Matlab -- how can i use a FOR loop if I have 2 variables changing
7 replies · 2K views
jiaying
Hey,for following code the 3rd loops i need to have 2 variables m and q .Could anyone help?
Matlab:
for t=1:maxiterations
    toterror=0;
    for j=1:numfeature
        totslope=0;
        for i=1:m&&q=1:numfeature
              z=0;
           for jj=1:numfeature
               z=z+prevtheta(jj)*x(i,jj);
           end
           h=1.0/(1.0+exp(-z));
           H=H+(x(i,q)*h*(1-h)*x(i,jj));
           totslope=(totslope+(h-y(i))*x(i,j));
           toterror=(toterror+-y(i)*log(h)-(1-y(i))*log(1-h));
        end
   toterror=toterror/numtrainsam;
   theta(j)= theta(j)-H\totslope;
    end
    prevtheta=theta;
      errorperiteration(t)=toterror/j;
end
I assume you're asking about this loop.
Matlab:
              z=0;
           for jj=1:numfeature
           end
        end
Why is m in there? It's not used in that for loop, and it's not used outside the loop.
In general, you would either use separate loops if they vary independently or make one dependent on the other.
Say m varies from 1 to 10 and n varies from 4 to 40
Then loop on m and compute n = 4*m inside the loop.
It helps if you say in words what you want to do. In MATLAB the syntax for for loop is
Code:
for ii=intialValue: stepSize: maxValue
I don't think you can include a variable in the stepSize option. What do you want to do with this for loop?
I'm fairly certain that you can use variables for all three: initVal, stepVal, and endVal. I don't have matlab, so I can't confirm this.
However, the for loop body can't change the value of the index variable (the loop control variable).
I think you can use variables in the all three, too, but I don't think you can use the following syntax
Code:
initialValue=1;
endValue=10;
for ii=initialValue:m=0.5:endValue
as the OP tried to do.
Code:
initialValue=1;
maxValue=10;
The problem is the "m=" part.
I believe this would be fine:
Matlab:
initVal=1;
stepVal = 0.5
endVal=10;
for ii=initVal : stepVal : endVal
;; loop body
end
