Maclaurin formula: finding a delta for a given error
11 replies · 3K views
Telemachus
Approximate the function [tex]f(x)=\sin(x)[/tex] using the corresponding Maclaurin polynomial: [tex]P_5(x)[/tex], in a bound [tex]\epsilon(0,\delta)[/tex]. Determine a value of [tex]\delta>0[/tex], so that the rest [tex]R_5(x)[/tex] verifies [tex]|R_5(x)|<0.0005[/tex] for all [tex]x\in{\epsilon(0,\delta)}[/tex]
Well, the first thing that puzzles me a bit is that the order for [tex]P_5[/tex] and [tex]R_5[/tex] is the same. I assume that it is a mistake, and that the polynomial must be [tex]P_4[/tex], or the rest [tex]R_6[/tex]. I have chosen to leave the degree of the polynomial as it was and turn up one grade to the rest.
So I have to find a delta for which any value within the environment [tex](0,\delta)[/tex] is less than the error 0.0005
So I did:
[tex]R_6(x)=|\displaystyle\frac{\sin(\alpha)x^6}{6!}|<0.0005[/tex] [tex]0<\alpha<x[/tex]
So I must find x:
[tex]R_6(x)=|\sin(\alpha)x^6|<0.36[/tex] [tex]0<\alpha<x[/tex]
I must find x that satisfies the equation: [tex]\sin(x)x^6<0.36[/tex]
I don't know how to go ahead.
Bye there.
I think you're just getting confused by the notation. The usual notation is
[tex]R_n(x) = f(x)-P_n(x)[/tex]
The remainder term turns out to depend on xn+1 and f(n+1)(x).
So I did:
So I must find x:
Bye there.
Hint: Use the fact that x ≥ sin x when x ≥ 0.
I don't get it. I know that 1≥sin(x) how should I use the fact you mentioned? I wouldn't noted it if you weren't.
Thanks vela.
The fact that x ≥ sin x for x ≥ 0 is one of those things you pick up along the way, typically when you do a problem like this one.
You're trying to solve for x, right? And the difficulty is that you can't solve an equation of the form xn sin x = c. So you use the usual approach. Instead of solving the equation exactly, you look for an upper bound that you can solve that gives you a good estimate. In this case, you know that x6 sin x ≤ x7.
Thanks man!
One doubt. I was thinking that as the sine is always less than one I could use x⁶ as an upper bound too. Right?
Telemachus said:
Thanks man!
What does this say - x⁶ ?
Telemachus said:
Thanks man!
Yes, you can. So what is the difference between the two choices? Why would you choose one over the other?
sin(x) = 1 for x = pi/2 + 2k*pi, k an integer.
What is x⁶? I can't read the exponent.
Sorry, I was studying :P
x⁶ is [tex]x^6[/tex]
I think I would choose [tex]x^6[/tex] cause its a better approximation than [tex]x^7[/tex], so I got [tex]|x<\sqrt[6]{\frac{9}{25}}[/tex]
Edit: Ok, I've seen that I was wrong, and that [tex]x^7[/tex] is a better approximation. But now I have more doubts, damn. For this: x ≥ sin x, or even using x^6 ≥ x^6 sin x, couldn't it happen that using that approximation I would get outside the boundary I was looking for? In this case I've noted that it works, but in general I would like to know what could happens. I mean, while using the substitution it could happens that the new value could be bigger than the error I was looking for, right? cause, I know that [tex]x^7\geq{x^6 sin x}[/tex] and so [tex]x^8\geq{x^6 sin x}[/tex] it is, and even for any n>6 [tex]x^n\geq{x^6}[/tex] right?
Mmm ok, I am wrong for values of x, such that [tex]x\leq{1}[/tex]. I've tried with x^8 and it seems to work too, and its a better approximation for the boundary I am looking for.
http://www.wolframalpha.com/input/?i=x^6+sin(x)+=+9/25
From here I get x ~~ 0.8807530939284029...
And http://www.wolframalpha.com/input/?i=(9/25)^(1/8)
0.88011173679339339727
Nope. As long as your steps are reversible, which they usually are when you're doing these algebraic manipulations, you can start with the condition you found for x and deduce that the error will be within the given bound.
Thanks vela, this is really helpful and very useful.
