Maximum angle between resultant and original vector
The problem involves adding two vectors of magnitudes 5 units and 3 units, with the goal of determining the angle between the resultant vector and the vector of magnitude 5 units when this angle is maximized.
  • Exploratory, Assumption checking
  • Participants discuss the relationship between the angles of the vectors and the resultant, with some suggesting to express the angle in terms of the angle between the two vectors. Others question the interpretation of the angles involved and whether the stated answers are correct.
The discussion is ongoing, with participants exploring different interpretations of the angles and checking each other's reasoning. There is an acknowledgment of potential misunderstandings regarding the angles being discussed.
Some participants note the constraints of the problem, such as the impossibility of the maximum angle being 0 or 180 degrees, and the need for careful reading of the question to avoid confusion.
Shivansh Mathur
Two vectors of magnitude 5 units and 3 units are added such that the angle between the resultant and the vector of magnitude 5units is maximum. Find this angle.
Knowing that the resultant vector makes a smaller angle with a vector of larger magnitude, I tried to draw some diagrams but they proved to be of little help.
Further, the max. angle can't be 180 degrees or 0 degree for obvious reasons.I know PF does not provide complete solutions but I would be thankful for any assistance provided.
First Try and find the angle between the vector and the resultant in terms of the angle between the two vectors.
Sahil ,
In case you have worked out the problem , do you mind checking the answer ?
37°
conscience said:
Sahil ,
37°
According to me the answer is
90° + 37° = 127°
Thanks .
I think what you have stated is the angle between the two vectors such that the angle between the resultant and vector of magnitude 5 units is maximum . I might be wrong .
Would you like to reconsider your answer ?
conscience said:
Thanks .
I think my answer is correct
cosx= -3/5 => x=90+37
This is the angle between the two vectors , not between the resultant and vector of magnitude 5 units .
Sorry, i didnt read the question carefully. You are correct.
tan y = (3*4/5)/(5-3*3/5) = 3/4 => y= 37
Alright :smile:
Draw a line OP for the vector of 5 units. From the tip of that vector, P, you can draw another line of 3 units. What is the locus of points Q where that might end? Which of these maximises the angle POQ?
  • · Replies 26 ·
