Loop-and-allied QG bibliography
  • Context: Graduate
  • Thread starter Thread starter marcus
    Bibliography
2,547 replies · 762K views
http://arxiv.org/abs/0807.1481
Is gravitational entropy quantized?
Dawood Kothawala, T. Padmanabhan, Sudipta Sarkar
4 pages
(Submitted on 9 Jul 2008)
"In Einstein's gravity, the entropy of horizons is proportional to their area. Several arguments given in the literature suggest that, in this context, both area and entropy should be quantized with an equally spaced spectrum for large quantum numbers. But in more general theories (like, for e.g, in the black hole solutions of Gauss-Bonnet or Lanczos-Lovelock gravity) the horizon entropy is not proportional to area and the question arises as to which of the two (if at all) will have this property. We give a general argument that in all Lanczos-Lovelock theories of gravity, it is the entropy that has equally spaced spectrum. In the case of Gauss-Bonnet gravity, we use the asymptotic form of quasi normal mode frequencies to explicitly demonstrate this result. Hence, the concept of a quantum of area in Einstein Hilbert (EH) gravity needs to be replaced by a concept of quantum of entropy in a more general context."
http://arxiv.org/abs/0807.1854
DSR as an explanation of cosmological structure
Joao Magueijo
(Submitted on 11 Jul 2008)
"Deformed special relativity (DSR) is one of the possible realizations of a varying speed of light (VSL). It deforms the usual quadratic dispersion relations so that the speed of light becomes energy dependent, with preferred frames avoided by postulating a non-linear representation of the Lorentz group. The theory may be used to induce a varying speed of sound capable of generating (near) scale-invariant density fluctuations, as discussed in a recent Letter. We identify the non-linear representation of the Lorentz group that leads to scale-invariance, finding a universal result. We also examine the higher order field theory that could be set up to represent it."
http://arxiv.org/abs/0807.1726
Axion Cosmology and the Energy Scale of Inflation
Mark P Hertzberg (MIT), Max Tegmark (MIT), Frank Wilczek (MIT)
5 pages, 4 figures
special Quantum Gravity issue of ASL, edited by Bojowald---Padma's invited article
http://arxiv.org/abs/0807.2356
Dark Energy and its Implications for Gravity
Thanu Padmanabhan
Invited article to appear in Advanced Science Letters Special Issue on Quantum Gravity, Cosmology and Black holes (editor: M. Bojowald)
(Submitted on 15 Jul 2008)
"The cosmological constant is the most economical candidate for dark energy. No other approach really alleviates the difficulties faced by the cosmological constant because, in all other attempts to model the dark energy, one still has to explain why the bulk cosmological constant (treated as a low-energy parameter in the action principle) is zero. I argue that until the theory is made invariant under the shifting of the Lagrangian by a constant, one cannot obtain a satisfactory solution to the cosmological constant problem. This is impossible in any generally covariant theory with the conventional low-energy matter action, if the metric is varied in the action to obtain the field equations. I review an alternative perspective in which gravity arises as an emergent, long wavelength phenomenon and can be described in terms of an effective theory using an action associated with null vectors in the spacetime. This action is explicitly invariant under the shift of the energy momentum tensor [tex]T_{ab}\to T_{ab}+\Lambda g_{ab}[/tex] and any bulk cosmological constant can be gauged away. Such an approach seems to be necessary for addressing the cosmological constant problem and can easily explain why its bulk value is zero. I describe some possibilities for obtaining its observed value from quantum gravitational fluctuations."
http://arxiv.org/abs/0807.2806
Phase space descriptions for simplicial 4d geometries
Bianca Dittrich, James P. Ryan
(Submitted on 17 Jul 2008)
"Starting from the canonical phase space for discretised (4d) BF--theory, we implement a canonical version of the simplicity constraints and construct phase spaces for simplicial geometries. Our construction allows us to study the connection between different versions of Regge calculus and approaches using connection variables, such as loop quantum gravity. We find that on a fixed triangulation the (gauge invariant) phase space associated to loop quantum gravity is genuinely larger than the one for length and even area Regge calculus. Rather, it corresponds to the phase space of area--angle Regge calculus, as defined by Dittrich and Speziale in [arXiv:0802.0864] (prior to the imposition of gluing constraints, that ensure the metricity of the triangulation). We argue that this is due to the fact that the simplicity constraints are not fully implemented in canonical loop quantum gravity. Finally, we show that for a subclass of triangulations one can construct first class Hamiltonian and Diffeomorphism constraints leading to flat 4d space--times."
http://arxiv.org/abs/0807.2808
Emergent diffeomorphism invariance in a discrete loop quantum gravity model
Rodolfo Gambini, Jorge Pullin
12 pages
"Several approaches to the dynamics of loop quantum gravity involve discretizing the equations of motion. The resulting discrete theories are known to be problematic since the first class algebra of constraints of the continuum theory becomes second class upon discretization. If one treats the second class constraints properly, the resulting theories have very different dynamics and number of degrees of freedom than those of the continuum theory. It is therefore questionable how these theories could be considered a starting point for quantization and the definition of a continuum theory through a continuum limit. We show explicitly in a model that the uniform discretizations approach to the quantization of constrained systems overcomes these difficulties. We consider here a simple diffeomorphism invariant one dimensional model and complete the quantization using uniform discretizations. The model can be viewed as a spherically symmetric reduction of the well known Husain--Kuchar model of diffeomorphism invariant theory. We show that the correct quantum continuum limit can be satisfactorily constructed for this model. This opens the possibility of treating 1+1 dimensional dynamical situations of great interest in quantum gravity taking into account the full dynamics of the theory and preserving the space-time covariance at a quantum level."
http://arxiv.org/abs/0807.2652
The Barbero-Immirzi Parameter as a Scalar Field: K-Inflation from Loop Quantum Gravity?
Victor Taveras, Nicolas Yunes
11 pages, submitted to Phys. Rev. D
(Submitted on 16 Jul 2008)
"We consider a loop-quantum gravity inspired modification of general relativity, where the Holst action is generalized by making the Barbero-Immirzi (BI) parameter a scalar field, whose value could be dynamically determined. The modified theory leads to a non-zero torsion tensor that corrects the field equations through quadratic first-derivatives of the BI field. Such a correction is equivalent to general relativity in the presence of a scalar field with non-trivial kinetic energy. This stress-energy of this field is automatically covariantly conserved by its own dynamical equations of motion, thus satisfying the strong equivalence principle. Every general relativistic solution remains a solution to the modified theory for any constant value of the BI field. For arbitrary time-varying BI fields, a study of cosmological solutions reduces the scalar field stress-energy to that of a pressureless perfect fluid in a comoving reference frame, forcing the scale factor dynamics to be equivalent to those of a stiff equation of state. Upon ultraviolet completion, this model could provide a natural mechanism for k-inflation, where the role of the inflaton is played by the BI field and inflation is driven by its non-trivial kinetic energy instead of a potential."
http://arxiv.org/abs/0807.2838
A Bi-Metric Theory with Exchange Symmetry
S. Hossenfelder
8 pages
"We propose an extension of General Relativity with two different metrics. To each metric we define a Levi-Cevita connection and a curvature tensor. We then consider two types of fields, each of which moves according to one of the metrics and its connection. To obtain the field equations for the second metric we impose an exchange symmetry on the action. As a consequence of this ansatz, additional source terms for Einstein's field equations are generated. We discuss the properties of these additional fields, and consider the examples of the Schwarzschild solution, and the Friedmann-Robertson-Walker metric."
Taveras paper here is likely to be quite useful. It is just the sort of thing one would want to have available
http://arxiv.org/abs/0807.3325
Corrections to the Friedmann Equations from LQG for a Universe with a Free Scalar Field
Victor Taveras
9 pages
(Submitted on 21 Jul 2008)
"In loop quantum cosmology the quantum dynamics is well understood. We approximate the full quantum dynamics in the infinite dimensional Hilbert space by projecting it on a finite dimensional submanifold thereof, spanned by suitably chosen semiclassical states. This submanifold is isomorphic with the classical phase space and the projected dynamical flow provides effective equations incorporating the leading quantum corrections to the classical equations of motion. Numerical work has been done using quantum states which are semiclassical at late times. These states follow the classical trajectory until the density is on the order of 1% of the Planck density then deviate strongly from the classical trajectory. The effective equations we obtain reproduce this behavior to surprising accuracy."
Taveras is in Ashtekar's group at Penn State. The next paper develops the theme of adding matter to simplicial quantum gravity
which the Ambjorn Loll triangulations people are also currently concerned with.
http://arxiv.org/abs/0807.3041
A Kirchoff-like conservation law in Regge calculus
Adrian P. Gentle, Arkady Kheyfets, Jonathan R. McDonald, Warner A. Miller
13 pages, 4 figures, submitted to Class. Quantum Grav
(Submitted on 18 Jul 2008)
"Simplicial lattices provide an elegant framework for discrete spacetimes. The inherent orthogonality between a simplicial lattice and its circumcentric dual yields an austere representation of spacetime which provides a conceptually simple form of Einstein's geometric theory of gravitation. A sufficient understanding of simplicial spacetimes has been demonstrated in the literature for spacetimes devoid of all non-gravitational sources. However, this understanding has not been adequately extended to non-vacuum spacetime models. Consequently, a deep understanding of the diffeomorphic structure of the discrete theory is lacking. Conservation laws and symmetry properties are attractive starting points for coupling matter with the lattice. We present a simplicial form of the contracted Bianchi identities which is based on the E. Cartan moment of rotation operator. These identities manifest themselves in the conceptually-simple form of a Kirchoff-like conservation law. This conservation law enables one to extend Regge Calculus to non-vacuum spacetimes, and provides a deeper understanding of the simplicial diffeomorphism group."
http://arxiv.org/abs/0807.3042
Stability of the Schwarzschild Interior in Loop Quantum Gravity
Christian G. Boehmer, Kevin Vandersloot
4 pages, 4 figures
"In recent work, the Schwarzschild interior of a black hole was investigated, incorporating quantum gravitational modifications due to loop quantum gravity. The central Schwarzschild singularity was shown to be replaced by a Nariai type universe. In this brief report we show that this interior solution is stable with respect to small perturbations, in contrast to the classical Nariai universe."
http://arxiv.org/abs/0807.3188
On gravitational defects, particles and strings
Winston J. Fairbairn
30 pages
(Submitted on 20 Jul 2008)
"We study the inclusion of point and string matter in the deSitter gauge theory, or MacDowell-Mansouri formulation of four dimensional gravity. We proceed by locally breaking the gauge symmetries of general relativity along worldlines and worldsheets embedded in the spacetime manifold. Restoring full gauge invariance introduces new dynamical fields which describe the dynamics of spinning matter coupled to gravity. We discuss the physical interpretation of the obtained formalism by studying the flat limit and the spinless case on arbitrary backgrounds. It turns out that the worldline action describes a massive spinning particle, while the worldsheet action contains the Nambu-Goto string augmented with spinning contributions. Finally, we study the gravity/matter variational problem and conclude by discussing potential applications of the formalism to the inclusion of the Nambu-Goto string in spinfoam models of four dimensional quantum gravity."
Winston Fairbairn was one of Rovelli's bunch, at Marseille. The first I heard of him was when he co-authored a really interesting paper with Rovelli, as he was a PhD student, back around 2004. Now he is at John Barrett's at Nottingham. This looks exciting, maybe one can get some stringy goodies in the context of 4D quantum gravity without all those extra dimensions.
Additional sample exerpt to help assess the paper's importance:
"Our common quantum relativistic understanding of matter in terms of finite dimensional, irreducible representations of the Poincare algebra is a very rough approximation of reality. This description is tied to the isometries of the flat, Minkowski solution to general relativity and yields a good approximation only in very weak gravitational fields, like for instance, in our particle accelerators where the successes of quantum field theory have been crowned.
In a fundamental theory of Nature, one cannot expect this approximation to be valid since in the early, Planckian universe, spacetime is undoubtedly not flat. Accordingly, the search of the fundamental structure of matter is tied to non-trivial, and certainly quantum configurations of the gravitational field. In turn, a complete theory of quantum gravity will have to incorporate a precise description of the degrees of freedom of matter.
As a first step, it seems therefore natural to look for an understanding of matter which does not rely on a particular fixed background geometry at the classical level. This will automatically render the formulation compatible with non-perturbative attempts to the quantisation of gravity which cannot, consistently, rely on a fixed, background metric structure.
A very old and appealing idea consists in considering the Einstein equations as defining the notion of matter. In other words, to consider matter as particular, possibly singular, configurations of the gravitational field. In this framework, we are reversing the standard picture where matter is defined on flat spacetime and then tentatively extended to other solutions of general relativity. Here, we are starting from the gravitational perspective, without selecting a preferred solution, and deriving matter from the geometry of spacetime. Obviously, this formulation should reproduce the standard properties of matter in the flat limit, but will also select a preferred formulation from the gravitational perspective.
For example, such a reversed approach has recently led to conceptually and technically strong results regarding the coupling of matter to three dimensional quantum gravity [2], [3].
The concrete implementation of this procedure relies on a the gauge symmetries
of gravity,..."
http://arxiv.org/abs/0807.3281
Definition of a time variable with Entropy of a perfect fluid in Canonical Quantum Gravity
Giovanni Montani (1, 2 and 3), Simone Zonetti (1) ((1) Dipartimento di Fisica, Universita degli Studi di Roma "La Sapienza", (2) ENEA C.R. Frascati (Dipartimento F.P.N.), (3) ICRANet C.C. Pescara.)
14 pages, no figures. Submitted to Phys. Rev. D
"The Brown-Kuchar mechanism is applied in the case of General Relativity coupled with the Schutz' model for a perfect fluid. Using the canonical formalism and manipulating the set of modified constraints one is able to recover the definition of a time evolution operator, i.e. a physical Hamiltonian, expressed as a functional of gravitational variables and the entropy. Entropy then reveals to be, in the comoving frame, the time variable for the system, and a simple evolution operator is obtained."
http://arxiv.org/abs/0807.3161
A comparative review of recent researches in geometry
Felix C. Klein
26 pages
"Felix Klein's so-called Erlangen Program was published in 1872 as professoral dissertation. It proposed a new solution to the problem how to classify and characterize geometries on the basis of projective geometry and group theory. The given translation was made in 1892 by Dr. M. W. Haskell and transcribed by N. C. Rughoonauth. We replaced bibliographical data in text and footnotes with pointers to a complete bibliography section."
http://arxiv.org/abs/0807.3561
Spin-Foam Models and the Physical Scalar Product
Emanuele Alesci, Karim Noui, Francesco Sardelli
24 pages
(Submitted on 22 Jul 2008)
"This paper aims at clarifying the link between Loop Quantum Gravity and Spin-Foam models in four dimensions. Starting from the canonical framework, we construct an operator P acting on the space of cylindrical functions Cyl(Gamma), where Gamma is the 4-simplex graph, such that its matrix elements are, up to some normalization factors, the vertex amplitude of Spin-Foam models. The Spin-Foam models we are considering are the topological model, the Barrett-Crane model and the Engle-Pereira-Rovelli model. The operator P is usually called the "projector" into physical states and its matrix elements gives the physical scalar product. Therefore, we relate the physical scalar product of Loop Quantum Gravity to vertex amplitudes of some Spin-Foam models. We discuss the possibility to extend the action of P to any cylindrical functions on the space manifold."
New paper by Ambjorn, Goerlich, Jurkiewicz, and Loll
http://arxiv.org/abs/0807.4481
The Nonperturbative Quantum de Sitter Universe
J. Ambjorn, A. Goerlich, J. Jurkiewicz, R. Loll
37 pages, many figures
(Submitted on 28 Jul 2008)
"The dynamical generation of a four-dimensional classical universe from nothing but fundamental quantum excitations at the Planck scale is a long-standing challenge to theoretical physicists. A candidate theory of quantum gravity which achieves this goal without invoking exotic ingredients or excessive fine-tuning is based on the nonperturbative and background-independent technique of Causal Dynamical Triangulations. We demonstrate in detail how in this approach a macroscopic de Sitter universe, accompanied by small quantum fluctuations, emerges from the full gravitational path integral, and how the effective action determining its dynamics can be reconstructed uniquely from Monte Carlo data. We also provide evidence that it may be possible to penetrate to the sub-Planckian regime, where the Planck length is large compared to the lattice spacing of the underlying regularization of geometry." http://arxiv.org/abs/0807.4192
Black Hole Entropy and the Problem of Universality
Steven Carlip
14 pages, Springer macros; to appear in 'Quantum Mechanics of Fundamental Systems: the Quest for Beauty and Simplicity' (Claudio Bunster Festschrift)
(Submitted on 25 Jul 2008)
"To derive black hole thermodynamics in any quantum theory of gravity, one must introduce constraints that ensure that a black hole is actually present. For a large class of black holes, the imposition of such 'horizon constraints' allows the use of conformal field theory methods to compute the density of states, reproducing the correct Bekenstein-Hawking entropy in a nearly model-independent manner. This approach may explain the 'universality' of black hole entropy, the fact that many inequivalent descriptions of quantum states all seem to give the same thermodynamic predictions. It also suggests an elegant picture of the relevant degrees of freedom, as Goldstone-boson-like excitations arising from symmetry breaking by a conformal anomaly induced by the horizon constraints.
Claudio Bunster, who is being celebrated by this collection of papers, used to be Claudio Teitelboim---a safer name to have in Chile during the Pinochet years. The name Bunster which he has now adopted was associated with opposition to military dictatorship. To find Bunster's research writings, search under his previous name.
http://arxiv.org/abs/0807.4152
The Constraint Algebra of Topologically Massive AdS Gravity
Steven Carlip
17 pages
"Three-dimensional topologically massive AdS gravity has a complicated constraint algebra, making it difficult to count nonperturbative degrees of freedom. I show that a new choice of variables greatly simplifies this algebra, and confirm that the theory contains a single propagating mode for all values of the mass parameter and the cosmological constant. As an added benefit, I rederive the central charges and conformal weights of the boundary conformal field theory from an explicit analysis of the asymptotic algebra of constraints."
http://arxiv.org/abs/0807.4520
Black Hole Thermodynamics and Statistical Mechanics
Steven Carlip
35 pages, Springer macros; for the Proceedings of the 4th Aegean Summer School on Black Holes
"We have known for more than thirty years that black holes behave as thermodynamic systems, radiating as black bodies with characteristic temperatures and entropies. This behavior is not only interesting in its own right; it could also, through a statistical mechanical description, cast light on some of the deep problems of quantizing gravity. In these lectures, I review what we currently know about black hole thermodynamics and statistical mechanics, suggest a rather speculative 'universal' characterization of the underlying states, and describe some key open questions."
http://arxiv.org/abs/0807.4468
The cosmological BCS mechanism and the Big Bang Singularity
Stephon Alexander, Tirthabir Biswas
11 pages, 1 figure
"We provide a novel mechanism that resolves the Big Bang Singularity present in FRW space-times without the need for ghost fields. Building on the fact that a four-fermion interaction arises in General Relativity when fermions are covariantly coupled, we show that at early times the decrease in scale factor enhances the correlation between pairs of fermions. This enhancement leads to a BCS-like condensation of the fermions and opens a gap dynamically driving the Hubble parameter to zero and results in a non-singular bounce. We derive the four fermion interaction and the effective potential for the gap, demonstrating a consistency condition necessary for the non-singular bounce."
http://arxiv.org/abs/0807.4574v1
Proof of the entropy bound on dynamical horizons
Authors: Sijie Gao, Xiaoning Wu
(Submitted on 29 Jul 2008)
"The entropy bound conjecture concerning black hole dynamical horizons is proved. The conjecture states, if a dynamical horizon, $D_H$, is bounded by two surfaces with areas of $A_B$ and $\abp$ ($\abp>A_B$), then the entropy, $S_D$, that crosses $D_H$ must satisfy $S_D\leq {1/4}(\abp-A_B)$. We show that this conjecture is implied by the generalized Bousso bound. Consequently, the generalized second law holds for dynamical horizons. Finally, we show that the lightlike bousso bound and its spacelike counterpart can be unified as one bound."
This is a simple but very insightful paper. By unifying both components, you can just now work with just the lightsheet of causal diamonds.
Now, this is something from my guts. If we consider that bound true, we can start thinking about a universe as a duality between the union of the domain of RP3 projections of matter and fields, because now we can the spacelike component of the causal diamond, and one holographic screen, which is the union of the images of all RP3.
http://arxiv.org/abs/0807.4748
Diffeomorphism invariance in spherically symmetric loop quantum gravity
5 pages, invited paper for a special issue of Advanced Science Letters
"We study the issue of the recovery of diffeomorphism invariance in the recently introduced loop quantum gravity treatment of the exterior Schwarzschild space-time. Although the loop quantization agrees with the quantization in terms of metric variables in identifying the physical Hilbert space, we show that diffeomorphism invariance in space-time is recovered with certain limitations due to the use of holonomic variables in the loop treatment of the model. This resembles behaviors that are expected in the full theory."
http://arxiv.org/abs/0807.4874
Canonical Relativity and the Dimensionality of the World
Martin Bojowald
17 pages, 2 figures; Chapter in: Relativity and the Dimensionality of the World, Ed. V. Petkov (Springer, 2007), pp. 137-152
(Submitted on 30 Jul 2008)
"Different aspects of relativity, mainly in a canonical formulation, relevant for the question 'Is spacetime nothing more than a mathematical space (which describes the evolution in time of the ordinary three-dimensional world) or is it a mathematical model of a real four-dimensional world with time entirely given as the fourth dimension?' are presented. The availability as well as clarity of the arguments depend on which framework is being used, for which currently special relativity, general relativity and some schemes of quantum gravity are available. Canonical gravity provides means to analyze the field equations as well as observable quantities, the latter even in coordinate independent form. This allows a unique perspective on the question of dimensionality since the space-time manifold does not play a prominent role. After re-introducing a Minkowski background into the formalism, one can see how distinguished coordinates of special relativity arise, where also the nature of time is different from that in the general perspective. Just as it is of advantage to extend special to general relativity, general relativity itself has to be extended to some theory of quantum gravity. This suggests that a final answer has to await a thorough formulation and understanding of a fundamental theory of space-time. Nevertheless, we argue that current insights into quantum gravity do not change the picture of the role of time obtained from general relativity."
http://arxiv.org/abs/0807.4910
Gravitational dynamics in Bose Einstein condensates
Florian Girelli, Stefano Liberati, Lorenzo Sindoni
15 pages
"Analogue models for gravity intend to provide a framework where matter and gravity, as well as their intertwined dynamics, emerge from degrees of freedom that have a priori nothing to do with what we call gravity or matter. Bose Einstein condensates (BEC) are a natural example of analogue model since one can identify matter propagating on a (pseudo-Riemannian) metric with collective excitations above the condensate of atoms. However, until now, a description of the 'analogue gravitational dynamics' for such model was missing. We show here that in a BEC system with massive quasi-particles, the gravitational dynamics can be encoded in a modified (semi-classical) Poisson equation. In particular, gravity is of extreme short range (characterized by the healing length) and the cosmological constant appears from the non-condensed fraction of atoms in the quasi-particle vacuum. While some of these features make the analogue gravitational dynamics of our BEC system quite different from standard Newtonian gravity, we nonetheless show that it can be used to draw some interesting lessons about 'emergent gravity' scenarios."
http://arxiv.org/abs/0808.0025
A Note on B-observables in Ponzano-Regge 3d Quantum Gravity
Etera R. Livine, James P. Ryan
17 pages
(Submitted on 31 Jul 2008)
"We study the insertion and value of metric observables in the (discrete) path integral formulation of the Ponzano-Regge spinfoam model for 3d quantum gravity. In particular, we discuss the length spectrum and the relation between insertion of such B-observables and gauge fixing in the path integral."
http://arxiv.org/abs/0808.0190
Singularities in loop quantum cosmology
Thomas Cailleteau, Antonio Cardoso, Kevin Vandersloot, David Wands
5 pages, 3 figures
(Submitted on 1 Aug 2008)
"We show that simple scalar field models can give rise to curvature singularities in Loop Quantum Cosmology (LQC). We find singular solutions for spatially flat Friedmann-Robertson-Walker cosmologies with a canonical scalar field and a negative exponential potential, or with a phantom scalar field and a positive potential. While LQC avoids big bang or big rip type singularities, we find sudden singularities where the Hubble rate is bounded, but the Ricci curvature scalar diverges. We conclude that the effective equations of LQC are not in themselves sufficient to avoid the occurrence of singularities."
http://arxiv.org/abs/0808.0246
Categorified Symplectic Geometry and the Classical String
John C. Baez, Alexander E. Hoffnung, Christopher L. Rogers
28 pages
(Submitted on 2 Aug 2008)
"A Lie 2-algebra is a 'categorified' version of a Lie algebra: that is, a category equipped with structures analogous those of a Lie algebra, for which the usual laws hold up to isomorphism. In the classical mechanics of point particles, the phase space is often a symplectic manifold, and the Poisson bracket of functions on this space gives a Lie algebra of observables. Multisymplectic geometry describes an n-dimensional field theory using a phase space that is an 'n-plectic manifold': a finite-dimensional manifold equipped with a closed nondegenerate (n+1)-form. Here we consider the case n = 2. For any 2-plectic manifold, we construct a Lie 2-algebra of observables. We then explain how this Lie 2-algebra can be used to describe the dynamics of a classical bosonic string. Just as the presence of an electromagnetic field affects the symplectic structure for a charged point particle, the presence of a B field affects the 2-plectic structure for the string."
On 25 July Lee Smolin posted a revision of his December 2007 paper, containing new information worth noting. Thanks to MTd2 for alerting us to this.
http://arxiv.org/abs/0712.0977
The Plebanski action extended to a unification of gravity and Yang-Mills theory
Lee Smolin
12 pages, one figure
(Submitted on 6 Dec 2007 (v1), last revised 25 Jul 2008 (this version, v2))
"We study a unification of gravity with Yang-Mills fields based on a simple extension of the Plebanski action to a Lie group G which contains the local lorentz group. The Coleman-Mandula theorem is avoided because the theory has no global spacetime symmetry. This may be applied to Lisi's proposal of an E8 unified theory, giving a fully E8 invariant action. The extended form of the Plebanski action suggests a new class of spin foam models."
http://arxiv.org/abs/0808.0701
Effective theory for the cosmological generation of structure
Martin Bojowald, Aureliano Skirzewski
8 pages, 1 figure
(Submitted on 5 Aug 2008)
"The current understanding of structure formation in the early universe is mainly built on a magnification of quantum fluctuations in an initial vacuum state during an early phase of accelerated universe expansion. One usually describes this process by solving equations for a quantum state of matter on a given expanding background space-time, followed by decoherence arguments for the emergence of classical inhomogeneities from the quantum fluctuations. Here, we formulate the coupling of quantum matter fields to a dynamical gravitational background in an effective framework which allows the inclusion of back-reaction effects. It is shown how quantum fluctuations couple to classical inhomogeneities and can thus manage to generate cosmic structure in an evolving background. Several specific effects follow from a qualitative analysis of the back-reaction, including a likely reduction of the overall amplitude of power in the cosmic microwave background, the occurrence of small non-Gaussianities, and a possible suppression of power for odd modes on large scales without parity violation."
http://arxiv.org/abs/0808.0949
Critical behaviour in quantum gravitational collapse
Viqar Husain
8 pages, 3 figures
(Submitted on 7 Aug 2008)
"We study the gravitational collapse of an inhomogeneous scalar field with quantum gravity corrections associated with singularity avoidance. Numerical simulations indicate that there is critical behaviour at the onset of black hole formation as in the classical theory, but with the difference that black holes form with a mass gap."
http://arxiv.org/abs/0808.0990
Effective Scenario of Loop Quantum Cosmology
You Ding, Yongge Ma, Jinsong Yang
4 pages, 2 figures
"Semiclassical states in isotropic loop quantum cosmology are employed to show that the improved dynamics has the correct classical limit. The effective Hamiltonian for the quantum cosmological model with a massless scalar field is thus obtained, which incorporates also the next to leading order quantum corrections. The possibility that the higher order correction terms may lead to significant departure from the leading order effective scenario is revealed. If the semiclassicality of the model is maintained in the large scale limit, even k=0 Friedmann expanding universe will undergo a collapse in the future due to the quantum gravity effect. Thus the quantum bounce and collapse may contribute a cyclic universe in the new scenario."
http://arxiv.org/abs/0808.1081
The kinematic origin of the cosmological redshift
Emory F. Bunn, David W. Hogg
14 pages. Submitted to Am. J. Phys
"A common belief among cosmologists is that the cosmological redshift cannot be properly viewed as a Doppler shift (that is, as evidence for a recession velocity), but must instead be viewed in terms of the stretching of space. We argue that the most natural interpretation of the redshift is in fact as a Doppler shift, or rather as the accumulation of many infinitesimal Doppler shifts. The stretching-of-space interpretation obscures a central idea of relativity, namely that of coordinate freedom, specifically the idea that it is always valid to choose a coordinate system that is locally Minkowski. We show that, in any spacetime, an observed frequency shift can be interpreted either as a kinematic (Doppler) shift or a gravitational shift by imagining a family of observers along the photon's path. In the context of the expanding Universe, the kinematic interpretation corresponds to a family of comoving observers and hence seems to be the more natural one."
http://arxiv.org/abs/0808.1107
Semiclassical regime of Regge calculus and spin foams
Eugenio Bianchi, Alejandro Satz
30 pages
"Recent attempts to recover the graviton propagator from spin foam models involve the use of a boundary quantum state peaked on a classical geometry. The question arises whether beyond the case of a single simplex this suffices for peaking the interior geometry in a semiclassical configuration. In this paper we explore this issue in the context of quantum Regge calculus with a general triangulation. Via a stationary phase approximation, we show that the boundary state succeeds in peaking the interior in the appropriate configuration, and that boundary correlations can be computed order by order in an asymptotic expansion. Further, we show that if we replace at each simplex the exponential of the Regge action by its cosine -- as expected from the semiclassical limit of spin foam models -- then the contribution from the sign-reversed terms is suppressed in the semiclassical regime and the results match those of conventional Regge calculus."
http://arxiv.org/abs/0808.1223
Constraints and gauge transformations: Dirac's theorem is not always valid
Julian Barbour, Brendan Z. Foster
14 pages
(Submitted on 8 Aug 2008)
"A standard tenet of canonical quantum gravity is that evolution generated by a Hamiltonian constraint is just a gauge transformation on the phase space and therefore does not change the physical state. The basis for this belief is a theorem of Dirac that identifies primary first-class constraints as generators of physically irrelevant motions. We point out that certain assumptions on which Dirac based his argument do not hold for reparametrization invariant systems, and show that the primary Hamiltonian constraint of these systems does generate physical motion. We show explicitly how the argument fails for systems described by Jacobi's principle, which has a structure closely resembling that of general relativity. We defer discussion of general relativity and the implications for quantum gravity to a later paper."
Hongbao Zhang is at Beijing Normal, same place as Yongge Ma. We should watch the quantum gravity/cosmology group there. I have already noted several of their papers.
In this note Hongbao improves on Steven Weinberg's treatment of a very interesting problem---how does the expansion of the universe slow down massive particles? E.g. neutrinos originally produced "hot" in the early universe will have slowed down due to expansion.
Note on the thermal history of decoupled massive particles
Hongbao Zhang
JHEP style, 4 pages, to appear in CQG
(Submitted on 11 Aug 2008)
"This note provides an alternative approach to the momentum decay and thermal evolution of decoupled massive particles. Although the ingredients in our results have been addressed in Weinberg's Cosmology, the strategies employed here are simpler, and the results obtained here are more general."
==sample excerpt==
"As is well known, for the freely traveling massless particle like photon in an expanding
FLRW universe, the frequency or energy will vary inversely proportional to the scale
factor, which implies that the number density of massless particles still keeps its thermal
spectrum form with a redshifted effective temperature although these particles went
out of the thermal equilibrium into the free expansion as time passed. This is the
physical foundation for the cosmic microwave radiation background currently observed
by us. Now a natural question arises, namely, does the above fact also apply to the
massive particle? Not only does this question possesses a theoretical interest by itself,
but also acquires a practical implication in cosmology since neutrinos and antineutrinos
are believed to be massive. However, to my best knowledge, this issue has not been
addressed in literatures except in Weinberg’s cosmology book published recently[1].
The purpose of this note is to provide an alternative approach to this issue. The
strategies employed here are simpler, but the results obtained here are more general.
Notations and conventions follow Ref.[2]."
In case Yongge Ma's name is not familiar, a recent paper of his was noted in post #743, two posts back.
I'm told that next year's Loop or QG conference will be in Beijing. I should be watching the QG research output of people like Yongge Ma and Hongbao Zhang. Here are three researchers at Hunan Normal, whose paper has already been accepted for publication in Physical Review D. and their names are new to me. Hongwei Yu is the senior researcher.
http://arxiv.org/abs/0808.1382
Dynamics of interacting phantom scalar field dark energy in Loop Quantum Cosmology
Xiangyun Fu, Hongwei Yu, Puxun Wu
18 pages, 7 figures, to be published in PRD
(Submitted on 10 Aug 2008)
"We study the dynamics of a phantom scalar field dark energy interacting with dark matter in loop quantum cosmology (LQC). Two kinds of coupling of the form [tex]\alpha{\rho_m}{\dot\phi}[/tex] (case I) and [tex]3\beta H (\rho_\phi +\rho_m)[/tex] (case II) between the phantom energy and dark matter are examined with the potential for the phantom field taken to be exponential. For both kinds of interactions, we find that the future singularity appearing in the standard FRW cosmology can be avoided by loop quantum gravity effects. In case II, if the phantom field is initially rolling down the potential, the loop quantum effect has no influence on the cosmic late time evolution and the universe will accelerate forever with a constant energy ratio between the dark energy and dark matter."
http://arxiv.org/abs/0808.1971
Intertwiner dynamics in the flipped vertex
Emanuele Alesci, Eugenio Bianchi, Elena Magliaro, Claudio Perini
12 pages, 7 figures
(Submitted on 14 Aug 2008)
"We continue the semiclassical analysis, started in a previous paper, of the intertwiner sector of the flipped vertex spinfoam model. We use independently both a semi-analytical and a purely numerical approach, finding the correct behavior of wave packet propagation and physical expectation values. In the end, we show preliminary results about correlation functions."
brief mention
http://arxiv.org/abs/0808.1913
Transiting Exoplanets with JWST
S. Seager (MIT), D. Deming (NASA/GSFC), J. A. Valenti (STScI)
22 pages, 11 figures. In press in "Astrophysics in the Next Decade: JWST and Concurrent Facilities, Astrophysics & Space Science Library, Thronson, H. A., Tielens, A., Stiavelli, M., eds., Springer: Dordrecht (2008)."
(Submitted on 13 Aug 2008)
http://arxiv.org/abs/0808.2069"
Action and Hamiltonians in higher dimensional general relativity: First order framework
Abhay Ashtekar, David Sloan
12 pages, no figures
(Submitted on 18 Aug 08)
We consider d>4 dimensional space-times which are asymptotically flat at spatial infinity and show that, in the first order framework, the action principle is well-defined without the need of infinite counter terms. It naturally leads to a covariant phase space in which the Hamiltonians generating asymptotic symmetries provide the total energy-momentum and angular momentum of the isolated system. This work runs parallel to our previous analysis in four dimensions. The higher dimensional analysis is in fact simpler because of absence of logarithmic and super translation ambiguities.
http://arxiv.org/abs/0808.2259
Time delay of light signals in an energy-dependent spacetime metric
A. F. Grillo, E. Luzio, F. Mendez
5 pages. Physical Review D77, 104033 (2008)
(Submitted on 16 Aug 2008)
"In this note we review the problem of time delay of photons propagating in a spacetime with a metric that explicitly depends on the energy of the particles (Gravity-Rainbow approach). We show that corrections due to this approach -- which is closely related to DSR proposal -- produce for small redshifts (z<<1) smaller time delays than in the generic Lorentz Invariance Violating case."
http://arxiv.org/abs/0808.3124
Planck Scale Cosmology in Resummed Quantum Gravity
B.F.L. Ward (Department of Physics, Baylor University, Waco, TX, USA)
7 pages
(Submitted on 22 Aug 2008)
"We show that, by using resummation techniques based on the extension of the methods of Yennie, Frautschi and Suura to Feynman's formulation of Einstein's theory, we get quantum field theoretic predictions for the UV fixed-point values of the dimensionless gravitational and cosmological constants. Connections to the phenomenological asymptotic safety analysis of Planck scale cosmology by Bonanno and Reuter are discussed."
Asymptotic safety papers cited by Reuter et al., Percacci et al.
Expectation mentioned of possible observational test. Running (Newton and cosmological) G and Lambda constants. UV limit of Lambda derived.
Conclusions mention a followup paper. Bennie Ward has over 300 papers at Spires going back to around 1973. Seems to be new arrival in asymptotic safety-related QG.
http://arxiv.org/abs/0808.3505
A note on DSR
Carlo Rovelli
This is a note circulated privately for a while. 5 pages, 2 figures
(Submitted on 26 Aug 2008)
"I study the physical meaning of Doubly Special Relativity (DSR) and argue that DSR can be physically relevant in a certain large distance limit. I present a direct physical interpretation of the 5-dimensional Girelli-Livine DSR formalism, by deriving it explicitly from a concrete physical effect: the gravitational time contraction and its effect on the dynamics of massive point particles. I give a physical interpretation to the corresponding 5d spacetime. I also present some speculations on the interpretation of the corresponding SO(4,1) transformations."
http://arxiv.org/abs/0808.3482
Dynamics of interacting dark energy model in Einstein and Loop Quantum Cosmology
Songbai Chen, Bin Wang, Jiliang Jing
15 pages, 4 figures
"We investigate the background dynamics when dark energy is coupled to dark matter in the universe described by Einstein cosmology and Loop Quantum Cosmology. We introduce a new general form of dark sector coupling, which presents us a more complicated dynamical phase space. Differences in the phase space in obtaining the accelerated scaling attractor in Einstein cosmology and Loop Quantum Cosmology are disclosed."
http://arxiv.org/abs/0808.3765
Could deformed special relativity naturally arise from the semiclassical limit of quantum gravity?
Lee Smolin
12 pages
(Submitted on 27 Aug 2008)
"A argument is described for how deformed or doubly special relativity may arise in the semiclassical limit of a quantum theory of gravity. We consider a generic quantum theory of gravity coupled to matter, from which we use only the assumption that a Hamiltonian constraint is imposed. We study circumstances in which Lambda, G and hbar all may be separately neglected, but there may arise terms in the ratio of particle energies to the Planck mass which are small but measurable. Such cases include probes of an energy dependent speed of light such as are possible in experiments such as MAGIC and GLAST. We show that in such cases the leading order effect of quantum gravity will, if certain scaling relations are satisfied, be to deform the metric in the effective Hamiltonian of the matter quantum field theory by terms linear in energies. As the Hamiltonian constraint has been imposed there can be no preferred time coordinate or frame of reference, hence this is a modification rather than a breaking of special relativity."
http://arxiv.org/abs/0808.3725
New Positron Spectral Features from Supersymmetric Dark Matter - a Way to Explain the PAMELA Data?
Lars Bergstrom, Torsten Bringmann, Joakim Edsjo
6 pages, 4 figures
"The space-borne antimatter experiment PAMELA has recently reported a surprising rise in the positron to electron ratio at high energies. It has also recently been found that electromagnetic radiative corrections in some cases may boost the gamma-ray yield from supersymmetric dark matter annihilations in the galactic halo by up to three or four orders of magnitude, providing distinct spectral signatures for indirect dark matter searches to look for. Here, we investigate whether the same type of corrections can also lead to sizeable enhancements in the positron yield. We find that this is indeed the case, albeit for a smaller region of parameter space than for gamma rays; selecting models with a small mass difference between the neutralino and sleptons, like in the stau coannihilation region in mSUGRA, the effect becomes more pronounced. The resulting, rather hard positron spectrum with a relatively sharp cutoff may potentially fit the rising positron ratio measured by the PAMELA satellite. To do so, however, as seems also to be the case for most other dark matter models, very large 'boost factors' have to be invoked that are not expected in current models of halo structure. If the predicted cutoff would also be confirmed by later PAMELA data or upcoming experiments, one could either assume non-thermal production in the early universe or non-standard halo formation to explain such a spectral feature as an effect of dark matter annihilation. At the end of the paper, we briefly comment on the impact of radiative corrections on other annihilation channels, in particular antiprotons and neutrinos."
http://arxiv.org/abs/0808.4056
Black hole entropy for the general area spectrum
Tomo Tanaka, Takashi Tamaki
5 pages
(Submitted on 29 Aug 2008)
"We consider the possibility that the horizon area is expressed by the general area spectrum in loop quantum gravity and calculate the black hole entropy by counting the degrees of freedom in spin-network states related to its area. Although the general area spectrum has a complex expression, we succeeded in obtaining the result that the black hole entropy is proportional to its area as in previous works where the simplified area formula has been used. This gives new values for the Barbero-Immirzi parameter ([tex]\gamma[/tex] =0.5802... or 0.7847...) which are larger than that of previous works."
both of the authors are new to me.
http://arxiv.org/abs/0809.0304
Towards a spin foam model description of black hole entropy
J.Manuel Garcia-Islas
5 pages, 1 figure
(Submitted on 1 Sep 2008)
"We propose a way to describe the origin of black hole entropy in the spin foam models of quantum gravity. This stimulates a new way to study the relation of spin foam models and loop quantum gravity."
http://arxiv.org/abs/0809.0469
Dark spinors with torsion in cosmology
Christian G. Boehmer, James Burnett
7 pages, 3 figures
(Submitted on 2 Sep 2008)
"We solve one of the open problems in Einstein-Cartan theory, namely we find a natural matter source whose spin angular momentum tensor is compatible with the cosmological principle. We analyze the resulting evolution equations and find that an epoch of accelerated expansion is an attractor. The torsion field quickly decays in that period. Our results are interpreted in the context of the standard model of cosmology."
Christian Boehmer has already co-authored in loop cosmology. Although this particular paper of his is formally classical, I think it likely to contribute to research in quantum cosmology, possible causes of inflation, and the dark energy effect.
http://arxiv.org/abs/0804.0616
Dark spinor inflation -- theory primer and dynamics
13 pages Phys. Rev. D 77 (2008) 123535
(Submitted on 3 Apr 2008)
"Inflation driven by a single dark spinor field is discussed. We define the notion of a dark spinor field and derive the cosmological field equations for such a matter source. The conditions for inflation are determined and an exactly solvable model is presented. We find the power spectrum of the quantum fluctuation of this field and compare the results with scalar field inflation."
http://arxiv.org/abs/0809.2022
Cosmology without inflation
Patrick Peter, Nelson Pinto-Neto
8 pages, Phys. Rev. D 78, 063506 (2008)
(Submitted on 11 Sep 2008)
"We propose a new cosmological paradigm in which our observed expanding phase is originated from an initially large contracting Universe that subsequently experienced a bounce. This category of models, being geodesically complete, is non-singular and horizon-free, and can be made to prevent any relevant scale to ever have been smaller than the Planck length. In this scenario, one can find new ways to solve the standard cosmological puzzles. One can also obtain scale invariant spectra for both scalar and tensor perturbations: this will be the case, for instance, if the contracting Universe is dust-dominated at the time at which large wavelength perturbations get larger than the curvature scale. We present a particular example based on a dust fluid classically contracting model, where a bounce occurs due to quantum effects, in which these features are explicit."
Freidel-Conrady on semiclassical limit
http://arxiv.org/abs/0809.2280
On the semiclassical limit of 4d spin foam models
Florian Conrady, Laurent Freidel (Perimeter Inst. Theor. Phys.)
32 pages, 5 figures
(Submitted on 15 Sep 2008)
"We study the semiclassical properties of the Riemannian spin foam models with Immirzi parameter that are constructed via coherent states. We show that in the semiclassical limit the quantum spin foam amplitudes of an arbitrary triangulation are exponentially suppressed, if the face spins do not correspond to a discrete geometry. When they do arise from a geometry, the amplitudes reduce to the exponential of i times the Regge action. Remarkably, the dependence on the Immirzi parameter disappears in this limit."
http://arxiv.org/abs/0809.2590
Physical time and other conceptual issues of QG on the example of LQC
Wojciech Kaminski, Jerzy Lewandowski, Tomasz Pawlowski
18 pages, 1 figure
"Several conceptual aspects of quantum gravity are studied on the example of the homogeneous isotropic LQC model. In particular: (i) The relativistic time of the co-moving observers is showed to be a quantum operator and a quantum spacetime metric tensor operator is derived. (ii) Solutions of the quantum scalar constraint for two different choices of the lapse function are compared and contrasted. (iii) The mechanism of the singularity avoidance is analyzed via detailed studies of an energy density operator. (iv) The relation between the kinematical and the physical quantum geometry is discussed on the level of relation between observables."
http://arxiv.org/abs/0809.2469
Multi-fluid potential in the loop cosmology
Jakub Mielczarek
4 pages, 5 figures
"The scalar field can behaves like a fluid with equation of state [tex]p_{\phi}=w\rho_{\phi}[/tex], where [tex]w \in [-1,1][/tex]. In this letter we derive a class of the scalar field potentials for which w= const. Scalar field with such a potential can mimic ordinary matter, radiation, cosmic strings etc. We perform our calculations in the framework of the loop cosmology with a holonomy corrections. We solve the model analytically for the whole parameter space. Subsequently, we perform similar consideration for the model with a phantom field (w<-1). We show that scalar field is monotonic function in both cases. This indicate that it can be treated as a well defined internal time for these models."
Quaternion-Loop Quantum Gravity
http://arxiv.org/abs/0809.2916"
M. D. Maia, S. S e Almeida Silva, F. S. Carvalho
Comments: 6 pages, latex, no figures
We present a simple realization of loop quantum gravity in terms of quaternion operators acting on the spinor space of the triad holonomy group. We find that the Riemannian curvature of the 3-dimensional hypersurfaces in space-time is induced by the SU(2) gauge potential, but it is constructed differently from the usual gauge curvature. Therefore, quaternion-loop quantum gravity is not a gauge theory of gravitation of the triad holonomy group, but is provides a natural justification for quaternion quantum gravity.
Evaluation of new spin foam vertex amplitudes
http://arxiv.org/abs/00809.3190"
Igor Khavkine
Comments: 19 pages, 4 figures, amsrefs
A new numerical evaluation algorithm is proposed for the new spin foam vertex amplitudes proposed by Engle, Pereira & Rovelli and Freidel & Krasnov. The algorithm is applied to compute the high spin behavior of the new vertex amplitudes. Their asymptotics exhibit non-oscillatory, power-law decay, similar to that of the Barrett-Crane model, but with different exponents.
