What Is the Significance of the Constant c in Wave Equations?
  • Context: High School
  • Thread starter Thread starter davidge
    Constant
The constant c in wave equations represents the speed of light, quantified as 3 x 108 m/s. In the context of a vibrating string, c is defined as c = √(T/ρ), where T is tension and ρ is mass density per unit length. This relationship indicates that the wave speed v, derived from the ratio T/ρ, is not necessarily equal to c but can be interpreted as the speed at which disturbances propagate along the string. The discussion emphasizes that while c is a universal constant, its implications can vary based on the specific wave system being analyzed.
  • Understanding of wave equations and their mathematical formulation
  • Knowledge of tension (T) and mass density (ρ) in physical systems
  • Familiarity with the concept of wave speed (v) and its derivation
  • Basic grasp of the relationship between physical constants and wave propagation
  • Explore the derivation of the wave equation in different physical contexts
  • Investigate the implications of the speed of light in various wave phenomena
  • Learn about the relationship between tension and wave speed in strings
  • Research the broader implications of wave speed in the context of space-time theories
Physicists, engineering students, and anyone interested in the mathematical foundations of wave mechanics and the significance of physical constants in wave propagation.
davidge
For systems whose motion is discribed by the wave equation
$$ \bigg(\frac{1}{c^2} \frac{\partial^2}{\partial t^2} - \vec{\nabla^2} \bigg)u \big(\vec{x},t \big) = 0$$ ##c## is the speed of light. It corresponds to different quantities depending on what the system under consideretion is. For instance, for a simple vibrating string, ##c = \sqrt{T / \rho}## where ##T## is the tension and ##\rho## is the mass density per unit length.
My question is, What is the meaning of the ratio ## T / \rho = c^2##? Maybe, tension propagates at the speed of light throughout the string?
Not necessarily, c is the speed of whatever wave you are dealing with.
Oh, I forgot about that. Thanks.
But, still, could the ratio ##T / \rho = v^2## be interpreted as the tension propagating across the string at the speed ##v##?
davidge said:
But, still, could the ratio T/ρ=v2T/ρ=v2T / \rho = v^2 be interpreted as the tension propagating across the string at the speed vvv?
##v## is the speed at which a disturbance in the string would travel. If you plucked the string, the distortion in it's shape would travel down the string at this speed.
c is speed of light that has a numerical value of 3*10^8 m/s.
Did you even read OP and other posts? c does have more general meaning in the context of OP.
If I understand the OP post correctly, he is trying to use the string derivation of the wave equation to glean insight into the "cause" of c, i.e. apply that insight into space-time.
I don't think you can. I think you just have to take the 1/c^2 as a factor that, while eventually causing the wave speed, can have very different and unrelated derivations.
Thank you all
  • · Replies 32 ·
  • · Replies 33 ·
