Limit Analysis: Simplifying Rational Expressions
Shackleford
1) = 0
The denominator grows much faster than the numerator.
2) = 0
Each of these terms would simply be zero, right?
For 4) and 5), the f(x) = x3
I simplified these to
4) = [(x-2)(x2+2x+4)]/(x-3)
5) = [(x-3)(x2+3x+9)]/(x-2)
http://i111.photobucket.com/albums/n149/camarolt4z28/Untitled2.png
http://i111.photobucket.com/albums/n149/camarolt4z28/Untitled.png
Shackleford said:
1) = 0
2) = 0
(1) is correct, (2) is not. In (2) your sequence is
[tex]\frac{1}{n}+ \frac{2}{n}+ \cdot\cdot\cdot+ \frac{n}{n^2}= \frac{1+ 2+ 3+ \cdot\cdot\cdot+ n}{n^2}[/tex]
Use the fact that [itex]1+ 2+ 3+ \cdot\cdot\cdot+ n= (1/2)n(n+1)[/itex].
If you are thinking you can take the limit in each term so that you get 0 for each, no that is not correct.
You can do that but the obvious point should be that denominator goes to 0 while the numerator goes to f(3)- f(2)= 27- 8 which is NOT 0.
Again, the denominator goes to 0 while the numerator does not.
For 2), I didn't know you could rewrite the sum in that manner.
I then get [(1/2)n(n+1)]/n = (1/2)[(n+1)/n] = 1/2.
If I had to guess, I would say 4) and 5) go to +/- infinity, respectively.
