Math tricks from various areas of mathematics
  • Level: Undergrad
  • Thread starter Thread starter agentredlum
282 replies · 56K views
ArcanaNoir said:
It would be nicer if it meant you could work with positive numbers after putting actual values for a, b, and c more often, but if b and c are positive in ordinary set up then they become negative in the regular way and in agentredlum's formula. if they're negative, both formulae make for positive calculations. So the only value is in ease of memorizing the formula. And maybe it's value is lost when you consider the usefulness of setting equations equal to zero and the methods of factoring, roots, critical points, and inflection points, etc. Conceptually everything is tied to zero.
I don't see why so many professors had trouble accepting this modification, it only took me one real example to see the nature of it. I think real examples are sometimes neglected since mathematicians' purpose seems mostly to prove things. Sometimes a proof obscures something that's obvious.
It's cool though. Super cool.
Thank you for the response, thank you for the support.:smile:
I think you got it! Coefficients can come with different signs so one formula is not superior to the other in that sense. Thank you for pointing out this subtle point.:smile:
Let me add that FORMS of the equation can come in 4 ways, here's what i mean...
Form1: ax^2 + bx + c = 0
Form2: ax^2 + bx = c
Form3: ax^2 + c = bx
Form4: ax^2 = bx + c
Every single one of these forms, by itself, describes the same infinite set of 2nd degree equations applicable to the quadratic formula so no form is superior to another in terms of APPLICABILITY.
However, form1 is INFERIOR to the other 3 cause it uses more, un-necessary, symbols. Zero is an extra symbol and there is an extra addition.
So yes my version using form4 is easier to memorize as you point out but also easier to write down cause you use less ink, less chalk, less keystrokes, etc.
Now, if you use form 1 with more symbols in the form and more symbols in the quadratic formula then you are performing more operations than if you use form4 which does NOT require you to set = 0 and has a simpler formula.
To put it another way, you will run out of ink faster than me, or run out of memory faster than me. So perhaps it might be worthwhile to use my derivation?:smile:
micromass said:
That's the point. It's not a different way of thinking. It's the exact same formula and the old way of thinking. There's nothing novel going on here.
So you dismiss it?
The old way of thinking is 'you have to set it = 0 to find the roots'
The new way of thinking is 'the old way of thinking is a myth'
This point of mine got lost on you in the midst of trying to trivialize my result.
Thank you for your comment.
Mark44 said:
Robert1986, micromass, and gb7nash, those were my thoughts, too.
If you start with your quadratic as ax2 = bx + c
then b and c will have the opposite signs as in the usual form of the Quadratic Formula, so the revised form becomes
[tex]\frac{b \pm \sqrt{b^2 + 4ac}}{2a}[/tex]
The -b of the original becomes b, and the -4ac of the original becomes + 4ac. IMO, not that big of an improvement.
And the improvement only exists in writing this new quadratic formula, and it is only if you have some hatred of minus signs. In actual practice, it works out the exact same way. I'm glad I'm not the only one who thinks that this "trick" is a complete waste of time.
agentredlum said:
So you dismiss it?
I agree with micromass. All that you are doing is changing from the standard form for a quadratic equation, ax2 + bx + c = 0 to a different form, ax2 = dx + f, where b = -d and f = -c. This is not a 'new way of thinking.' It's just a slightly different way of saying the same thing.
Except we define "http://en.wikipedia.org/wiki/Root_of_a_function" " to be this.
That's why we teach it this way.
agentredlum said:
Thank you for the response, please keep the criticism coming.
Here is a difference you missed.
Look at the example x^2 + 3x + 2 you changed this to x^2 - 3x - 2 = 0 and used the OLD formula that has un-necessary minus signs. You also made a mistake somewhere cause your solutions don't work.
x = 3 +- sqrt(b^2 - 4(1)(c))/2a. Does Not give -1 and -2 for many reasons, many mistakes.
Where to begin, where to begin, where to begin.
First, -1 and -2 are solutions to x^2 + 3x +2.
(-1)^2 + 3(-1) + 2 = 1 -3 + 2 = 0 so -1 is a solution
(-2)^2 + 3(-2) +2 = 4 - 6 + 2 = 0 so -2 is a solution.
or to show it another way:
x^2 + 3x +2 = (x+1)(x+2) = 0, which means -1 and -2 are roots.
But, you didn't even do the quadratic formula correctly. You have to do (-3 +- sqrt(3^2-4(a)(2)))/2. This isn't what you did, which is why you didn't get the right answer.
Now, where are the "many mistakes"?
But your biggest mistake is the following subtle point...
No, my biggest mistake was getting roped into this...
The original was not set equal to anything but you transformed it into something else you thought i would do and set it equal to zero, which i would NEVER do.
I have no idea how you propose to find solutions to something that is not "set equal" to something. When you find roots of a quadratic, you are, in fact, setting it equal to 0 and finding what x's make the equation true.
It is not easy to attempt a different way of thinking when everything you have learned screams against the attempt.
I don't know how many of you can really follow a derivation cause if you think it is not correct then you should point out the flaw in the derivation instead of mixing up stuff and coming up with your own versions that do not follow from my derivation. :smile:
Hmmm. You see, I agree with your derivation. I find nothing wrong with what you did, mathematically. What I am saying is that what you did was silly, pointless and trivial.
For the example x^2 + 3x + 2 = 0
I propose to solve x^2 = -3x - 2 by isolating ax^2 term and using my method NOT x^2 - 3x - 2 = 0 as you claim i would.
Your method is to take the equation x^2 = -3x -2 and use your "revised" quadratic formula find the values of x for which this equation is true. Fine, I see nothing wrong with that, my only point is that it does not simplify anything in the slightest. I never said that you would solve it by solving x^2 - 3x - 2 =0. I said you would take the quadratic equation:
ax^2 + bx + c = 0 as ax^2 = bx +c then use a "different" (different in a superficial, fifth grader way) quadratic formula to find x's that make the equation true. This is EXACTLY what you described.
The equation x^2 = -3x -2 is the SAME FREAKING THING as the equation x^2 + 3x +2 = 0. And your quadratic formula is the SAME FREAKING thing as mine. Go ahead, plug the numbers in yours and in mine and, before you make any calculation you will see that they are IDENTICAL. So why the flip even bother moving stuff around?
You seem to not be able to grasp multiplication by minus 1.
agentredlum said:
So you dismiss it?
Ok, solve this equation:
bx + c = 0.
You can do it multiple ways:
a) solve -bx - c = 0
b) solve bx = -c
c) solve x = -c/b
d) solve -bx -c + 100 = 100
and I could go on. The point isn't that what you have done is wrong, the point is that a)anyone with a middle-school level of education can figure this out b)you aren't doing anything new, in any sense of the word.
It's no wonder his math profs initially said "you're wrong" and then changed it to "you're right." I'm guessing that this is how the conversation went:
AGENTREDLUM: Prof., I have a new way to solve a quadratic. [tex]x = \frac{b +- \sqrt{b^2 + 4ac}{2a}[/tex].
PROF: thinking agentredlum means he proposes to solve the equation ax^2 + bx + c = 0, which is what anyone would think No freaking way.
AGENTREDLUM: long explanation of his easy arithmetic
PROF: Oh yeah. Well you're certainly correct. My only question is why it took prof half an hour to be convinced.
Thank you for the response. That's not what I'm doing in the derivation and if you try to do this for a particular example it would fail to give the right answer using my formula. You see if you replace b by -d and f by -c as you claim then you get back ax^2 + bx + c = 0 so this method hasn't DONE anything. The subsequent derivation will yield the textbook quadratic formula.
This is what i derived
If ax^2 = bx + c then x = (b +-sqrt(b^2 + 4ac))/(2a)
You can't set it = 0 and use this version... you must isolate ax^2 term in equation given to you.
I fear my shortcut post had at least 2 undesirable effects
1) It caused confusion
2) It made the result look trivial.
When using shortcuts one must use them wisely because there are underlying intricacies involved.:smile:
"Oh, let's try to solve the equation ax+b=0. But let's not set it equal to zero. Let's look at the equation ax=b instead. We can see that the solution is [itex]x=\frac{b}{a}[/itex].
This is basically what you did in your post.
No, I won't be impressed until you find a solution for a quintic polynomial.
Let's look at ax = b
If you had been taught that you MUST set it equal to zero in order to find the root, what would you think? Would you think that rule is a myth?
So you only get impressed when someone performs an impossible task? It doesn't take much to impress me, i am thankful for any progress made, no matter how small, especially in a subject such as this which has been considered 'dead' for centuries.
I'm not asking for anyone to be impressed, this is not a cure for a disease. I am asking for some of the posters to be a bit more civilized and check their calculations before showering me with derision.:cool:
To be pedantic, micromass never asked for a solution using radicals. I don't remember if Bring radicals solve all quintics, but I think elliptic integrals can be used.
Robert1986 said:
Now, where are the "many mistakes"? .
Your many mistakes are on this line below, originally posted by you. :smile:
1) You don't have parenthesis on the immediate left of 3
2) you have 3, should be -3. If you use 3 you can't get the answers -1 and -2 that's why i said your answers were incorrect.
3) 1 parenthesis is missing to the immediate right of c
4) 2a should be enclosed in parenthesis
You also didn't substitute for all a, b, c but let that slide:smile:
Yes, I know that, i was trying to avoid flying off on a tangent by posting something like x^5 - 1 = 0
You don't understand me at all. The main idea of that post is that any progress, no matter how trivial is perceived by others, actually is benficial, especially in a subject that has been considered 'dead'
Where does pedantic stop? Sooner or later you will resort to correcting my punctuation in order to make your point?
:smile:
agentredlum said:
Where does pedantic stop? Will you sooner or later resort to correcting my punctuation in order to make your point?
Couldn't resist. :biggrin:
Yeah, I couldn't get tex working correctly so I screwed up writting the quadratic formula. Ya got me there. But this doesn't change the fact that the solutions are -1 and -2 and you get those solutions using any of the methods I described or "your method" (which is really just using the quadratic formula everyone else uses.)
We're cool.:cool: :cool:
I'll try again to explain the 'bare bones mechanics'
My definition...
If ax^2 = bx + c
Then x = (b +-sqrt(b^2 + 4ac))/(2a)
Textbook definition...
If ax^2 + bx + c = 0
Then x = (-b +-sqrt(b^2 - 4ac))/(2a)
From your post I understand you are not disputing this. You are disputing it's usefulness. That is an opinion and it's fine by me.
What I am asking you (and others) is...
'Why do you claim it is the same formula as the textbook version when clearly one can see, just by looking at it, that it isn't. All you have to do is write them down side by side and compare'
This is not an opinion but a question that can be tested by observation, experimentation, and mathematical arguments.
Then I point out 2 MAJOR differences.
1) The idea that you must set the equation to zero is a myth because (as you agree) my version gives the correct answers and it is not set equal to zero.
2) My formula uses less symbols, in the definition and in the formula itself.So my derivation answers the following question...
'Do you have to set it equal to zero to find the roots?'
The old way of thinking says 'You have to'
My derivation says 'You don't have to'
It brings into question the long standing belief that setting the equation to zero is an unquestionable procedure.
This is not an opinion. One can put the 2 definitions side by side, textbook version, my version.
To bring into question a long standing belief, by providing evidence in the form of a derivation as I have done,
is not a trivial matter.
Let me be absolutely clear. I do not question the validity of the textbook version. I question the statement 'you must set it equal to zero' because of the word 'must' :smile:
My definition...
If ax^2 = bx + c
Yes, if you look at the two formulas, they are different. But you are starting with -b instead of b and -c instead of c. Your formula, then, is no surprise. It is a mind-numbingly simple arithmetic "trick" that, in practice, does nothing.
Since you have -b instead of b, then it is natural that -(-b) = b, which is what you have in your formula.
[\QUOTE]
But you ARE setting the quadratic to 0, then just shuffling stuff to the other side of the "=". There is no deep insight here (there is no shallow insight, either). This is 4th grade math.
Yeah, but to get to your equation, you have to multiply b and c by -1 in the general quadratic equation, so what's the point?
But your derivation DOES set it equal to 0, then you just shuffle stuff to the right of the "=". Again, this is 4th grade stuff.
Oh boy; yes, moving stuff to the right side of an equation is real ground-breaking stuff.
You want to solve:
ax^2 + bx + c = 0 by doing this:
ax^2 = bx + c and then using this formula:
[tex]x = \frac{b +- \sqrt{b^2 + 4ac}}{2a}[\tex]<br /> <br /> right?<br /> <br /> OK, well, this equation:<br /> <br /> ax^2 = bx + c is just this equation:<br /> <br /> ax^2 + bx + c = 0 with the b and c multiplied by -1. And your quadratic formula is just the text-book quadratic formula with the b and c multiplied by -1. <br /> <br /> As I have been trying to explain, your method does nothing. Once you plug the actual numbers into the two quadratic formulas, they are the SAME THING. Go ahead, try it with symbols. This is why I say it is useless and nothing new or deep.[/tex]
[\QUOTE]
Did you look at post #1? You are only concentrating on the shortcut. In post #1 i never set it equal to zero, which invalidates all of your counter reasoning above.
In the 'shortcut' post i used the well known form that is ALREADY set equal to zero so of course one can say that is NOT groundbreaking.
But in post #1 i set it equal to bx + c, that is not trivial as you believe.
You don't understand. Because of the way in which the subject is learned, it is not trivial for someone to proceed in this direction, however, the derivation in post #1 is correct and shows you do not have to set it equal to zero in order to derive a working quadratic formula.
Let's put arguments to the side. I have 1 question for you.
Do you believe the equation must be set equal to zero in order to find the roots?
Yes. And I'll explain by a counter-question.
What is the definition of a root?
Robert1986 said:
You want to solve:
[tex] <br /> 0.0) I don't set it equal to zero, you do.<br /> <br /> 0.1) You have to keep track of an extra symbol, zero, I don't so you're moving around more objects than I am. As a matter of fact, even if the equation given to me is set equal to zero, I get rid of zero, by a clever 'kindergarten' argument you don't seem to understand<br /> <br /> 0.2) Your formula has an extra minus sign in front of b which you need to keep track of. This minus sign has nothing to do with a particular equation that has numerical values for a, b, c. The minus sign is a consequence of the definition set equal to zero, and the subsequent derivation by completing the square.<br /> <br /> etc.,etc.,etc.[/tex]
It's trivial
micromass said:
:biggrin: So I'm right, then...
Yes but it's sad to me because you do not want to see beyond definitions. :cry:
Now, I have become the supreme onion, the saddener of all worlds...:biggrin:
Some posters have pointed out that my equation can be set equal to zero. This is a trivial statement. Any equation can be set equal to zero. Some posters have argued adamantly that this is 'reeealy' what I'm doing. This is a misunderstanding, I am not doing that. I am doing the exact opposite, in my derivations using completing the square, Tschirnhaus transformation and the numerical examples presented. Even in the 25% chance that an equation is given already set equal to zero, I get rid of zero and still achieve the correct answers.
Forget about the shortcut, it is not a derivation that can stand on it's own because it uses THE OTHER definition. I would have been impressed if someone pointed THAT out, but no one did. Instead some posters used it to diminish the worth of my result and others agreed with them. I was aware of the shortcomings of the short cut, pun intended, that's why I didn't use it in post #1
Nevertheless, the shortcut is an interesting curiosity and I'm glad I posted it even though it has stirred a lot of controversy. I say again, the shortcut cannot stand very well on its own.
Many thanks for all the responses, let's keep it civilized, o-k?:smile:
OK, perhaps I have misunderstood something, is this what you do to solve a quadratic:
Given this quadratic: ax^2 + bx + c = 0 you write this equation:
ax^2 = bx + c
Am I right so far (forget about where I set it equal to zero, just ignore that if you want, it isn't important; I only wrote it because it isn't an equation without it.)
Then you use this quadratic formula:
[tex]x = \frac{b +- \sqrt{b^2 + 4ac}}{2a}[/tex]
So do I still understand what you are doing?
What I am saying is that you haven't done anything. You have taken the original equation:
ax^2 + bx + c = 0 then you multiplied b and c by -1 to get:
ax^2 - bx -x = 0 (which is 100% identical to what you wrote, which you correctly call "trivial") and solved it using the normal text-book quadratic formula, AFTER you multiplied b and c by -1 in the text-book quadratic formula. Can't you see that your quadratic formula and the text-book quadratic formula only differ in that the b and c have been multiplied by -1 in yours, which accounts for the fact that you have multiplied b and c by -1 in your quadratic equation (you never said you were doing this, but you have, even if you don't realize it.)
It doesn't matter if you start with:
ax^2 = bx + c
and then solve for x from there by completing the square and doing other stuff. It doesn't matter becuase without knowing what a,b and c are, you can multiply them by anything (other than 0) and as long as you make the appropriate adjustments in the quadratic formula (which you did) you get the right answers. This isn't rocket science.
No, it would not.
Here is a simple example, solved in the usual way and solved in your way.
1. x2 + 3x + 2 = 0
I would normally just factor the quadratic expression on the left, but for this example I will use the Quadratic Formula.
[tex]x = \frac{-3 \pm \sqrt{3^2 - 4*1*2}}{2*1} = \frac{-3 \pm 1}{2}[/tex]
So x = -2 or x = -1
2. x2 = -3x - 2
This equation is equivalent to the equation in #1.
Here you are calling the coefficient of x, b and the constant term c, so b = -3 and c = -2. By your formula
[tex]x = \frac{(-3) \pm \sqrt{3^2 + 4*1*(-2)}}{2*1} = \frac{-3 \pm 1}{2}[/tex]
So x = -2 or x = -1, exactly the same as before.
The reason I used d and f was to lessen the possible confusion that results in identifying different numbers with the same variable.
