Homework Helper
- 4,080
- 2,130
- TL;DR
- I'm taking along a "gravitational altimeter" and trying to make sense of what I would see.
So, as with the many fictitious characters that have preceded me, I am going to drop into a black hole - and I will bring along Alice, that "outside observer" who hangs around black holes waiting for "Bob"s to drop in.
I am going to take along a gravitational altimeter. And I'm going to use a gravitational altimeter design that I believe is easier to model in the BH environment. That altimeter will just be side-by-side pendulums of equal length. At the top they will be a fixed distance apart (symbol W). At the bottom, they will be very, very slightly closer - by a distance dH. And the length of the pendulums will be of equal length L. So, my altitude above the center of whatever mass I am hovering over will be r=L dH / H.
For convenience, I will calibrate my altimeter so the readout (R) is expressed in Schwarzschild radii. So, R = r/S = L dH /(SH).
I do not believe this altimeter will be reporting my areal radius as seen by an outside observer. I will call that "A" (as in Alice's Areal report of my Altitude).
I will descend in luxury - using a Dyson sphere with these specialized accoutrements:
1) It will be made of that sturdy unobtainium alloy that exhibits a speed of sound that matches the speed of light.
2) It will have an adjustable diameter - so, at least initially, I will be able to descend towards the even horizon steps and wait at each step.
3) My box seat will be along the interior surface of this sphere - providing me with a full view of the black hole, the interior of the Dyson, and any other box seats.
When the Dyson sphere is very large compared to the event horizon, then (except for its mass) the effects of the black hole are negligible. And from my box seat, I see this:
I can see the pendulums from all the other box seats and I can see them all pointing directly at the black hole.
But as I descend further and approach A=1.5, the photon sphere, things no longer fall so simply into place.
To see what happens to those pendulums, imagine how the interior surface of the Dyson sphere would appear if it was allowed to descend that far.
At A=1.5, light would be circling the black hole and traveling across the interior surface of the Dyson sphere. So all of the box seats would appear to me to be resting on a wide plane. All of those pendulums would be pointing in the same direction, at a right angle to that plane, as if the black hole was at infinity. And similarly, my gravitational altimeter would be pinned at infinity. So, at A=1.5, R is pinned.
Also at A=1.5, it does not appear to me that there are any compression forces on the Dyson sphere at all. Each part of the sphere has its own unobstructed trajectory towards the black hole that does not conflict with any other part. And, if that's the case, the diameter of the Dyson sphere will not have the same control over the altitude above the black hole that is did when A>1.5.
The problem I have is with that altimeter. It is never going to read between R=0 to about R=3. I believe it will bottom out at a reading of roughly R=3 when A is about 2.
And if I go beyond A, my altimeter goes negative (R<0) - as if the mass of the black hole was in back of me.
And about that altimeter design. The conventional gravitational altimeters measure the difference between gravitational accelerations between a higher and lower part of the instrument. Would they give the same readings as my pendulum-style meters? This is a question for someone who understands GR better than me - but I can't see how they could be different. If that's the case, if you survive A=2 in your drop into the BH, you should have just survived the worse of the speghetification forces.
