Matlab command question: length max([x+y-1,x,y])
  • Context: MATLAB
  • Thread starter Thread starter PainterGuy
    Length Matlab
The discussion clarifies the behavior of the MATLAB command length max([2+3-1,2,3]), which returns 16 because it treats the input as a string rather than executing the max function. The correct usage to obtain the maximum value is length(max([2+3-1,2,3])), which returns 1, as max([2+3-1,2,3]) evaluates to 4. The misunderstanding arises from the absence of parentheses, leading to confusion between string length and numerical evaluation.
  • Understanding of MATLAB syntax and command structure
  • Familiarity with MATLAB functions such as length and max
  • Basic knowledge of data types in MATLAB, specifically strings and numbers
  • Experience with MATLAB version R2023a or later for accurate function behavior
  • Learn about MATLAB function syntax and the importance of parentheses
  • Explore string manipulation functions in MATLAB
  • Investigate data type conversions in MATLAB, particularly between strings and numbers
  • Review MATLAB documentation on the length and max functions for deeper insights
MATLAB users, data analysts, and programmers seeking to understand function behavior and string handling in MATLAB. This discussion is particularly beneficial for those troubleshooting command syntax issues.
PainterGuy
Hi,
I'm not sure if I should be asking this but I couldn't make sense of the following Matlab command: length max([2+3-1,2,3]). The result is "16". I couldn't the operation of this command and why it produces the result of "16". Could you please help me with?
The length command, when used in the way you have shown, returns the number of characters in the string after it. So, for example, length ans returns 3 because the number of characters in ans is 3. Similarly, the number of characters in max([2+3-1,2,3]) is 16, so the command length max([2+3-1,2,3]) returns 16.
Perhaps you are trying to use length(max([2+3-1,2,3]))?
https://in.mathworks.com/help/matlab/ref/length.html
I'm sorry but how the number of characters is 16. The command max([2+3-1,2,3]) produces the result 4.
The command max([2+3-1,2,3]) is not executed. It is considered a string, and MATLAB gives you the number of characters in that string.
When you use length without parentheses, it assumes that everything after it is a string, so
is really the same as
length 'max([2+3-1,2,3])'
and the string 'max([2+3-1,2,3])' is 16 characters long.
If you would have used parentheses, it would not make the assumption that the argument is a string. It would evaluate the string. And max([2+3-1,2,3]) evaluates to max([4, 2, 3]) which evaluates to a double precision number 4. And length(4) is, of course, 1. So if you do
you'll get 1
Not really sure what you want, but those are two ways to proceed. Adapt it to get what you need or want.
