Maximum angle between resultant and original vector
To find the maximum angle between the resultant vector and the 5-unit vector, the discussion emphasizes understanding the relationship between the two vectors. The maximum angle cannot be 0 or 180 degrees, as these would not yield a resultant. Participants suggest drawing diagrams to visualize the vectors and their resultant. The conversation highlights the importance of correctly interpreting the angles involved, particularly distinguishing between the angle of the resultant and the angle between the two original vectors. Ultimately, the goal is to determine the configuration that maximizes the angle between the resultant and the larger vector.
Shivansh Mathur
Two vectors of magnitude 5 units and 3 units are added such that the angle between the resultant and the vector of magnitude 5units is maximum. Find this angle.
Knowing that the resultant vector makes a smaller angle with a vector of larger magnitude, I tried to draw some diagrams but they proved to be of little help.
Further, the max. angle can't be 180 degrees or 0 degree for obvious reasons.I know PF does not provide complete solutions but I would be thankful for any assistance provided.
First Try and find the angle between the vector and the resultant in terms of the angle between the two vectors.
Sahil ,
In case you have worked out the problem , do you mind checking the answer ?
37°
conscience said:
Sahil ,
37°
According to me the answer is
90° + 37° = 127°
Thanks .
I think what you have stated is the angle between the two vectors such that the angle between the resultant and vector of magnitude 5 units is maximum . I might be wrong .
Would you like to reconsider your answer ?
conscience said:
Thanks .
I think my answer is correct
cosx= -3/5 => x=90+37
This is the angle between the two vectors , not between the resultant and vector of magnitude 5 units .
Sorry, i didnt read the question carefully. You are correct.
tan y = (3*4/5)/(5-3*3/5) = 3/4 => y= 37
Alright :smile:
Likes Sahil Kukreja
Draw a line OP for the vector of 5 units. From the tip of that vector, P, you can draw another line of 3 units. What is the locus of points Q where that might end? Which of these maximises the angle POQ?
