Limit of 4/e^(-x) as x approaches infinity
5 replies · 3K views · last reply
mileena
Find the limit and any horizontal asymptotes:
lim 4/(e-x)
x→∞
Principle 1: A limit defines a horizontal asymptote whenever x→∞ or x→-∞.
Principle 2: If a limit goes to ∞ or -∞, there won't be a horizontal asymptote.
lim 4/(e-x) = ∞
x→∞
since as x gets bigger, ex also gets bigger.
Horizontal Asymptote = 0
Given the above answer, if correct, then I have a problem with the two above principles I learned. Should I email my professor about these two principles? I am trying to learn these first before I do the actual homework.
Thanks!
lim 4/e-x
x→∞
lim 4/e-x = ∞
x→∞
Thanks!
So this is your function if I'm not mistaken : ##\frac{4}{e^{-x}} = 4e^x##.
As ##x → ∞##, ##4e^x → ∞##. So there are no horizontal asymptotes happening in this direction.
Why do you think ##y=0## is a horizontal asymptote for your function? Can you elaborate?
Hi Zondrina!
Yes, you interpreted the formula correctly.
I didn't realize horizontal asymptotes were subject to a direction. I thought they applied to the whole function, so I saw that as x→-∞, the function approached 0. So I thought that was a horizontal asymptote (y = 0) for the function.
EDIT: I will also go back and edit the function I posted in my first post to remove the ambiguity! I have to learn how to use the LaTeX function on this forum, but it was complicated when I first tried to even write a simple fraction!
mileena said:
Hi Zondrina!
When you went to quote my second post, it will allow you to see how I wrote the latex. You can use that to get a feel for it. Here's a good tutorial to teach you some basics as well ( complements of micromass ) :
https://www.physicsforums.com/showpost.php?p=3977517&postcount=3
Also you are correct when you say this :
I was just checking if you explicitly knew to take ##x→-∞## instead. You have to check both directions with these kinds of problems.
Thank you!
So I hope this is right:
as x→∞, the limit is also ∞, and there is no horizontal asymptote. But as x→-∞, both the limit and horizontal asymptote is 0.
For the overall function, the horizontal asymptote is y = 0.
And I also will go back and check the LaTeX. I would love to learn to write fractions and radicals, etc., correctly so they are easier to read for everyone involved. I have just been scared to try something new.
Also, technically, Principle 1 above:
"Principle 1: A limit defines a horizontal asymptote whenever x→∞ or x→-∞."
is violated here as x→∞, since the limit of the function here is ∞ but there is no horizontal asymptote.
Maybe I should email my professor and ask her to clarify this. It worked for the examples she gave in class when she said the principle:
lim(3x3 - 1000x2)
x→∞
lim(-x5 - x2 + x - 10)
x→∞
