Leisure Time Satisfaction: Gallup Poll Analysis
  • Thread starter Thread starter xsgx
    Stats
The discussion revolves around analyzing a Gallup poll that surveyed 1010 adults regarding their satisfaction with leisure time. Participants are tasked with testing the claim that two-thirds of adults are satisfied with their leisure time using a significance level of 0.01.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the formulation of null and alternative hypotheses, with some suggesting that the null hypothesis should reflect the claim of two-thirds satisfaction. Others calculate sample proportions and critical values for hypothesis testing.
There is ongoing exploration of the correct hypotheses and testing methods. Some participants have provided guidance on the use of critical values and the nature of the test (one-tailed vs. two-tailed), while others are seeking confirmation of their calculations and reasoning.
Participants are navigating the implications of using sample proportions versus established claims in hypothesis testing, and there is mention of potential errors in initial calculations that may affect the outcomes of the tests.
xsgx
OP warned about not using the homework template
Leisure Time In a Gallup poll: 1010 adults were randomly selected and asked if they were satisfied or dissatisfied with the amount of leisure time
that they had. Of this sample 657 said that they were satisfied and 353 said that they were dissatisfied. Use a 0.01 significance level to test the claim that 2/3 of adults are satisfied with the amount of leisure time that they have.
In this case is the null hypotheses 2/3 adults or the calculated proportion (.65) from the sample size?
My guess is that the null hypothesis is Ho=.65 and the alternative hypothesis is h1>.65. But I want to be sure.
For the first step I calculated P by dividing the amount of people who responded that they do have enough leisure time by the sample size:
QY4VgDAmVc1AXpMTaLfdXXF6Od5ya6tWQN-jZDD0f4UMs90m21YtvA-aLG4gkMH-o-egdKqTFwakia1HCRtJLpReyQB2hMpg.png
this gave me a P value of .65 after rounding. Since there is no previously known value of P this becomes the null hypothesis
XO1FdcjjHLvoH7CPYk2oK80qosfKDW7yG6RnC1l9_b0AIzVso0nTIeaCJMZb2CVeOID54vqZQYsUv4NOJ-0wwQCNTQKMtDYQ.png
. The ⅔ of adults claim then leads to the alternative hypothesis H1 >.65 because ⅔ = .67 after rounding. I then plugged in the values of .65 for the “previously known proportion”, .67 for P^(the claimed proportion), and the sample size of 1010 into the test statistic for a sample proportion formula from the book:
_rZCSsyNPyHNFK6n-rudHCWzM3i3R4WKUmLdg6Z-lCvISjuDLf2GSAd9FMJM8dH0EAWJbQENCJzr7UdS8HdwzP09PSybQhuw.png
. I used the traditional method of using a critical value, and since the alternative hypothesis contains a “greater than” sign the hypothesis test will be right tailed. Since the significance is a=.01 I calculated the critical value by using statdisk and plugging in .99 into the “cumlative area from the left” tab which gave me a critical value of 2.33, and because the test statistic 1.333 is far below that critical value 2.33 I failed to reject the null hypothesis.My solution to the problem. Please let me know whether I have made any errors.
Your null hypothesis should be the claim, i.e. 2/3. Use that to calculate your variance.
Also, if the question is test the validity of the claim, generally you will use a 2-tailed test, so your critical value would be for .995.
I can't imagine that your decision will change, since the proportions are so close anyway, but it might be worth another look.
^^ In that case would this be a satisfactory answer? For the first step I calculated P^ by dividing the amount of people who responded that they do have enough leisure time by the sample size:
this gave me a P^ value of .65 after rounding. Since there is already an established claim that ⅔ of adults say they are satisfied with the amount of leisure time that becomes the null hypothesis Ho: P=.67 after rounding .Therefore the alternative hypothesis would be H1: P =/ .67 . I then plugged in the values of .65 for the P^, .67 for established/claimed proportion, and the sample size of 1010 into the test statistic for a sample proportion formula from the book:
YTTcBLd9JdXuka1WTwZgXDIqLvc0E35RYmLOORJxlaAJQiio6m81vtWt06ZUzYCFEmbkcD7zHHCPecLNKnUndmWq3-Ud-8Ow.png
. I used the traditional method of using a critical value,and since the alternative hypothesis contains a =/ sign the hypothesis test will be two tailed. Since the significance is a=.01 I calculated the critical value by using statdisk and plugging in .005 into the “cumlative area from the left” tab which gave me a critical value of -2.58 for the left tail and 2.58, for the right tail, and because the test statistic -1.352 is far above the left critical value -2.58 I failed to reject the null hypothesis.
All looks right to me.
  • · Replies 25 ·
15K
  • · Replies 67 ·
17K
  • · Replies 266 ·
33K
  • · Replies 18 ·
43K
