Linearising Christoffel symbols
The discussion centers around the linearization of Christoffel symbols in the context of weak gravitational fields, specifically through perturbative methods involving the metric tensor. Participants explore the implications of assuming small perturbations and the behavior of derivatives of these perturbations.
  • One participant presents the linearization of the metric tensor and the resulting expression for Christoffel symbols, questioning the assumption that the partial derivatives of the perturbation are of the same order as the perturbation itself.
  • Another participant compares the situation to a matrix approximation, suggesting that the behavior of small perturbations can be understood similarly to a Taylor expansion.
  • There is a discussion about the clarity gained by introducing a constant factor in the perturbation, which helps in understanding the order of terms in the expansion.
  • Concerns are raised about the order of derivatives of the perturbation and whether they can be considered small, with some participants suggesting that these derivatives could potentially be larger than expected.
  • Participants express uncertainty about the implications of the order of terms in the equations, particularly regarding which terms can be neglected in the linear approximation.
Participants do not reach a consensus on the assumptions regarding the order of derivatives and perturbations. There are competing views on how to interpret the order of terms and their significance in the context of the linearization process.
Limitations include unresolved assumptions about the behavior of perturbations and derivatives, as well as the implications of neglecting certain terms in the equations presented.
chartery
Carroll linearising by perturbation ##g_{\mu\nu}=\eta_{\mu\nu}+h_{\mu\nu}## has: (Notes 6.4, Book 7.4)
##\Gamma^{\rho}_{\mu\nu}=\frac{1}{2}g^{\rho\lambda}\left( {\partial_{ \mu}}g_{\nu\lambda}+{\partial_{ \nu}}g_{\lambda\mu}-{\partial_{ \lambda}}g_{\mu\nu}\right)=\frac{1}{2}\eta^{\rho\lambda}\left( {\partial_{ \mu}}h_{\nu\lambda}+{\partial_{ \nu}}h_{\lambda\mu}-{\partial_{ \lambda}}h_{\mu\nu}\right)##
This must mean that ##{\partial_{ \mu}}h_{\nu\lambda}## is taken to be of same order as ##h^{\rho\lambda}##
I can't find a justification anywhere, so I guess everyone thinks it self-evident.
Is it certain that a weak gravitational field cannot vary quickly or 'strongly' ?
It is essentially the matrix equivalent of
\frac{1}{1+x} \simeq 1 - x
for small ##x##
for small ##x##
Sorry, you've lost me. Were you referring to ##g^{\mu\nu}=\eta^{\mu\nu}-h^{\mu\nu}##?
My problem was how to know that the partial derivative (i.e. variation) of a small item was necessarily also small.
if ##\frac{1}{1+x}## is how I should think of ##\partial_{\mu}## here, I'm afraid I need extra guidance.
It becomes more clear if you write
$$g_{\mu \nu}=\eta_{\mu \nu} + \epsilon h_{\mu \nu} \qquad (1)$$
with ##\epsilon=const.## and taking all quantities of interest only up to linear order in ##\epsilon##.
For the inverse metric you have
$$g^{\mu \nu}= \eta^{\mu \nu} -\epsilon h^{\mu \nu}+\mathcal{O}(\epsilon^2)$$
with
$$h^{\mu \nu}=\eta^{\mu \rho} \eta^{\nu \sigma} h_{\rho \sigma}, \qquad (2)$$
because then
$$(\eta^{\mu \nu} - \epsilon h^{\mu \nu}+\mathcal{O}(\epsilon^2))(\eta_{\nu \sigma} + \epsilon h_{\nu \sigma}= \delta_{\sigma}^{\mu} - \epsilon {h^{\mu}}_{\sigma}) + \epsilon {h^{\mu}}_{\sigma}+\mathcal{O}(\epsilon^2) = \delta_{\sigma}^{\mu} + \mathcal{O}(\epsilon^2).$$
For the Christoffels you plug (1) and (2) in the definition equation and immediately see that they are of order ##\epsilon## and given at this order by the equation in the OP.
I may have read your OP a bit quick. There are a couple of things to consider here.
The foremost one is that the derivatives of eta vanish and the derivatives you have left are multiplied by essentially eta+O(h). Regardless of the derivatives of h are in terms of size, multiplying them by h is going to give you something of higher order than multiplying by eta.
Apart from that, further assumptions on slow variations etc are common.
Sorry @vanhees71 I can't get the multiple quote insert to work!Yes, my problem was being sure that ##h^{\rho\lambda}{\partial_{ \mu}}h_{\nu\lambda}## terms were order ##h^2##
It makes sense that ##\epsilon h^{\rho\lambda} {\partial_{ \mu}}\epsilon h_{\nu\lambda}## would be order ##\epsilon^2##
Many thanks
Many thanks
I mean, your worry is partially justified. There is nothing a priori stopping ##\partial h## to be order ##1/\epsilon## in the above. However, it will always be the case that - regardless of the order of the derivative - the h-term in front will be one order higher than the leading one.
Sorry for gap. I can see Vanhees understands, though it seems to me if ##\partial h## is order ##1/\epsilon## then ##\epsilon h^{\rho\lambda} {\partial_{ \mu}}\epsilon h_{\nu\lambda}## is only order ##\epsilon## but needs to be order ##\epsilon^2## to be ignored in OP equation?
If that is the case then the leading term in OP's equations is ##\mathcal O(1)##, not ##\mathcal O(\epsilon)##. Therefore, to leading non-trivial order, terms ##\mathcal O(\epsilon)## should be ignored.
Durr... Got fixated on second term of ## \eta^{\rho\lambda} {\partial_{ \mu}}\epsilon h_{\nu\lambda} - \epsilon h^{\rho\lambda} {\partial_{ \mu}}\epsilon h_{\nu\lambda}## (just in case someone of similar density looking up).
Many thanks.
  • · Replies 17 ·
  • · Replies 62 ·
