Limit of ln(1+x²y²)/(x⁴+y⁴) as x²+y²→∞
  • Topic:
  • Thread starter Thread starter Petrus
    Limit
4 replies · 2K views
Petrus
$$f(x,y)=\frac{\ln(1+x^2y^2)}{x^4+y^4}$$
decide if it got a limit if $$x^2+y^2=\infty$$. if so calculate it.
well I go to polar form and we got
$$\lim_{r^2->\infty}\frac{\ln(1+r^2\cos^2(\theta)r^2\sin^2( \theta))}{r^4\cos^2(\theta)^4+r^4\sin^4(\theta)}$$
we see both approach to limit but the bottom will go a lot faster so it will be equal to zero, is this wrong to say like this?
Regards,
$$|\pi\rangle$$
Regards,
$$|\pi\rangle$$
Hi Petrus, :)
I would use the L'Hopital's rule over the variable \(r\).
Sudharaka said:
Hi Petrus, :)
Thanks! Now I see without finish the L'Hopital's rule as you need to do it 4 times :P we will end with a $$24\cos^2(\theta)sin^2(\theta)$$ at top and we will keep have some r at bottom which will make bottom to $$\infty$$ so it will equal to 0!:) I got one question that I would like to know.
is it allowed to say $$r^2->\infty$$ is same as $$r->\infty$$ when you calculate limits?
Regards,
$$|\pi\rangle$$
Alternatively, you can use the upper bound $\ln(1+u) \le \sqrt u$.
Btw, do you need 4 applications of l'Hospital's rule? It seems I only need 1.
It's unusual, but I don't think it's wrong.
It fits into the definition of a limit.
I like Serena said:
Alternatively, you can use the upper estimate $\ln(1+u) \le \sqrt u$.
you are correct! we will be able to divide $$4r^3$$ on top and bottom! Thanks!
Regards,
$$|\pi\rangle$$
