 1), and in this case, we only need to consider four spin S_{11}, S_{12}, S_{21}, S_{22}. Note that each of them can take two values so there are totally 16 possible values. The transition matrix would be 4x4, right?
Your Hamiltonian is incorrect- it's missing a term like S_ij S_i+1,j .The 2-D ising model is significantly more complicated than the 1-D. There's a brief treatment in Landau and Lifgarbagez, vol. 5 (pp 498-506) and Chaikin and Lubensky "Principles of condensed matter physics" has additional detail along with the O_n model.
Thanks. I will check
I checked it, now the Hamiltonian is modified as
H = -J\sum_{i=1}^{2}\sum_{j=1}^N S_{ij}S_{i, j+1} + S_{ij}S_{i+1,j}
So, the for site (i, j), the energy could take 16 possible values. For
S_{ij}, S_{i+1, j}, S_{i, j+1}, S_{i+1, j+1} \Longrightarrow E
++++: 4
+++-: 2
++-+: 2
++--: 0
+-++: 2
+-+-: 0
+--+:-2
+---: -2
-+++: 2
-+-+: 0
-+--: -2
--++: 0
--+-: -2
---+: -2
----: 4
So could I just use this values to setup the transition matrix?
The exact solution of the 2D Ising model was done by Onsager. See here for a brief outline: http://www.nyu.edu/classes/tuckerman/stat.mech/lectures/lecture_26/node2.html
Thanks. I read that before, but I found this quite confusing.
The above outline is about n x n lattices, now let's apply his result to 2 x n, we get the matrix element
<br /> T_{jk} = \exp\left[\beta J\left(\sigma_{1j}\sigma_{1k} + \sigma_{1j}\sigma_{2j} + \sigma_{2j}\sigma_{2k} + \sigma_{2j}\sigma_{1j}\right)\right]<br />
For the last term, we apply the periodic boundary condition.
My doubt is \sigma_{ij} is the eigenvalue and could be -1 or +1, so each terms in above expression couble be either +1 or -1, how come do we get a certain value for specific matrix element T_{jk} ?
Solvng the 2D Ising model is almost trivial by transforming it to a close packed dimer model. The dimer model can be solved using very simple combinatorial techiques, you don't need complicated transfer matrix techniques. See e.g. here:
http://arxiv.org/abs/cond-mat/0212363
Thank you very much. I will read that later.
I am learning this problem because there is one chapter about transfer matrix in my text and this method is useful in some other place. So I want to learn it by studying 2D ising model as an example.
Then you should read this book:
http://tpsrv.anu.edu.au/Members/baxter/book
You can download it free of charge. The transfer matrix technique that most textbooks explain for solving the Ising model is of no use for most other models. The Ising model is a so-called "free fermion model", the transfer matrix can then be diagonalized using a Bogoliubov transformation. This won't work for the vast class of integrable models.
So, if you want to learn about solving models, you should learn about the Bethe Ansatz, the Yang-Baxter equation etc. etc. This is explained in detail in the book by Baxter.
Using the 2D Ising model to learn about the Transfer matrix is probably not the best approach. First, the Transfer Matrices are somewhat obscure (although certainly doable), and second, it doesn't even get you half way there in solving the model (i.e. you still need perform some other steps as well - steps that are quite specific to the Ising model).
But just to throw in another book, I know that this one solves the Ising model using Transfer matrices:
https://www.amazon.com/dp/9810216424/?tag=pfamazon01-20
(Chapter 5.1)
ok. Thank you for all your help.
Is the Onsager Solution extendable to 3D ? is it do-able in principle ?
