Learning trigonometry from basics
13 replies · 3K views · last reply
awholenumber
i was trying to learn some trigonometry from some basics ...
after understanding terms like ,
f(x) = sin x , and
y = sin x ...
i was also getting sort of comfortable with the notations of functions ...
i was also wondering , where to improve from here ... ?
any good books , sites ? tutorials ... ?
They will all just state the notation to use and then use it - if you are "uncomfortable" with notation for functions then they won't help.
The foundation trig is just based on angles in the unit circle.
A unit circle is one that has a radius of 1 unit.
The size of an angle is the distance around the circumference of a unit circle that is inside the angle.
The trig functions are just the names of distances using this definition ...
For instance: the tangent line to the unit circle is any line that touches the circle at only one point.
If you draw a line through that point and the center of the circle, you can make an angle to that line by drawing any other line through the center of the circle.
The tangent of that angle is the length of the tangent line inside that angle.
There are similar definitions for sine and secant.
Once you have that down - you can do trig.
Other than that, just google for "introduction to trigonometry".
this was all very confusing for a very long time ... you know , the opposite / hypotenuse ... adjacent / hypotenuse ... all those things ...
looked so dull and uninteresting to me , until i found this picture online ...
Collage of a woman with long dark hair in the foreground, with a tan-and-green dinosaur scene of two-legged theropods in a forest on the top left and a snarling dinosaur head with open jaws on the right.
suddenly , the quadrants and the sine , cosine , opposite / hypotenuse ... adjacent / hypotenuse etc is a bit more interesting ...
Unit circle diagram titled Finding the Values of Trig Functions, with angles in degrees and radians and coordinates labeled at key points such as (1, 0), (0, 1), and (-1, 0).
i have few more important questions to ask ...
when does a function like ...f(x) = sin x
becomes like a repetitive cycle , and becomes like a wave like motion ?
Diagram of a unit circle with dashed outline and a point on the horizontal axis, beside a sine wave plotted against a horizontal axis, starting at zero and rising to a peak, falling through zero to a trough.
for example ...how to graph a sine function ?
http://www.dummies.com/how-to/content/how-to-graph-a-sine-function.html
Knowing how to graph trig functions allows you to measure the movement of objects that move back and forth or up and down in a regular interval, such as pendulums. Sine functions are perfect ways of expressing this type of movement, because their graphs are repetitive and they oscillate (like a wave)
f(x) = sin x
It repeats itself every 2-pi radians ...
This repetition occurs because 2-pi radians is one trip around the unit circle — called the period of the sine graph — and after that, you start to go around again. Usually, you're asked to draw the graph to show one period of the function, because in this period you capture all possible values for sine before it starts repeating over and over again. The graph of sine is called periodic because of this repeating pattern
i really need a better understanding of this part ...
is it really going to repeat itself for an infinite period ??
When I teach this, I get students to measure the sine and tangent lengths and plot the results on a graph.
You should probably do this.
Draw a unit circle: radius = 1.
Draw a line going through the center of the circle, passing through the sides ... right through: this is the "base line" for the angles.
Ignore your protractor: this is a distraction.
Draw a line starting from the center and passing through the side of the circle. This is the angle line.
The length around the circumference between the base line and the angle line is the size of the angle.
Notice there are two angles: these angles add up to half the circumference of the unit circle.
Call the smaller angle ##\theta##, then the bigger one is ##\pi - \theta## because the circumference of a circle radius 1 is ##2\pi##.
This is also why radians are the most natural way to do angles.
OK, add some labels
- the center of the circle is point O;
- the base line intersects the side of the circle at points A and A';
- the angle line intersects the circle at point B ... so ##\theta## is the angle AOB;
You can draw the tangent line to the circle at point A.
This intersects the angle line at point C.
The distance |AC| is called "the tangent of theta" or ##\tan\theta## for short.
You can draw the angle line in at different angles and make a plot of ##\tan\theta## vs ##\theta## and see how it behaves.
You can measure ##\tan\theta## with a ruler! For this exercise it is useful to make your unit circle quite large.
What happens as ##\theta## approaches ##\pi/2##? How about just past ##\pi/2##?
The distance |OC| is called "the secant of theta" or ##\sec\theta## for short.
You can draw a chord from point B, that makes a right-angle to the base line. It intersects the circle at B and B', and intersects the base-line at point D.
The distance |BD| is twice |BB'| ... and is called "the sine of theta" or ##\sin\theta## for short.
You can repeat the exercise above for the sine... use different angles and measure the sine.
thanks a lot for a lot of explanations ...
there is lot in it to think about ...
in the meanwhile , let me see where i can make small progresses ...
this discussion was very helpful , in moving forward positively ...
i have few more questions about little bit more advanced trigonometric functions ...
i don't know if i should be asking about it here .. or if i should start a separate thread about it ?
my question was mostly about functions such as these ...
f(x) = sin (kx − ωt)
y = sin (kx − ωt)
is it simply a representation of a trigonometric function in a graph ? or does such functions has some sort of practical application , such as some sort of wave propagation ?this was the way i was trying to understand it , from the usual basics... to graph like cyclic representation to some sort of wave propagation that goes from the theoretical representation of a function in a graph to physical wave propagation?
Collage of a woman in the foreground in front of a forest, with a CGI pack of dinosaurs in the upper left and a close-up of a dinosaur's open jaws in the upper right.
Unit circle diagram titled Finding the Values of Trig Functions, with angles in degrees and radians and coordinates (cos, sin) labelled at key points, and a 45 degree ray from the origin highlighted in red.
Diagram of a unit circle with a dashed outline and a horizontal radius to a point at its left, beside a sine curve plotted against an axis with its starting point at the origin.
until this part , it looks like some sort of wave like representation in a graph ...
which isn't actually going anywhere ...
Illustration of a beer bottle labelled Beer beside a mug of beer with a foamy head and a banner reading HIGHEST, with a hand-drawn black line scribbled across them.
but then , what happens here ??
Animation snapshot titled snapshot_sin(kx-ωt) showing a sine wave in black at the bottom, with faded repeated copies of it sloping diagonally upward to the right, and a purple wave segment above the axis.
i don't exactly understand the operations here ??
Film still of a woman with long dark hair in a forest setting, with a dinosaur head in the foreground on the right and a group of small dinosaurs in the top left corner.
May I inquire how that picture made trig more interesting...?
Four-panel comic: a stick figure says Miss Lenhart is absent and Mr. Munroe is substituting, then says the material is more vital than anything learned, followed by a worksheet of raptor word problems headed This is a matter of life and death.
micromass said:
Four-panel comic: a teacher named Mr. Munroe substitutes for Miss Lenhart, who never taught the class; a stick figure says the material is vital, then the final panel shows a worksheet with raptor pursuit trigonometry problems.
This made me laugh out loud. By far, it's the most useful application of math I've ever seen! :oldlaugh:
Nevermind @rosekidcute. Carry along. You're clearly just being prepared for the next time you come across three raptors :biggrin:
It's very funny. But question 1 and 2 are very well-posed problem too. Especially 2 is fun to solve. :biggrin:
Sure they are, but I'm not going to bother solving them because my hand is literally numb from decomposing too many partial fractions.
**Anyway, sorry for derailing the thread. Please resume back to what you were doing.
ProfuselyQuarky ,
first of all i am not really a trigonometry expert ... i have lots of things to improve from my basics ... which is sometimes why i like to use pictures ... it clearly gives me a wider picture of the things i am trying to solve ...
for example ...
this is me trying to solve
f(x) = sin x
i am not sure , what are all the sort of information i need ... to solve such a question ... i am only trying to refresh a few things from my old syllabus ...
the information should be usually looking like this ...
Collage of trigonometry visuals: a sine wave graph beside a unit circle, a 45-degree right triangle on a unit circle, a labelled right triangle with sides 3, 4 and 5, and a table of sine, cosine and tangent ratios.
lots of opposite / hypotenuse , adjacent / hypotenuse , opposite / hypotenuse ...
sometimes its a bit hard to imagine where this is all going ... and looks all the same ...
then i came across this picture ...
Collage of three scenes from a dinosaur film: a pack of small dinosaurs at top left, a woman with long dark hair in a forest in the centre, and a large open-mouthed dinosaur head with teeth at right.
and it was sort of fun trying to think something inside a triangle ...
and when you try to do this again , opposite / hypotenuse , adjacent / hypotenuse , opposite / hypotenuse ...
you should be able to see some difference ...
like one of these raptor jokes , micromass posted...
xkcd-style comic: a teacher named Mr. Munroe substitutes for Miss Lenhart; below, a printed physics word problem about a velociraptor chasing a stick figure, and a second raptor triangle diagram.
i guess the way you view it , looks a bit more interesting ... like if you start calculating the opposite / hypotenuse , adjacent / hypotenuse , opposite / hypotenuse ...
some parts of that human in the middle of those raptors ... gets eaten last ?
i am not sure about that at this point , or it could be the way i see things ... or i might be looking at it the wrong way ...
Okay, it's fantastic that you founds away to help you with trig. It takes creativity to associate something like that with the image, so if it helps you, then shoot :smile:
thanks ,
i am happy that my trigonometry is improving somehow .. even though its like a very slow activity ...
i was also wondering if anyone could help me with few more basic questions from trigonometry ...
i am like self learning this from scratch ...
when you talk about a function like ...
f(x) = sin x
the x , after the sin is the representation of angle in theta ...at the same time it also means , opposite / hypotenuse ...
so what does this question really mean ... ?
Slide with several trigonometry diagrams: a sine wave beside a unit circle, a unit circle with a 45 degree angle and cos and sin values of 0.71, a right triangle with sides 3, 4 and 5 and sin, cos and tan ratios, a labelled unit circle of angles, and a table of trig ratios.
f(x) = sin x
(the x , after the sin is the representation of angle in theta) and it also means ( opposite side length/ hypotenuse side length )
how are these things related ? i mean the angle in theta , the opposite side length / hypotenuse side length ...
