Maximum Weight for Stationary System with Static Friction
  • Thread starter Thread starter burg25
    Friction
The discussion revolves around two physics problems involving forces, friction, and static equilibrium. The first problem involves a father pulling a sled with a child on it, requiring calculations for acceleration and the minimum force needed to start moving the sled. The second problem concerns a block system where participants need to determine the maximum weight of one block to keep the system stationary, considering static friction and angles.
  • Mixed
  • Participants explore the application of force equations and friction coefficients in both problems. There is an attempt to break down the forces acting on the blocks and to clarify the setup of the second problem. Some participants express confusion about the correct approach to the second problem, particularly regarding the treatment of forces in different directions.
Participants are actively engaging with the problems, providing attempts at solutions and seeking clarification. Some guidance has been offered regarding the need to separate horizontal and vertical forces for the second problem. There is a recognition of the need to sum forces in both directions to establish the correct equations.
One participant mentions confusion regarding the setup of the second problem and the attachment containing a figure, which is crucial for understanding the scenario. There are indications of differing interpretations of the force equations, particularly in the context of static friction and tension in the rope.
burg25
1. Homework Statement
Hey I was wondering if someone would just check over this bonus question for me.
1) A father pulls his child on a sled by pulling on rope over his shoulder. He exerts a force of 50 N at an angle of 30*. a) Using the coefficient of friction for steel on ice, calculate the acceleration of the sled if its mass plus the child's is 20 kg, assuming the sled is already in motion. b) What minimum force must the father exert to start the sled moving from rest?
2) Block B in the figure (in attached file) weighs 711 N. The Coefficient of static friction between the block and the horizontal surface is 0.25. Find the maximum weight of block A for which the system will be stationary. Assume the rope attached to the wall make a 30* angle with the horizontal.
\mus = 0.40 \muk = 0.02
F=ma
1) a) Fx= max Fy=may
Fappcos\theta-f = ma Fn+Fappsin\theta= Fg
Fappcos\theta- \mukFn=ma Fn = Fg - Fappsin\theta
a = Fappcos\theta- \mukFn/m
a = (50cos30 - (0.02(20(9.8)- 50 sin30))/20
a = 1.99m/s/s
b) Fcos\theta- \mus (Fg-Fsin\theta) = 0
Fcos\theta- \musFg +\musFsin\theta)=0
Fcos\theta+\musFsin\theta)=\musFg
F(cos\theta+\mussin\theta) =\musFg
F =\musFg / (cos\theta+\mussin\theta
F = (0.4(20*9.8)) / (cos30 + (0.4(sin30))
F = 73.5 N
2) I was confused on this one and treated it as a hanging mass problem but here is my attempt:
Fb=ma
Fb=mg-\mukmg
Fb= 711 - (0.25(711))
Fb=533.25N
Tbsin\theta= Tacos\theta
Ta = Tbsin\theta / cos\theta
Ta = 533.25sin30 / cos30
Ta = 307.9N
The maximum weight for block A is 307.9N because if it were greater the string would break.
Hi burg25,
F=ma
a = 1.99m/s/s
F = 73.5 N
Fb=ma
Fb=mg-\mukmg
Fb=533.25N
Ta = 307.9N
Your work for the first problem looks okay to me.
(I can't yet view your attachment and did not understand the setup for the second problem.)
Would you be able to see the figure if I emailed the figure to you? I do not know how to start the second, so I'm kinda lost there.
It's been approved now so I can see the attachment. (I'm glad I did not say anything about it; my mental image was way off.)
I think you're doing a few things wrong. In you force equation for block B, you are mixing horizontal and vertical forces (for example, you have the vertical weight and the horizontal friction in the same equation).
You apply \sum F_x = ma_x in one particular direction (when you are dealing with components), so you'll need two equations for block B: one for the vertical force (components) and one for the horizontal forces (components). There are a total of four forces on block B, so what two equations would you get from the force diagram?
The other force equation that you found for the tensions (Tbsin= Tacos\theta) look right to me.
What do you get for the weight of block A?
Ok so I should sum the forces in the x and y directions. This would give me the equations
Fx= Tb - \mumg = 0 for the x since the system is stationary and the y equation would be Fy= Fg=FN. So then I could rewrite the x to be Tb = \mumg. So then I would plug this value in for Tb in the equation
Tbsin\theta = Tacos\theta so
Ta = (.25(711))sin30/cos30
Ta = 102.6 N
So the maximum mass block A could be to keep the system stationary is 102.6N.
Is this right or did I still screw something up and thank you so much for your help.
Ta = 102.6 N
That looks like the right answer to me.
Thank you alphysicist.
Glad to help!
13K
37K
