Mathematical induction with a summation in the problem.
The discussion revolves around a mathematical induction problem involving a summation, specifically proving a statement for n greater than or equal to 0. Participants are examining the correctness of their approaches to parts A and C of the problem.
  • Mixed
  • Participants discuss breaking down the summation into parts and the implications of using n=0 for the base case. There are attempts to manipulate the summation and questions about the correctness of these manipulations. Some participants express uncertainty about their algebraic steps and seek clarification on how to arrive at specific forms of the equation.
The discussion is ongoing with various interpretations being explored. Some participants have provided guidance on how to approach the summation and the algebra involved, while others are still grappling with the steps and seeking further clarification. There is no explicit consensus on the correctness of the approaches yet.
Participants are working under the constraints of a homework assignment, which may limit the information they can share or the methods they can use. There are indications of confusion regarding the algebraic manipulation of terms within the summation.
izic
Hi, I'm currently taking Discrete Mathematics and I'm working on a mathematical induction problem that's a little different than usual because it has a summation in it. What I basically want to know is did I do parts A and C correctly?
http://i48.tinypic.com/s118q8.png
This problem asks you to prove the statement for n greater or equal to 0, not 1, so you would need to use n=0 for part A. The base case is like your "starting point".For part C, write out all your steps, your equality is basically what you are trying to prove. (start by breaking up the summation into the summation from i=1 to i=k+1 plus the term when i=k+2, because we already know what this summation is equal to by assumptions. So, you'll have to manipulate this to show that it equals (k+1)2^{k+3}+2)
Alright so I broke the summation up into three parts - i=1, i=k+1, and i=k+2 and since I already knew what i=k+1 and i=k+2 was, I plugged those values for it. This is what I have so far but to be honest I'm not sure how to go where from here.
http://i45.tinypic.com/5158xu.jpg
this isn't the correct way to break up the summation.
This is what the summation actually means: ##\sum_{i=1}^{k+2} i2^i = (1)(2^1) + (2)(2^2) + ... + (k+1)(2^{k+1}) + (k+2)(2^{k+2})##
So, we can group the first k+1 terms together to get ##\sum_{i=1}^{k+2}i2^i = (\sum_{i=1}^{k+1}i2^i ) + (k+2)(2^{k+2})##
izic: if you post images here, please make sure they are small enough to not distort the view. If you can't make them small enough, then please just link the images. I changed the images to links in your older posts.
Oh so that's what I was missing. But yeah I took what you gave me and I was able to get the Left hand side to look like "(k+1)(k+2)(2^k+3)" which is close to the right hand side "(k+1)(2^k+3)". Did I go about this the right way? All I need to do is cancel (k+2) and the left hand side will finally look like the right hand side.
http://i47.tinypic.com/2cdjsjd.jpg
See what CornMuffin did?
Then, since we are assuming that [itex]\displaystyle \sum_{i=1}^{k+1}i\cdot2^i =k\cdot2^{k+2}+2\ ,[/itex]
we now have that [itex]\displaystyle \sum_{i=1}^{k+2}i\cdot2^i=\left(k\cdot2^{k+2}+2 \right) +(k+2)(2^{k+2}) \ .[/itex]
Now show that the RHS is equivalent to (k+1)2k+3 + 2
First I get, (k * 2^k *2^2 + 2)+ (k+2)(2^k* 2^2).
Then, (2^k * 2)(k+2) +(k+2)(2^k * 2)
Can I factor out one "(2^k * 2)(k+2)" since I have two of them?
(k * 2k *22 + 2) ≠ (2k * 2)(k+2) .
Take (k+2)2k22 and distribute the 2k22 through the (k+2). By the way 2k22 is 2k+2 and 2 times that is 2k+3, which you're looking for.
I notice that after distributing it, I get k*(2^(k+2)) + (2^(k+3)) (2^(k+2)*k)
Do you mind explaining how to get these bold parts in the RHS (2^(k+3)+2)(k+1)
from the left hand side which is this k*(2^(k+2))+ (2^(k+3)) (2^(k+2)*k)?
Distributing as I suggested:
[itex]\displaystyle (k+2)2^{k+2}=k\cdot2^{k+2}+2\cdot2^{k+2}\ .[/itex]
Now, add that to the other terms, [itex]\displaystyle k\cdot2^{k+2}+2\ .[/itex]
izic said:
Added them together but it's equaling the right hand side.
http://i50.tinypic.com/33dfbls.png
That's incorrect...how did you get a 5k?? :confused:
You have,
[tex]2^{k+3} + k\cdot 2^{k+2} + k\cdot 2^{k+2} + 2[/tex]
Try factoring out [itex]2^{k+2}[/itex] of the middle two terms, simplify, and then factor [itex]2^{k+3}[/itex] out of the term you get.
You have,
Alright, I tried that but ended up with (k+1)(2^(k+3)) instead of (k+1)(2^(k+3)+2)). How can I get the "+2" part?
http://i49.tinypic.com/25q6g51.png
It's evident that your algebra skills are lacking. You also appear to skip steps.
In sure that the main purpose of this exercise was to give you some practice working with inductive proofs. You gave gotten all bogged down in the algebra, which is really quite basic.
The "+ 2" part never gets combined with anything.
Let's start with [itex]\displaystyle 2^{k+3}+k\cdot2^{k+2}+k\cdot2^{k+2}+2\,,[/itex] which is what you started with in your graphic from last post.
You have a repeated term of [itex]\displaystyle k\cdot2^{k+2}\,.[/itex]
In my opinion, the easiest way to look at this is to recognize this as two of something (added together). So just as
[itex]\displaystyle x+x=2x[/itex]
you have
[itex]\displaystyle k\cdot2^{k+2}+k\cdot2^{k+2}=2\left(k\cdot2^{k+2} \right)\,.[/itex]
Of course, you can look at it as Infinitum suggested and factor out the common factor of [itex]\displaystyle 2^{k+2}\,.[/itex] This will give the same result.
Now, how can you write [itex]\displaystyle 2\left(k\cdot2^{k+2} \right)\,[/itex] in simpler form?
2 times k times "k+2" factors of 2 is the same thing as k times "k+3" factors of 2.
What does that leave us with?
[itex]\displaystyle 2^{k+3}+\underline{\quad\text{ ? }\quad}+2\,.[/itex]
  • · Replies 23 ·
