Limit Comparison/Comparison Test on Non-rational functions
chrischoi614
Either the Comparison Test or Limit Comparison Test can be used to determine whether the following series converge or diverge.
which test you would use (CT or LCT)
[ii] which series you would use in the comparison.
[iii] does the series converge or not
The series of (root(n^4 +1) - n^2) n goes from 1 to infinity
2. Relevent equations
Series of 1/n^2? I am not too sure
So what i did was drag out the n^2 from the root so it becomes (n^2)(root(1+(1/n^4)))
and I know i Think i have to compare this with 1/n^2 , I know this series converge, but however I do not know how to explain correctly, to compare it with 1/n^2, if 1/n^2 really is the right one to compare to, or should i be using limit comparison test? I am quite lost at the moment, I have tried everything, but the fact that all I can use is CT and LCT, I really don't know how to solve it. I know that root (n^4 + 1) is just really close to n^2, its that (+1) that make this series happen... Pleasee and thanks :)
I would start by multiplying your expression by (sqrt(x^4+1)+n^2)/(sqrt(x^4+1)+n^2) and doing some algebra in the numerator. Then see what you think.
I actually did that before, but i ended up with 2n^4 -(2n^2)(root(n^4 +1)) + 1 in the numerator, the fact that the square root is there really is making me struggle cus i don't know how to simplify it =\
Then show us the algebra you did to get that. It's not right.
no... i didnt get it wrong :S... i just put the terms together...
I'm glad you are so confident but (sqrt(x^4+1)-n^2)*(sqrt(x^4+1)+n^2) doesn't have a sqrt in it if you expand it. Show us how you got 2n^4-(2n^2)(root(n^4 +1))+1 or we can't help you. Did you not change the sign on the n^2? That's the whole 'conjugate' thing that makes the sqrt cancel.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
