Mass rotating in horizontal circle at two velocities
17 replies · 4K views · last reply
mpittma1
A 1.5 kg mass tied to the roof rotates with constant speed in a horizontal
circle. The string makes an angle of 30 deg to the vertical.
a) determine the velocity , the centripetal acceleration and the centripetal
force on the mass.
b) determine the tension in the string.
c) say the mass is given a push so that now the mass rotates with a constant
velocity of 9.4 m/s . Determine the angle the string makes with the vertical
, the centripetal force on the mass and the tension in the string.
∑Fradial = TsinΘ = mv2/R
∑Fy = TcosΘ - mg = 0
To solve part a:
First I found my R by,
R = LsinΘ = 1.5sin30° = .75m
Second my T by,
T= mg/cosΘ = 1.5*9.8/cos30° = 16.97 N
Now I find my velocity by,
V= sqrt((R*T*sinΘ)/m)) = sqrt((.75*16.97*sin30°)/1.5) = 2.06 m/s
the centripetal acceleration,
v2/R = a
a = TsinΘ/m = 16.97*sin30°/1.5 = 5.66 m/s2
for part b I already found my tension to be 17N.
Part C is where I am having trouble, how can i find the angle Θ with the new constant velocity if I am not given a radius or tension?
Hello, mpittma1. Welcome to PF!
Note that you have 3 "unkowns": θ, T, and R. But you also have 3 equations: your two "Relevant equations" and your equation for R in terms of L and sinθ.
Can you see how to do the algebra to get to an equation where the only unknown is θ?
Hey TSny,
So my three equations are:
R = LsinΘ (1)
TcosΘ - mg =0 (2)
TsinΘ = mv2/R (3)
I see how you could plug equation 1 into equation 2 and come up with
TsinΘ = mv2/LsinΘ which is closer because I have my m, v, and L but I am still not seeing how to get rid of the T by using equation 2.
Use (2) to find T in terms of θ. [EDIT: Or divide (3) by (2) after rearranging (2)]
So I am coming up with:
TanΘ = v2/LsinΘg
after dividing eqn 3 by eqn 2 and plugging in eqn 1 for R.
After doing some more algebra I come up with tanΘsinΘ = v2/Lg
something doesn't seem right there though... how could i solve for tanΘsinΘ?
Looks good so far! Can you express the left side of the equation solely in terms of sinθ?
well I could easily express the left side as sin2Θ/cosΘ
im not seeing how to express it solely as sinΘ though
Can you think of a trig identity that relates sinΘ and cosθ?
so here's what I am doing:
sin2Θ/cosΘ → using a half angle formula (1-cos2Θ)/2 * 1/cosΘ →
(1-cos2Θ)/2cosΘ
my eqn thus far is (1-cos2Θ)/cosΘ = 2v2/Lg
how could you simplify the left side further?
I'm not sure the half-angle formula will help. Can you make use of sin2Θ + cos2θ = 1?
[Edit: I said earlier to express everything in terms of sinθ, which will work. But it might be a little easier to express sin2Θ/cosΘ in terms of cosθ.]
[Edit: I said earlier to express everything in terms of sinθ, which will work. But it might be a little easier to express everything in terms of cosθ.]
I was trying to find a way to get a +cos2Θ but its just not there
So, use the trig identity to express sin2θ in terms of cos2θ.
(1-cos2Θ)/cosΘ
or secΘ-cosΘ so I am almost there
mpittma1 said:
(1-cos2Θ)/cosΘ
Good
I don't recommend writing it this way. Use (1-cos2Θ)/cosΘ for tanθsinθ in your equation from post #5 and see if you can proceed from there.
TSny said:
Good
After plugging in my values for v L and g i get:
(1-cos2Θ)/cosΘ = 6.011
any suggestions any solving for Θ?
Let x = cosθ and write your equation in terms of x. Can you solve for x?
ok so what i did:
let x = cosΘ
so, 1-x2/x = 6.011
1-x2 = 6.011x
0 = x2 + 6.011x -1
then after solving for the roots of x
x = -6.173 and .162
plugging x = .162 into x = cosΘ
gives me Θ = 80.7° which is the correct answer!
thank you for all your help!
