AplanisTophet
- Messages
- 89
- Reaction score
- 4
- TL;DR
- Examining the limits of ordinal sequences
Let ##\omega_1## be the first uncountable ordinal such that ##x## is an element of ##\omega_1## if and only if it is either a finite ordinal or there exists a bijection from ##x## onto ##\omega##.
I want to define a matrix such that the matrix contains each element of ##\omega_1## only once.
To get the first column, I might start by listing upwards from the bottom row in the standard order all the elements of ##\omega_1## before removing the limit ordinals. The remaining (non-limit) ordinals will comprise the first column of the matrix.
For the second column, I might start by listing the (limit) ordinals not contained in the first column before removing the limit ordinals of that list. The remaining ordinals will comprise the second column.
For the third column, I might again start by listing the ordinals not contained in the previous columns before removing the limit ordinals of that list.
Continue ad infinitum, such that the matrix contains each element of ##\omega_1## only once. Here is the matrix:
\begin{matrix}
\vdots & \vdots & \vdots & & \vdots \\
{\omega + 1}_{(0, \omega)} & {\omega^2 + \omega}_{(1, \omega)} & {\omega^3 + \omega^2}_{(2, \omega)} & \dots & {\omega^{\omega+1}+\omega^{\omega}}_{(\omega,\omega)} & \dots \\
3_{(0,2)} & {\omega*3}_{(1,2)} & {\omega^2*3}_{(2,2)} & \dots & {\omega^{\omega}*3}_{(\omega,2)} & \dots\\
2_{(0,1)} & {\omega*2}_{(1,1)} & {\omega^2*2}_{(2,1)} & \dots & {\omega^{\omega}*2}_{(\omega,1)} & \dots \\
1_{(0,0)} & {\omega}_{(1,0)} & {\omega^2}_{(2,0)} & \dots & {\omega^{\omega}}_{(\omega,0)} & \dots \\
\end{matrix}
Note that ##a_{(x,y)} + b_{(x,0)} = c_{(x,y+1)}## for any elements of the matrix ##a,b,## and ##c## located in the same column (column ##x##), where ##a## is in row ##y \geq 0##, ##b## is in the bottom row, and ##c## is in row ##y+1##.
**Proof: The matrix has a last column**
The matrix above only contains elements of ##\omega_1##, but consider a second matrix created the same way as the above one using all the ordinals instead. We know that ##\omega_1## would appear at position ##(\omega_1,0)## of this second matrix, ##\omega_1*\omega+\omega_1## would appear at position ##(\omega_1,\omega)##, and ##\omega_1 + \beta## would appear at ##\text{limit}_{x \rightarrow \omega_1}^{\text{matrix position }(x,\omega)}##. That is, there must be a final column of the first matrix above with order type ##\omega## because it can be the only column of that order type where, if the order type was any greater, the column would contain elements that are not in ##\omega_1##. This contradicts the standard notion that the first matrix above can have a last column or that the order type of the last column must be ##\omega_1## instead of ##\omega##, but the matrix does have a last column of order type ##\omega## because it must.
Let ##\alpha = \text{the ordinal at matrix position } (\text{last column},1)##.
Let ##\beta = \text{the ordinal at matrix position } (\text{last column},0)##.
**Questions:**
Is it true that ##\alpha = \beta + \beta \implies \beta < \alpha \implies \beta < \omega_1 \implies## there exists a bijective function from ##\beta## onto ##\omega##?
If so, then could we go on to show that ##\zeta = limit_{x \rightarrow \omega_1}^{\text{matrix position } x,\beta}## is also in ##\omega_1##. And since ##\zeta \in \omega_1##, can't we now show that ##\theta = limit_{x \rightarrow \omega_1}^{\text{matrix position } x,\zeta}## is also in ##\omega_1##, ad inifinitum, so as to start enumerating the matrix and contradict the assumption that ##\omega_1## is uncountable?
If the limits of the rows are countable and we put them into a sequence such that they are the range of a normal function ##f## (ie, ##f(1) = \beta, f(2) = \zeta, f(3) = \theta##, and so on), then does this normal function contradict the fixed-point lemma because it doesn't have any fixed points nor is the set of all fixed points unbounded in ##\omega_1##?
**My Proposed Conclusion**
There is no first uncountable ordinal because there cannot be. Assuming the existence of ##\omega_1## leads to the above countable matrix containing all of its elements, contradicting the assumption that ##\omega_1## is uncountable. I note that the above matrix takes the shape of a 'quarter circle'. I also note that there are uncountable cardinals and I believe Cantor found the first one, but nevertheless, the continuum hypothesis rests on the existence of an uncountable ordinal and there are none so it is solved.
Thank you for reading!
B.J.K. 10-21-21
\begin{matrix}
\end{matrix}
**Questions:**
B.J.K. 10-21-21
