Line perpendicular to plane 2x - 3y + 5z = 4 through (1,2,4)
  • Thread starter Thread starter andrey21
14 replies · 2K views
andrey21
Find the equation of the straight line which is perpendicular to the plane.
2x - 3y +5z = 4
Which goes through the point (1,2,4)
Heres my attempt
Direction of the normal to the plane is:
(2,-3, 5)
So equation of desired line is:
r(t) = (1,2,4) + t (2,-3, 5)
Is this correct?
How do I see if (3,-1, 9) is on the line??
Any comments would be great :)
2x - 3y +5z = 4
Heres my attempt
(2,-3, 5)
Is this correct?
Yes.
If you can find a value of t for which (1, 2, 4) + t(2, -3, 5) = (3, -1, 9), then that point is on the line. If there is no such value of t, that point is not on the line.
Fantastic I eventually arrived at a value for t=1. So the point is on the line.
Yes, that's what I got, too.
Geometrically r(1) is a vector from the origin to the point (3, -1, 9).
Great thanks mark 44, I do have another question if you dot mind taking a look.
I have been asked to find the fixed points of the bilinear map
f(z) = z+1/z-1
Now by setting this = z and cross multiplying I get:
z+1 = z^2 -z
Which becomes:
z^2 = 1
Now do I say the fixed points are z =1 and z=1 because it is a quadratic, or just on its own z =1 ?
f(z) = z+1/z-1
From the context below, I assume that you mean f(z) = (z + 1)/(z -1). As you wrote this, it would be interpreted as z + (1/z) - 1. When you are writing a rational expression as a single line of text, put parentheses around the whole numerator and the whole denominator if they consist of more than a single term.
Better yet, learn how to write using LaTeX.
[tex]f(z) =\frac{z+1}{z-1}[/tex]
Click the equation to see my LaTeX script.
z+1 = z^2 -z
Which becomes:
z^2 = 1
This equation has two solutions, one of which is not allowed here because it's not in the domain of your function f.
See above.
So it has only one solution??
You have an error in your work that I didn't spot before. The equation you started with is
z = (z + 1)/(z - 1)
If you multipy both sides by z - 1, you get z2 - z = z + 1, which is not equivalent to z2 = 1.
There are two real fixed points for your function.
Ah I see thank you mark 44 I didnt spot that error at all, so that would give me z^2 -2z -1 correct?
Yes I ended up with z = (2+SQRT(8))/2 and z=(2-SQRT(8))/2 I substituted the back into z^2 - z -1 and they equaled zero.
Ah ok so:
(2+SQRT(8))/2 becomes:
(2+SQRT(4).SQRT(2))/2
(2+2SQRT(2))/2
1+SQRT 2correct?
