Mass whirling on table pulled by string through center
35 replies · 8K views
PhizKid
Energy
So I'm not exactly sure what this question even wants considering the statement is true by the work - energy theorem. Does it want me to show it explicitly for this case? If so, then, since there are no forces present along [itex]\hat{\theta }[/itex], [itex]W = m\int_{a}^{b}<\ddot{r} - r\dot{\theta }^{2}, 0>\cdot <dr,d\theta > = m\int_{l_{1}}^{l_{2}}\ddot{r} - r\dot{\theta }^{2}dr[/itex] so [itex]W = \frac{1}{2}m\dot{r}^{2}|_{l_1}^{l_2} - \int_{l_{1}}^{l_{2}}mr\dot{\theta }^{2}dr[/itex]. The change in kinetic energy is given by [itex]\Delta T = \frac{1}{2}m\dot{r}^{2}|_{l_1}^{l_2} + \frac{1}{2}mr^{2}\dot{\theta }^{2}|_{l_1}^{l_2}[/itex]. If we choose a coordinate system centered around the hole, then the position vector to the mass is parallel to the net force so the torque is identically zero thus angular momentum is conserved so [itex]r^{2}\dot{\theta }[/itex] is a constant of motion which implies [itex]r^{4}\dot{\theta }^{2}[/itex] is also a constant so [itex]-\int_{l_1}^{l_2}mr\dot{\theta }^{2}dr = -\int_{l_1}^{l_2}m\frac{r^{4}\dot{\theta }^{2}}{r^{3}}dr =-mr^{4}\dot{\theta }^{2}\int_{l_1}^{l_2}\frac{dr}{r^{3}} = \frac{1}{2}mr^{2}\dot{\theta }^{2}|_{l_1}^{l_2}[/itex] so [itex]W = \Delta T[/itex] but I'm not sure if my solution is valid and I'm also not satisfied with this long winded solution, if it is correct, because the chapter this problem is from was before angular momentum was introduced so there must be a solution that doesn't use the concept but I can't think of it so if anyone could guide me towards that it would be great. Thanks!
"Slowly" means that you can ignore the radial velocity and the acceleration related to the change in the radial velocity. Under this assumption, what is the acceleration of the mass?
Why can we assume all those things? Can you give a mathematically precise reason? Seems like we are assuming a lot just from the word slowly. Anyways if the radial acceleration is indeed small then [itex]\ddot{r} << r\dot{\theta }^{2}[/itex] so that [itex]a_{r} = -r\dot{\theta }^{2} + O(\frac{\ddot{r}}{r\dot{\theta }^{2}})[/itex]. Also, could you please tell me if my solution above was correct or not? Thanks
There is no "mathematically precise" reason, it is a physical simplification.
Your derivation does not take the Coriolis effect into account, which is precisely what the "slowly" simplification eliminates.
I don't see why we care about the Coriolis forces. They show up in the angular component of the force which is zero here so it doesn't even show up in the line integral for work due to the dot product. Also I am really not convinced about the whole "slowly" approximation without being able to see how to express that mathematically. Otherwise it seems like hand waving to me.
If you know that angular momentum is conserved, then you'd also know that the final energy state of the whirling mass is independent of the path. The net work related to radial acceleration and deceleration would be zero, since the whirling mass begins and ends with zero radial speed, and its angular momentum is conserved.
So it seems that for this problem, the "slowly" pulled in means you ignore the work related to radial acceleration and deceleration, rather than relying on knowledge of conservation of angular momentum, or in effect, deriving the equivalent.
But I don't get where my solution went wrong. I don't see how Coriolis forces would factor into the line integral the way I did it. The dot product takes care of that. Thanks for the response rcgldr!
In your derivation of work, the acceleration vector is constant in direction. This is only possible when the vector is taken in a co-rotating frame. In a co-rotating frame, you have to take the Coriolis effect into account - unless you can assume that the velocity is "slow".
From a purely mathematical point of view, a lot of physics may seem like hand waving. Which is OK, because physics is not mathematics. Learn the difference.
If you can't quantify a result mathematically, approximation or not, then why should I accept it as fact? You're literally translating a simple phrase in English to a powerful physical assumption. There's a difference between being given an explicit approximation and taking something out of that and loosely interpreting an english word to mathematical results without justifying it mathematically. Anyways, can you point out where in the work integral it was assumed the direction of the radial acceleration was constant? Do you mean to say the direction of the radial acceleration is not the same as the direction of the radial displacement? Thanks.
The problem asks the work of the person who pulls the string W=∫Fdl. You calculated the work of the string on the mass, which is the same now, I did not find any error in your derivation. You only did not take the condition "pulling slowly" into account.
"Pulling slowly" means that you pull with a force which is almost equal to the centripetal force, it can be taken equal to it. So F=mrω2. That means a constant radial speed, so the radial speed does not contribute to the change of KE.
Conservation of angular momentum is necessary to take into account.
ehild
The acceleration vector you had was ## (\ddot{r} - r\theta^2, 0) ##. Its direction is constant. Which is only possible in a co-rotating frame. In which case there must be a Coriolis term.
You are free to debate whether "slow" means "absence of radial velocity", but then you must take it into account.
Hi ehild. Thanks for the response. So are you saying if I take into account the radial acceleration not contributing any work then I will get the same answer I have now except the change in .5m(dr/dt)^2 from l1 to l2 terms will go away in the work expression? Why will the term go away in the kinetic energy expression where radial velocity shows up without reference to the radial acceleration? Also, if I don't take the approximation into account, is my final expression/ solution for work and for kinetic energy still correct? I just don't get where any reference to Coriolis forces come up. Thanks!
Your derivation is correct proving that the work done on the mass is equal to the change of kinetic energy in general, but the problem asks to derive it when the radial velocity is "slow" ; that excludes the term connected to the change of the radial velocity from the KE. And I think the problem wants you to present the result in the usual form of the KE: 1/2 mv2,so expand the last expression and give the work in terms of the initial and final speeds.
The Coriolis force is irrelevant here.
Centrifugal force and Coriolis force are inertial forces, fictitious forces, experienced in a rotating frame of reference. You observe the motion from a rest frame.
ehild
He may be observing it from a rest frame, but his derivation is an co-rotating frame.
No. Why do you think so?
ehild
## (\ddot{r} - r\theta^2, 0) ## is a vector. Vectors are invariant. You can't have one and the same vector have constant and non-constant direction just because you change coordinates.
A coordinate system is not the same as the frame of reference.
Describing a motion with a polar coordinate system, there are both radial and azimuthal components of acceleration. The azimuthal component includes both the "Coriolis term" and the angular acceleration. As the string can exert only radial force, the azimuthal component of acceleration is zero. That does not mean that the acceleration or the force has constant direction as you said in #11. It means that the force is "central", acts along the radius, and the acceleration is radial.
ehild
Which is way a vector is either rotating or not, independently of the coordinate system.
The expression given for the acceleration vector implies its direction is constant. Which should not be the case for a rotating mass in an inertial frame.
Consequently, the expression is an non-inertial frame.
I did not say that. PhysKid's expression for the acceleration vector implies that. Which is so obvious that I do not even understand why we are having this discussion.
The article that you linked has the correct expression for acceleration at the end. It should just be taken from there.
PhizKid said that the azimuthal component of acceleration was zero, that was, why he did not include that term in the integral. ehild
You said that the azimuthal component of acceleration must be zero as the force is central. The azimuthal component is [itex]a_{\theta}=2\dot {r} \dot {\theta}+r \ddot {\theta}=\frac{1}{r} \frac{d}{dt}\left(r^2\dot {\theta}\right)=0[/itex],so [itex]\frac{d}{dt} \left(r^2\dot {\theta}\right)=0[/itex]→ [itex]r^2\dot {\theta}=const[/itex] which you can know without learning about angular momentum. (You only happen to derive its conservation in central force field :) )
ehild
Which has no physical basis, unless one assumes that the motion is planar and that the rope is a straight line. And why should that be assumed? The whole point of this discussion is that PhizKid believes that "slowly" has no physical significance, while in fact that's why those assumptions could be made.
The mass moves on a plane, pulled by a string. A table is usually plane and a stressed massless string is straight.
ehild
You are missing my point entirely. PhizKid's derivation has flaws. One of those is using the rotating frame of reference and assuming that tangential acceleration is absent there. This assumption must either be proved or reduced to another assumption, such as "pulling slowly".
"Pulling slowly" means that the motion is circular and uniform at any instant, which automatically proves the assumption. Whether this is the case with any other kind of pulling must be proved.
I don't see any vector notation in PhizKid posts. ΔT represents the integral for tension in the string from radius L1 to L2 (force x distance). In his equations, the absolute direction of the tension doesn't matter, only that it's radial.
Since angular momentum is conserved, than at any time when the radial speed is zero (such as the initial and final states), the tension is proportional to (1/r)^3. This is shown in posts #3 and #7 of the previous thread linked to below. The comment about no net work related to radial acceleration (path doesn't matter) wasn't mentioned in that previous thread, so I've quoted my previous post from this thread that explains that aspect:
https://www.physicsforums.com/showthread.php?t=328121
The very first equation, the work integral, is a scalar product of two vectors.
It is not assumed that the tangential acceleration is absent. You mix it with the azimuthal acceleration in the polar coordinate system, which is zero, as the force is radial.
The tangential and the centripetal acceleration are defined in the instantaneous system of coordinates, moving together with the particle along its trajectory. The velocity points in the direction tangent to the trajectory, and the acceleration can have both tangential and normal components. The tangential acceleration is equal to the time derivative of the speed. The normal (centripetal) component of acceleration is v2 /R where R is the curvature of the trajectory.
In this problem, the trajectory is a spiral. The acceleration has components both tangential and normal to the path .
In polar coordinates, the velocity has both radial and azimuthal components, but the acceleration has only radial component, as the force is radial. ehild
Oh gosh I'm so confused. I don't know if my solution is right or not. I never took into account the slow approximation so does that void it's correctness? Or does applying the slow approximation simply get rid of the radial velocity terms in my final solution? I'm not seeing any reason to introduce Coriolis forces into this and I have no idea where voko got the idea that I was working in a frame co - rotating with the mass so that its trajectory in such a frame would be purely radial (this is what would happen in such a frame correct? If someone could answer that even though its unrelated =D). Thanks a ton!
