Max/min with partial derivatives
The function f(x,y) = -(x^2 - 1)^2 - (yx^2 - x - 1)^2 has two critical points, specifically at (1,2) and (-1,0), both of which are maxima. The critical points were determined by setting the partial derivatives f_x and f_y to zero, leading to the equations f_x = -2(x^2 - 1)(2x) - 2(yx^2 - x - 1)(2xy - 1) = 0 and f_y = -2(yx^2 - x - 1)(x^2) = 0. The second derivative test confirmed that both critical points yield positive determinants, indicating local maxima.
  • Understanding of partial derivatives and critical points
  • Familiarity with the second derivative test for maxima and minima
  • Knowledge of multivariable calculus concepts
  • Ability to manipulate algebraic expressions and equations
  • Study the method of Lagrange multipliers for constrained optimization
  • Learn about Hessian matrices and their role in determining local extrema
  • Explore the applications of partial derivatives in real-world scenarios
  • Investigate the implications of saddle points in optimization problems
Students and professionals in mathematics, particularly those focusing on calculus, optimization, and multivariable functions, will benefit from this discussion.
compliant
Show that f(x,y) = -(x^2 - 1)^2 - (yx^2-x-1)^2 has only two critical points, and both are maxima.
Set partial derivatives (wrt x and y) to zero to find critical pts.
-2(x^2 - 1)(2x) - 2(yx^2 - x - 1)(2xy - 1) = -2(yx^2 - x - 1)(x^2)
(x^2 - 1)(2x) + (yx^2 - x - 1)(2xy - 1) = (yx^2 - x - 1)(x^2)
2x^3 - 2x + 2(x^3)(y^2) - 2(x^2)y - 2xy - yx^2 + x + 1 = yx^4 - x^3 - x^2
3x^3 + x^2 - x + 1 = yx^4 -2(x^3)(y^2) + 2(x^2)y + 2xy
3x^3 + x^2 - x + 1 = y(x^4 -2(x^3)(y) + 2(x^2) + 2x)
And that's about as far as I got.
look at the f_y equation. What can you deduce about its solutions straightaway (it's already factorized!) ? Check if each solution works by comparing with f_x equation. I see only two workable ones. I suppose I'll leave it to you to check for maxima.
well, from f_y, I can deduce that x=0 or yx^2 - x - 1 = 0.
If x=0, from f_x, y= -2.
If yx^2 - x - 1 = 0,
y = (x+1)/(x^2)
Subbing into f_x,
-2(x^2 - 1)(2x) - 2((x+1)-x-1)(2x(x+1)/(x^2) - 1) = 0
-2(x^2 - 1)(2x) = 0
x(x^2 - 1) = 0
x = 0 (as above), x = 1 or x = -1
If x = 1, y = 2
If x = -1, y = 0
Using the second derivatives test,
D = (f_xx)(f_yy) - (f_xy)^2
where
f_xx = -2[6x^2 - 2 + 6(x^2)(y^2) - 4xy - 2y]
f_yy = -2[x^4]
f_xy = -2[4yx^3 - 3x^2 - 2x]
At (0,-2), f_xx = -2(-2+4) = -4; D = (-4)(0) - 0 = 0
At (1,2), f_xx = -2(6-2+24-8-4) = -32; D = (-32)(-2) - (3)^2 > 0
At (-1,0), f_xx = -2(6-2) = -8, D = (8)(-2) - (-5)^2 < 0
So, I essentially have a saddle point at (-1,0), a maximum at (1,2) and an unknown at (0,-2). The problem with this is that:
1) there are three critical points, somehow, and not two.
2) only one is a maximum.
"If x=0, from f_x, y= -2."
Are you sure?
= -2(0-1)(0) - 2(-1)(-1) = -2
its f_x, NOT y.
Thus, what does this mean?
*backtracks*
ooooooooooookay. so.
when x=0, f_x = -2, but f_x = 0, so x=0 is not a solution.
which brings me back to the points (-1,0) and (1,2). looking at my calculations for (-1,0), turns out that it's horrendously wrong.At (-1,0), f_xx = -2(6-2) = -8, D = (-8)(-2) - (0-3+2)^2 = 16 - 1 > 0
Which gives a maximum. Hooray. Thanks for the help.
np =)
