MHB Min(a, b) expressed in terms of absolute value
  • Thread starter Thread starter mathdad
The discussion centers on expressing the minimum function, min(a, b), in terms of absolute values, specifically as min(a, b) = (a + b - |a - b|)/2. This formula is verified with specific examples, including a = 6 and b = 1, confirming that min(6, 1) equals 1. The conversation also explores the conditions under which this formula holds true, such as when a < b, b < a, or a = b, and proposes a similar formulation for the maximum function, max(a, b) = (a + b + |a - b|)/2, which is validated through various cases.
  • Understanding of absolute value properties
  • Familiarity with basic algebraic expressions
  • Knowledge of real numbers and their comparisons
  • Ability to manipulate mathematical equations
  • Study the properties of absolute values in mathematical expressions
  • Learn how to derive and simplify functions involving min and max
  • Explore the implications of piecewise functions in calculus
  • Investigate the applications of min and max functions in optimization problems
Mathematicians, students studying algebra, and anyone interested in mathematical functions and their properties, particularly in optimization and real analysis.
mathdad
Given two real numbers a and b, the notation min(a, b) denotes the smaller of the two numbers. In cases where a = b, then min(a, b) denotes the common value of a and b. It can be shown that min(a, b) can be expressed in terms of absolute value as follows:
min(a, b) = (a + b - | a - b |)/2
Verify this equation in the following case:
a = 6 and b = 1
Solution:
m(6, 1) = (6 + 1 - | 6 - 1 |)/2
m(6, 1) = (7 - | 5 |)/3
min(6, 1) = (7 - 5)/2
m(6, 1) = (2/2)
min(6, 1) = 1
We can say that if a = 6 and b = 1, then the smallest of the two numbers is 1.
Question:
Can this be done with expressions?
For example, if a = 2x and b = 3x, can we use the above equation to find min(a, b)? What about max(a, b)?
Mathematics news on Phys.org
Before we move onto expressions, do you see how the given formula works? Try simplifying the min() function under the assumptions:
a) $$a<b$$
b) $$b<a$$
c) $$a=b$$
What do you find? Can you put forth a hypothesis for a max() function?
When b < a
a = 6 and b = 1
Solution:
m(6, 1) = (2/2)
min(6, 1) = 1
We can say that if a = 6 and b = 1, then the smallest of the two numbers is 1. The function confirms that b is the minimum value.
When a < b
m(1, 6) = (1 + 6 - | 1 - 6 |)/2
m(1, 6) = (7 - | -5 |)/2
m(1, 6) = (7 - (5))/2
m(1, 6) = 2/2
m(1, 6) = 1
The function confirms that a is the minimum value.
When a = b
m(4, 4) = (4 + 4 - |4 - 4 |)/2
m(4, 4) = (8 - |0|)/2
m(4, 4) = 8/2
m(4, 4) = 4
When a = b, the function shows that both a and b share a common number or value.
I cannot come up with a hypothesis in this case. For me at this level of math, the function is just a plug and chug to confirm a max or min value.
What I meant was to do something like the following:
We are given:
$$\min(a,b)=\frac{a+b-|a-b|}{2}$$
a) $$a<b\implies a-b<0$$
And so the min() function becomes:
$$\min(a,b)=\frac{a+b+(a-b)}{2}=\frac{2a}{2}=a$$
b) $$b<a\implies 0<a-b$$
$$\min(a,b)=\frac{a+b-(a-b)}{2}=\frac{2b}{2}=b$$
c) $$a=b$$
$$\min(a,b)=\frac{b+b-(b-b)}{2}=\frac{2b}{2}=b=a$$
About our hypothesis, look at how the min() function behaves in the 3 scenarios above...what do you think we can do the the min() function to get it to be a max() function?
I'll get back to you later. Happy Father's Day.
My guess is to maximize the given function we replace subtraction with addition in the numerator.
max(a, b) = (a + b + | a - b |)/2
Yes?
Yes?
Test it the way I did for the min() function in post #4...:D
I do not know how to test it as demonstrated in post 4. Can you show me?
We are testing:
$$\max(a,b)=\frac{a+b+|a-b|}{2}$$
And so the max() function becomes:
$$\max(a,b)=\frac{a+b-(a-b)}{2}=\frac{2b}{2}=b\quad\checkmark$$
$$\max(a,b)=\frac{a+b+(a-b)}{2}=\frac{2a}{2}=a\quad\checkmark$$
c) $$a=b$$
$$\max(a,b)=\frac{b+b+(b-b)}{2}=\frac{2b}{2}=b=a\quad\checkmark$$
So, we conclude our hypothesis is correct in all possible cases.
Suppose we now consider:
$$\min(px,qx)$$
What does the formula give us? How many cases can we check?
min(px, qx).
min(px, qx) = (px + qx - | px - qx|)/2
min(px, qx) = (pqx - (px - qx))/2
min(px, qx) = (pqx -px + qx)/2
min(px, qx) = x(pq - p + q)/2
I am stuck here.
RTCNTC said:
min(px, qx).
Okay, I agree we have:
$$\min(px,qx)=\frac{px+qx-|px-qx|}{2}$$
In your next step, you have somehow combined:
$$px+qx=pqx$$
Which is not true in general, and also you have removed the absolute value without given any conditions on p, q, or x. As our next step, we could write:
$$\min(px,qx)=\frac{(p+q)x-|(p-q)x|}{2}$$
We may use the identity:
$$|uv|=|u||v|$$
(which you should verify using the radical definition for absolute value)
to write:
$$\min(px,qx)=\frac{(p+q)x-|p-q||x|}{2}$$
Okay, now we will have 6 cases to check...looking at the above formula, can you explain the conditions giving rise to all six cases?
I did not know the rule |vu| = |v| |u|.
I don't understand.
I don't understand.
If we try to remove the absolute values...what do we need to be concerned about?
Removing the absolute value bars yields a 0 in the numerator.
How?
(p + q)x - | p - q ||x|)/2
(p + q)x - (p + q)|x|)/2
[(px + qx) -px -qx]/2
(px + qx - px - qx)/2
0/2
0/2
How do you justify:
$$|p-q|=p+q$$ ?
I give up! Can you show me what you mean?
  • · Replies 48 ·
  • · Replies 19 ·
