What changes when a body undergoes acceleration?
becsy said:
I was reading through some of the forums and something popped into my head. "Mass increases with acceleration" so does that mean that is decreases with decceleration? i would think it would but I am not to sure. If i got in an elevator would my mass change? and if it does how would it change. its all confusing.
No wonder you are confused! It is completely incorrect to say that "mass increases with acceleration". What you probably read somewhere (on this forum? I hope not!) was the claim that "relativistic mass increases with velocity". This should be restated as "relativistic kinetic energy increases with velocity".
The
mass of an object is a
kinematically invariant property; that is, it does not change simply due to the motion of the object.
Specifically, the expression given by Einstein for the energy (mass plus kinetic energy) of an object in terms of its mass and its velocity is:
E = m \, \cosh \, \operatorname{arctanh} \, v = \frac{m}{\sqrt{1-v^2}} = m \, \left( 1 + \frac{v^2}{2} + \frac{3 \, v^4}{8} + \dots \right)
where m is the mass (sometimes misleadingly called "rest mass"), m \, v^2/2 is the Newtonian kinetic energy, and the remaining terms are relativistic corrections to the Newtonian kinetic energy. The effect of these additional terms is to ensure that as the velocity approaches unity (the speed of light in relativistic units in which we measure both time and distance in meters), the kinetic energy of the object diverges.
Having said this, I should probably add that the corresponding expression for the magnitude of the relativistic momentum is
\| \vec{p} \| = m \, \sinh \, \operatorname{arctanh} \, v = \frac{m \, v}{\sqrt{1-v^2}} = m \, \left( v + \frac{v^3}{2} + \frac{3 \, v^5}{8} + \dots \right)
where m \, v is the Newtonian expression for the momentum, and the remaining terms are relativistic corrections, which again have the effect of ensuring that as velocity approaches unity, the magnitude of the momentum diverges. Note that while mass is a kinematicaly invariant quantity, the kinetic energy and momentum are both observer-dependent quantities.
(The qualifier "kinematical" refers to the fact that, in general relativity, if you heat an object, you are adding energy to the system, so that its effective gravitational mass increases very slightly. This effect is much to small to affect any cooking in your kitchen, however!)
Unfortunately, I should warn students that several current threads on this board concern claims by a dissident which are, to say the least, highly idiosyncratic, and in my view, quite unhelpful to students trying to grasp the fundamentals of relativistic physics. A book I highly recommend is Taylor and Wheeler,
Spacetime Physics, First Edition (the second edition unfortunately dropped discussion of an invaluable concept, the "rapidity" of a "boost", which is the analog of the angle of a rotation). This widely used and excellent textbook represents mainstream pedagogy in teaching the basic ideas of relativistic physics, and there are many good reasons for studying such a textbook rather than a dissident approach.
