Mechanics - particle in a potential
2 replies · 2K views
Pagan Harpoon
Find the equation of motion for a particle moving in a potential [tex]U(x)=Vtan^2(ax)[/tex] with V>0. The motion occurs in one dimension.
[tex]\frac{\partial L}{\partial x}=\frac{d}{dt}\frac{\partial L}{\partial\dot{x}}[/tex] (*)
[tex]L=\frac{1}{2} m\dot{x}^2-Vtan^2(ax)[/tex]
By taking derivatives of this and applying (*), it is easy to arrive at the differential equation:
[tex]\ddot{x}=-\frac{2Va}{m} \frac{sin(ax)}{cos^3(ax)}[/tex]
but this isn't much use because there's no way I can solve that.
So another approach I tried is this:
[tex]L=E_k-U(x)=(E-U(x))-U(x)=E-2U(x)[/tex]
Where E is constant.
Now apparently [tex]\frac{d}{dt}\frac{\partial L}{\partial\dot{x}}=0[/tex] because [tex]\dot{x}[/tex] doesn't appear in L. So,
[tex]0=\frac{\partial L}{\partial x}=-\frac{2Va}{m} \frac{sin(ax)}{cos^3(ax)}[/tex]
But this can't be right, because it implies that x=n/aPi where n is an integer. Clearly, x should be a function of time, x_0 and v_0 and not a constant. However, I can't identify what is wrong with the analysis I did.
Thank you.
There is potential, so the force is conservative. The energy is conserved, T+V = E. You can get the velocity, v= dx/dt in terms of x: dx/dt = f(x). You can solve this differential equation in principle, to get the equation of motion in terms of the time.
ehild
