MATLAB Efficient Summation in MATLAB for Biphasic Model: Varying n from 0-3 to 0-100
The discussion focuses on implementing a summation in MATLAB for a biphasic model, specifically varying the parameter n from 0 to 3 and then from 0 to 100. The user seeks guidance on how to properly define and sum the function f(n) within their code, which involves a complex mathematical expression. They encounter an error related to subscript indices while attempting to sum the results. Suggestions emphasize the need to ensure that indices are real positive integers and to correctly structure the summation loop. Overall, the conversation revolves around troubleshooting MATLAB code to achieve the desired summation for the biphasic model.
tunk
i need to write this into MATLAB
http://www.engin.umich.edu/class/bme456/ch10fitbiphasic/biphasfit19.gif
which i have done here:
uj = (-sig/Ha)*(xj-(((2*h)/(pi^2))*((((-1)^n)/((n+1/2)^(1/2)))*sin((n+1/2)*((pi*xj)/h))*exp(((-Ha*ko)/(h^2))*((n+1/2)^2)*(pi^2)*t))));
how do i vary n, and get the equation to sum over n=0-3? and then again from n=0-100?
Call everything inside the summation f(n)
for i=1:4 %n from 0 to 3 case
y(i) = f(i-1)
end
sum(y);
for i=1:101 %n from 0 to 3 case
y(i) = f(i-1)
end
sum(y);
Should work
y(i) = f(i-1)
end
sum(y);
y(i) = f(i-1)
end
sum(y);
Should work
I got the following error for the same equation, following your summation of f(n),
"? Subscript indices must either be real positive integers or
logicals.
Error in ==> scriptrun at 16
f(n)=sum(((abs((-1).^n))/((n+1./2).^(2))));"
My code:
for i=1:3 %n from 0 to 2 case
y(i)=f(i-1);
end
sum(y);
uj = (-sig/Ha)*(xj-(((2*h)/(pi^2))*f(n)*sin((n+1/2)*((pi*xj)/h))*exp(((-Ha*ko)/(h^2))*((n+1/2)^2)*(pi^2)*t)));
Any advise?
You're summing uj = (-sig/Ha)*(xj-(((2*h)/(pi^2))*f(n)*sin((n+1/2)*((pi*xj)/h))*exp(((-Ha*ko)/(h^2))*((n+1/2)^2)*(pi^2)*t))) that's what f(n) is. just calling that expression will give an error, I believe.
18K
