- 4,853
In https://th.physik.uni-frankfurt.de/~hees/publ/quant.pdf from 2008 you write:vanhees71 said:In which of my lecture notes and where have you interpreted this in? Of course, I never wanted to claim this nonsense. Maybe I was sloppy in some formulation that you could come to this conclusion.
[Moderator note (for completeness, although identical with what is said anyway): If the observable ##A## is measured on the system, then the result of the measurement is always a (generalized) eigenvalue of the according self-adjoint operator ##A##.]Hendrik van Hees said:Wird nun an dem System die Observable ##A## gemessen, so ist das Resultat der Messung stets ein (verallgemeinerter) Eigenwert des ihr zugeordneten selbstadjungierten Operators ##A##.
which agrees with tradition and the Wikipedia formulation of Born's rule, and says that measurements produce always eigenvalues - hence never approximate eigenvalues. Later, on p.20 of https://th.physik.uni-frankfurt.de/~hees/publ/stat.pdf from 2019, you seem to have strived for more precision in the language and only require:
You now 1. distinguish between the observable and the associated operator and 2. have the qualification 'precise', both not present in the German version.Hendrik van Hees said:A possible result of a precise measurement of the observable ##O## is necessarily an eigenvalue of the corresponding operator ##\mathbf O##.
Thus it was natural for me to assume that you deliberately and carefully formulated it in this way in order to account for the limited resolution of a measurement device, and distinguish between 'precise', idealized measurements that yield exact results and 'unprecise', actual measurements that yield approximate results, as you did in post #2 of the present thread:
vanhees71 said:Born's statistical interpretation does not claim that there is no measurement error but, as usual when formulating a theory, discusses first the case that the measurement errors are so small that they can be neglected. If you deal with unprecise measurements the analysis becomes much more complicated
Here you seem to refer again to idealized measurements when you make the final statement., as no measurement error is mentioned.vanhees71 said:It's of course true that any measurement device has some imprecision, but you can in principle measure as precisely as you want, and theoretical physics deals with idealized measurements. The possible outcomes of measurements are the eigenvalues of the operator of the measured observable.
Thus you have hypothetical measurement results ('precise', idealized) representing the true, predictable possible values and actual measurement results ('imprecise') representing the unpredictable actual values of the measurements. Their relation is an unspecified approximation about which you only say
It is this postulated dichotomy that I analyzed in my post #21.vanhees71 said:That cannot be theorized about but has to be treated individually for any experiment and is thus not subject of theoretical physics but part of a correctly conducted evaluation of experimental results for the given (preparation and) measurement procedure.
