lonewolf219 said:
(I am assuming we are evaluating the function at the point (0,0), if this is correct terminology?)
When y=x, the x^8 is evaluated at 0, but what happens to the remaining fraction x^5/x^4. Is that simply "x", which is then evaluated again at 0?
When y=x^4, the x^8 in the denominator again becomes 0, and a fraction remains that is x^8/x^8 which is 1? Thanks for your reply scurty
But perhaps this is not simply evaluating a function at point (a)...
I'm assuming that what you mean by "the function," you mean ## \frac{x^4y}{x^8 + y^4}##.
If so, you cannot evaluate this function at the point (0, 0), because this function is undefined there. That's the reason that you are asked to evaluate the limit as (x, y) → (0, 0).
Along each the specified paths, the function simplifies to a different function that involves only x, and you can take the limit as x → 0.
Note that for both limits, you cannot simply evaluate the limit expression at x = 0, as both limit expressions are undefined at x = 0. Using the properties of limits, however, you can evaluate both limits.
As you have found, on each of these paths a limit exists, but it is not the same limit for both paths.
scurty said:
Yes, that's exactly what you are doing.
No it isn't. The function in the original limit is undefined at the point (0, 0). In addition, along each of the two paths, the simplfied limit expression was undefined at x = 0.
