Light reflecting between mirrors at 60.5 degrees
6 replies · 5K views · last reply
Winzer
A pair of vertical plane mirrors stands with an angle of = 60.5 degrees between them. A pencil of light approaches in a direction parallel to one of them, as shown. After the pencil has left the mirrors, in which direction will it be going? (Give your answer as the angle above the second mirror the light hits.)
3. The Attempt at a Solution [/b
I am just confused on how they want the answer.
is this how it is?
I'm trying to figure outhow this situation looks. If the diagram I drew is right then logically (since I haven't studied optics yet) if the angle between the mirrors were 90 degrees then then light would hit the other mirror perpendicularly as well, and the light wouldn't hit the mirror the light is parallel to. the angle needs to be less than 90 degrees for the light to hit the mirror that the light is parallel to at all. Since this is the case, I would assume that whatever the angle the light hits the mirror is the difference between 90 degrees and the angle made between the two mirrors. so logically (again only logically) I would say the angle of the reflected light hitting the parallel mirror is 29.5 degrees.
hope that helps, tell me if I'm right that would be awesome if i didn't even look it up.
  • Hand-drawn diagram of two mirrors meeting at a corner, with a light ray from the lower right striking the left mirror and a double-headed arrow across the inner surface. Labels: 60.5 at the corner, theta, "theta = ?", "60.5 + theta = 90°", "Light".
See I tried that as well and it was incorrect. Nice try though.
another try
the other answer I came up with is 59 degrees
changed tactic
k so then I tried to do it from a bird's eye view (see my diagram)
Since the two mirrors make a 60.5 degree angle that means the parallel light and mirror 2 also make a 60.5 degree angle. Since it comes in at that angle it bounces off mirror two, forming a 60.5 degree angle between the reflected light and mirror 2. once it strike the parallel mirror, it forms a triangle. since triangles have 180 degrees to them and you have to angles, I found the third angle... eh?
  • Handwritten bird's eye view diagram of light reflecting between two mirrors, with a ray labelled 60.5 degrees at each reflection and the note 60.5 + 60.5 = 121 degrees, and 180 - 121 = 59 = theta.
Ok I get now, its so obvious its embarassing,
thank you
