MATLAB movie2avi cannot made video
  • Topic: MATLAB
  • Thread starter Thread starter kelvin490
    matlab movie video
4 replies · 4K views · last reply
kelvin490
I am trying to test the function movie2avi using simple codes in R2014a as follows:
clear; close all;
figure;
Z = peaks;
surf(Z);
axis tight manual;
ax = gca;
ax.NextPlot = 'replaceChildren';
loops = 40;
F(loops) = struct('cdata',[],'colormap',[]);
for j = 1:loops
X = sin(j*pi/10)*Z;
surf(X,Z);
drawnow;
F(j) = getframe(gcf);
end
movie(F);
movie2avi(F, 'myPeaks.avi', 'compression', 'None');
It seems the movie(F) works well but the avi file created contains the toolbar and background instead of just showing the graph. Also the avi file just show stationary picture as follow:
https://www.dropbox.com/s/otgnhc9ucfehqwk/a.png?dl=0
Another version of the program produce the same result:
clc;clear; close all;
figure;
Z = peaks;
surf(Z);
axis tight manual;
ax = gca;
ax.NextPlot = 'replaceChildren';v = VideoWriter('newfile2.avi','Uncompressed AVI');open(v);
loops = 40;
for j = 1:loops
X = sin(j*pi/10)*Z;
surf(X,Z);
drawnow;
F = getframe(gcf);
writeVideo(v,F);
end
close(v);There is also a warning:
Warning: Struct field assignment overwrites a value with class "double". See MATLAB R14SP2 Release Notes, Assigning Nonstructure
Variables As Structures Displays Warning, for details.
Please help. Thanks.
The movie2avi function is not recommended. There is a note in the documentation saying to use VideoWriter instead.
Try this code out instead of calling movie2avi:
Code:
v = VideoWriter('newvid.avi');
open(v)
writeVideo(v,F)
close(v)
More info here: http://www.mathworks.com/help/matlab/ref/videowriter-object.html
Code:
open(v)
writeVideo(v,F)
close(v)
I have tried writeVideo, for simple codes like this:
Z = peaks; surf(Z);
vid = VideoWriter('myPeaks2.avi');
vid.Quality = 100;
vid.FrameRate = 15;
open(vid);
for k = 1:20
surf(sin(2*pi*k/20)*Z,Z);
writeVideo(vid, getframe(gcf));
end
close(vid);
winopen('myPeaks2.avi')
it works for R2015a in my win8 computer, avi file is produced normally, but doesn't work for R2014a in a win10 computer, only stationary picuture with unnecessary background in the screen is shown in the avi (just like the picture I posted above). I don't know why there is such a difference...
Not at a computer to test this but my first guess would be that the graphics system had a major overhaul in 14b. So the behavior of some graphics functions changed, in particular I would double check that getframe(gcf) has the behavior you expect in both releases.
Update: I added a command "set(gcf,'Renderer','zbuffer');" when I use R2014a and the problem is solved. It is just like using writeVideo in R2015a without that command. Thank you.
