Linear Regression with Measurement Errors
The discussion focuses on performing linear regression with measurement errors in both independent (X) and dependent (Y) variables. Standard regression methods typically assume errors only in the Y variable, but when X has significant errors, total least squares or Deming regression should be used. Resources such as Wikipedia and R packages like mcr are recommended for implementing these methods. It is also advised to consider equal variances for X and Y and to compute the correlation coefficient to evaluate the fit. Overall, treating errors in both variables separately leads to a more accurate regression analysis.
Arishy Han
Hello,
I have a set of data, two columns, and each datum has its measurement error like illustration shows below:
x | y
x1+/-xe1 | y1+/-ye1
Now, I intend to find a best fitting line with those data.
I just ask where I can find the sources or exact formulae that I can
calculate the slope and the intercept even the slope variance and intercept variance.
Thank you so much,
Han
Mathematics news on Phys.org
Every statistics textbook should have the formulas, every statistics tool will have them, for a simple least square approximation you can also follow the links at the Wikipedia article.
Thank you !
I don't know what you call "standard", as long as the uncertainties can be treated as uncorrelated Gaussians this looks pretty regular to me.
The sum-square function being minimized is different when X measurements have errors. The error in the X measurement should not be treated as an error of the Y variable. The errors should not be added since there is a significant difference between 2 independent random error variables being 1 σ from 0 versus 1 variable being 2 σ from 0.
From the second figure of wikipedia link above: "The bivariate (Deming regression) case of total least squares. The red lines show the error in both x and y. This is different from the traditional least squares method which measures error parallel to the y axis. The case shown, with deviations measured perpendicularly, arises when x and y have equal variances."
The Deming regression reminds me of the Principle Component Analysis. I can't immediately see the difference.
Apparently the Demming Regression can be done in the language R after installing the mcr package. See https://www.r-bloggers.com/deming-and-passing-bablok-regression-in-r/. I have no experience with it.
PS. It may be advisable to rescale the X and/or Y variables so that their sample variances are equal. If these algorithms minimize a total sum-squared errors, it may be necessary that the variance of both variables be equal. However, the algorithms might already take care of this.
Don't forget to compute the correlation coefficient (r2) when you are through. The linear regression formula gives you an answer every time - even if it is clearly wrong. I have seen researchers in the softer disciplines using linear regression on every set of data they have in the hope of finding some significance and getting excited over an r2 of 0.01(!).
Guess the correlation
With given uncertainties, chi^2/ndf shows how reasonable the linear fit is.
No one suggested that. You have to find the point on the line that fits best given the two independent uncertainties (in x and y). That is a single analytic expression.
With given uncertainties, chi^2/ndf shows how reasonable the linear fit is.No one suggested that. You have to find the point on the line that fits best given the two independent uncertainties (in x and y). That is a single analytic expression.
The standard linear regression algorithms assume that the random error is added to the Y variable only. Treating the X and Y errors separately gives a different regression line, which is the correct one in this case.
  • · Replies 23 ·
  • · Replies 30 ·
