Maximizing cylinder volume using calculus of variations
1 reply · 2K views
CrosisBH
Find the ratio of R (radius) to H(height) that will maximize the volume of a right circular cylinder for a fixed total surface area.
[tex] \frac{\partial f}{\partial q_k} - \frac{d}{dx} \frac{\partial f}{\partial q_k '} + \sum \lambda_k (x) \frac{\partial g_k}{\partial q_k} = 0[/tex]
[tex] S = 2\pi RH + 2\pi R^2 [/tex]
[tex] V = \pi R^2 H [/tex]
Note this is in our Lagrangian Mechanics section of Classical Mechanics, so I assume he wants us to use Calculus of Variations to solve it.
The surface area is fixed, so that'll be the constraint. Maximizing volume, we need a functional to represent Volume. This was tricky, but my best guess for it is
[tex]V = \int dV = \int_{0}^{H} \pi R^2 dH[/tex]
That way it can be represented by a single integral.
[tex]f = R^2[/tex]
Plugging the stuff into the Euler-Lagrange equation and simplifying I get (I can show my work here if it's needed)
[tex](2\lambda + 1)R + \lambda H = 0[/tex]
I'm just stuck here. I don't know how to proceed. Calculus of Variations is still very new to me. Thank you!
Yes it's needed ... I'd like to see what you use as Lagrangian and what you use as ##q_k## and ##g_k##
[edit] You seem to think that ##{\mathcal L} = f = R^2 ## but that is not correct
Furthermore, the number of constraints is not equal to the number of variables, so ##g_k## and ##\lambda_k## looks strange: The sum is not over ##k## but over the constraints :##\displaystyle{
\sum_i \lambda_i \frac{\partial g_i}{\partial q_k}}##
The ##\lambda_i## are numbers, not functions.
[edit2] looked at your profile and want to step back somewhat:
##f## is the function you want to maximize, so here ## f(r,h) = V = 2\pi r^2 h ##, a function of 2 variables. At an extreme you expect ##{\partial f\over \partial h}= {\partial f\over \partial r} = 0##.
Two equations in two unknowns that are not independent.
Instead of eliminating one of the variables, you use the method of Lagrange multipliers and solve
##{\partial {\mathcal L} \over \partial h}= {\partial {\mathcal L} \over \partial r} = 0## with ##{\mathcal L} = f - \lambda g##.
##g(r,h) = 0## is the constraint ##S = 2\pi r^2 + 2\pi rh \quad \Rightarrow \quad g(r,h) = 2\pi r^2 + 2\pi rh - S##.
Now we have three equations (the third one is ##g=0##) with three unknowns (##r,h,\lambda##) and we can treat ##r## and ##h## as if they were independent.
