Miller Index Problem - Is it (102) or (112)?
  • Context: Undergrad
  • Thread starter Thread starter Carolyn
    Index
9 replies · 11K views
Carolyn
Can somebody tell me what is the miller index for the tilted plane?
Nothing seems to fit...
I wonder if we can even describe it with miller index?
Please download the picture here in pdf format:
http://www.megaupload.com/?d=F8J344BH
Thanks!
Every plane has a Miller index. A common way to find the Miller index for a plane in a cubic system is to take the reciprocal of the axis intercepts and normalize the result so it contains only integers. Negative intercepts are treated by putting a bar over the number. For example, the y-intercept in your figure is at -1.
thanks for the reply. But could you explain why is the y intercept for the triangular plane -1? it does not seem to intersect with the y axis?
The plane continues on to infinity; if you follow the line in the y-z plane, you'll see that it (and therefore the plane) intersects the y-axis at -1. Use the same approach for the other axes.
um..so are you saying that I can extend the vector so it eventually intersects with the y-axis?
so the miller index should be (1-12)?
Yes; a [itex](1\bar 1 2)[/itex] plane (a member of the family of [itex]\{112\}[/itex] planes), with surface normal vector [itex][1\bar 1 2][/itex] (a member of the family of [itex]\langle 112\rangle[/itex] directions).
But, for example, this picture is also (1,-1,2). so are they a family?
More than another member of a family; that's the same plane.
ok. I think I am getting it, thanks a lot.
