Measuring Coefficients of Friction
In summary, the conversation discusses the task of designing and carrying out a lab to measure the coefficients of friction between a wooden board and random objects. The individual is seeking help with understanding how to solve for the coefficients and distinguish between kinetic and static friction. They are also struggling with understanding vector components and using Newton's laws to solve the problem. The conversation also touches on the concept of breaking up forces into their components and using equations such as F=ma and F=mg.
Dirkpitt
first off I'd like say thanks to everyone on here, I've lurked and solved many questions thanks to you guys. First post woo.
Basically we were tasked to design and carryout a lab to measure the coefficients of friction between a wooden board and some random objects (teachers gone for a few days so busy work basically). Easy stuff really, but I'm getting all confused with the components and way to solve for the coefficients/distinguish difference between solving for kinetic and static (if there is one).
Have a bunch of angles but only need some help on getting started.
Object 1 - Static 18 degrees to start moving, kinetic 13.6 degrees to move at a constant velocity.
This is where I'm lost basically.
This is the diagram I have. Excuse my 5 minute pentool job XD. With similar triangles the angle is 18 degrees, and I know you have to use cos and sin to make up for the "F1, F2" variables. Cos for F1, and Sin for F2, all I'm missing is how to use them. Thus I haven't gotten too far yet :(
From my current understanding, Fn = Fg - Ff. So Normal force has to equal the force of gravity minus the force of friction for the object to move, I'm just not sure on how to add in the F1 and F2. I'm thinking F=mg would work, and setting them equal to each other?
Something like;
F1=M(Gcos)
F2=M(Gsin)
Then M(Gcos)=M(Gsin), you could take out the "M", since M=M.
Gcos=Gsin
G=Sin/Cos
G=Tan
Honestly I don't really know where I was going with that, other then taking out the M :/
yes, F1 = mg cos theta, and F2 = mg sin theta. Those are the componets of mg. So now cross out mg in your free body diagram, because you already broke it up into its vector components.
Don't solve it by adding vectors, rather, solve it by adding vector components. Choose the incline as the x axis, and the normal force then acts along the y axis. Please label the friction force in your diagram, and show its direction. Now use Newton's Law (which one?) in the x and y direction, separately.
Adding in Ff, which would be going up the incline, opposite to the direction of Fd. So Fnet=Fd-Ff, which is where I was earlier. Then from that, I've broken Fd into it's components and now I'm stumped.
I'm still getting lost in the equation part. I just don't know what the coefficient of friction is made up of. I feel like this is just a lack of my understanding of solving vector components. I've done that before, and vector addition, but in those cases there was always clear sets of x and y to be found. In this there is only F1 and F2, a single x and y.
Also to solve with Newton's laws, you would use the second one? F=ma or F=mg?
Thanks for the help.
yes, parallel to the incline
What is Fd? The force acting opposite to Ff is F2, where F2 is mgsin theta, acting on the object . So in the x direction (take the x direction as parallel to the incline), it's F_net = F2 - Ff, but what is F_net if the object is not moving, or moving at constant velocity?
You know the force of friction is (mu_s)(N) when the object is just about to move, and (mu_k)(N) when it is moving relative to the incline, right? What is the value of N?
If the object is not moving, or moving with constant velocity, F_net = ?
Dear student,
Thank you for your question and for sharing your thoughts on the problem. It's great to see that you are taking the initiative to understand the concepts and apply them to your lab work. I will try to provide some guidance on how to approach this problem.
First, let's review the concept of coefficient of friction. It is a measure of the resistance between two surfaces in contact, and it is usually denoted by the symbol μ (mu). There are two types of coefficients of friction: static and kinetic. The static coefficient of friction is the force required to overcome the initial resistance and start the motion between two surfaces, while the kinetic coefficient of friction is the force required to maintain the motion of the two surfaces at a constant velocity.
In your problem, you are given the angles at which the wooden board starts to move (18 degrees) and maintains a constant velocity (13.6 degrees) when different objects are placed on it. This means that the angle of inclination of the board is directly related to the coefficient of friction between the board and the object. The larger the angle, the smaller the coefficient of friction and vice versa.
To solve for the coefficients of friction, you will need to use the equation: μ = tanθ, where μ is the coefficient of friction and θ is the angle of inclination. In this case, μ will represent either the static or kinetic coefficient of friction, depending on which angle you are using.
For example, if you want to solve for the static coefficient of friction, you will use the angle of 18 degrees and the weight of the object to calculate the force required to overcome the initial resistance and start the motion. This force will be equal to the coefficient of friction multiplied by the normal force (Fn = Fg - Ff). You can then rearrange the equation to solve for μ.
Similarly, for the kinetic coefficient of friction, you will use the angle of 13.6 degrees and the weight of the object to calculate the force required to maintain the motion at a constant velocity. Again, this force will be equal to the coefficient of friction multiplied by the normal force. You can then rearrange the equation to solve for μ.
I hope this helps to clarify the concept and guide you in your lab work. Remember to always check your units and be careful with your calculations. Good luck!
What is the coefficient of friction?
The coefficient of friction is a measure of the amount of resistance between two surfaces in contact with each other. It is a dimensionless quantity and is represented by the symbol "μ".
How is the coefficient of friction measured?
The coefficient of friction can be measured using a device called a tribometer, which applies a known amount of force to two surfaces and measures the resulting frictional force. It can also be calculated by dividing the force required to move an object by its weight.
What factors affect the coefficient of friction?
The coefficient of friction is affected by several factors, including the nature of the surfaces in contact, the amount of force applied, the temperature, and the presence of any lubricants or contaminants on the surfaces.
Why is measuring the coefficient of friction important?
Measuring the coefficient of friction is important in many industries, including engineering, transportation, and manufacturing. It helps determine the suitability of materials for different applications and can also be used to improve the performance and efficiency of machines and processes.
How is the coefficient of friction used in everyday life?
The coefficient of friction is used in everyday life in various ways, such as in the design of tires for vehicles, the selection of flooring materials for buildings, and the development of non-slip surfaces for safety purposes. It also plays a role in sports, such as determining the grip of a ball on a surface.
