Least Square Estimator for Matrices: Bill's Problem
  • Level: Graduate
  • Thread starter bhobba
    Square
5 replies · 2K views · last reply
I recently came across the following interesting problem.
Suppose A = BC where A,B, and C are matrices. We know a ton of A's and their corresponding C's. We want the least square estimator of B.
When A and C are vectors the solution is well known.
But what is the solution when they are matrices?
Thanks
Bill
How do you intend to define the "error" between the observed and predicted values? Until that is defined, "least squares" doesn't describe a specific criteria.
Isn't there an equivalent of a perp projection operator in your space of matrices ?If this space is a Hilbert space, then, AFAIK, the general solution to this problem in a Hilbert space is the ortho. projection of B onto the subspace spanned by A,C.
Yes there is - its the trace. I will think about that one.
Thanks
Bill
Hi Guys
Thanks for all the help.
Finally nutted it out. As usual I was on the wrong track. It's simply a matter by blocking the problem and reducing it to a number of ordinary least squares problems. Break B into rows Bj so you get the usual least squares problems ||Aji - BjCi||^2. The minimum is the minimum of each of these separate problems.
Thanks
Bill
