Minimizing function in Matlab and C
  • Topic: MATLAB
  • Thread starter a.mlw.walker
    Function Matlab
78 replies · 21K views · last reply
a.mlw.walker
The foloowing code is the MATLAB code to minimize a function using the nelder mead method.
Code:
Starting=[1 1 -1]; options=optimset('Display','iter'); Estimates=fminsearch(@myfit,Starting,options,t_d,Data) Calling: function sse=myfit(params,Input,Actual_Output) a=params(1); b=params(2); c=params(3);
Fitted_Curve = (1/(a*b))*(c-asinh(sinh(c)*exp(a*Input*2*pi)));
Error_Vector=Actual_Output-Fitted_Curve ;
sse=sum(Error_Vector.^2);
This is supposed to be the equivalent C code, however it doesn't produce the same results. Can anyone see what I may have done wrong?
Code:
static double function(int n, double x[])
	double c;
    double Fitted_Curve[5];
    double Error_Vector[5];
    int i;
    double a, b, sum = 0;
    double  v1[5], v2[5], geom_inv[5], norm = 0, norm_2 = 0, v2sum = 0, x_coeff = 0;
//    Actual_Output[5] = {1.2, 2.693, 4.325, 6.131, 8.125};
a = x[0];
b=x[1];
c=x[2];
    for (i = 0; i <= 4; i++)
      Fitted_Curve[i] = (1/(a*b))*(c-asinh(sinh(c)*exp(a*Input[i]*2*pi)));
      Error_Vector[i] = Actual_Output[i]-Fitted_Curve[i];
          sum = sum + Error_Vector[i]*Error_Vector[i];
      printf("sum = %f\n", sum);
      a_global = a;
      b_global = b;
     // x_coeff_global = x_coeff;
      return sum;
Thanks
Hi a.mlw.walker! :smile:
The C function that you're showing is functionally a match for the myFit() function that you specified as MATLAB code.
Do you also have an implementation of the fminsearch() function?
If so, what does it expect as input?
the fminsearch function is a MATLAB function implementing the NelderMead algorithm. I know the MATLAB is correct because I have the solution. However the C does not produce the same final result but does produce the same first result!
Matlab produces:
a = 0.0250 b= 1.8944 c= -0.3690
C code produces
a = 3.52, b = 3.634 c= -0.000073
Check the pics:
  • Console output from a C program listing Fitted_Curve and Error_Vector values over ten iterations, ending with a line reading sum= 24.381597.
  • MATLAB console output showing Fitted_Curve values 6.1378, 12.4210, 18.7041, 24.9873, 31.2705; Error_Vector values -4.9378, -9.7280, -14.3791, -18.8563, -23.1455; and sse = 24.3816.
You pictures seem to basically show that the C function is indeed a match for the MATLAB function.
So either your fminsearch is not doing its work like it does in matlab.
Or, what seems more likely, the parameters are syntactically not passed properly to the function.
Or the boundary conditions are not set properly.
Did you already print the values of a, b, and c during the iterations?
What are the values in your Input[] array?
Did you already check if the given solution by the C code is actually a solution for the problem, since it may have found another minimum (if your boundary conditions are set up differently)?
I'll get it to print earlier values of a, b and c and post them. Yeah i plotted the points found by C and it doesn't find a curve that fits. input is just [1 2 3 4 5], that's what it is in both MATLAB and C.
Its a strange error considering the values for the first iteration are the same, but I know the Matlab is correct, I have the solution to that from previous work - and it is a solution. The problem is in the C.
I'll get a b and c for the first iteration
While you're at it, also print the values of 'sum' (the sse) in your function, since we'd like to see if it converges or not.
Ok here we go. three iterations of both, MATLAB in white, c in black...
  • Console output of a C program printing lines labelled Fitted_Curve, Error_Vector and sum with decimal values, in white text on a black background.
  • MATLAB command window output showing three optimisation iterations, each listing Fitted_Curve, Error_Vector and sse values, with iteration 0 header showing min f(x) 1217.05.
I'm just noticing that in all your pictures the sum/sse does not match the Error_Vector.
The sum/sse should be the sum of the squared entries of the Error_vector.
In all cases (except perhaps the last) it isn't.
In your original 2 pictures the sum and sse appear to be the square of only the first entry in the Error_Vector.
So what did you print for the sum/sse?
In your last 2 pictures, there are 5 sums displayed in the console dump.
They appear to be the squares of the individual Error_Vector entries, but they should still be added.
In the MATLAB output, there is only one sse, that may well be the sum needed.
This means the code you have shown in the opening post apparently does not match the code you have just executed.
The original images were just to see whether it was doing the sum my calculator was expecting - i.e just the first Error_Vector^2. The latest images (my last post) is the actual output after three iterations from NelderMead. look at the latest images.
Sorry your right, the C code for sum is not producing the correct values...
Yes, I believe I have.
The displayed sums for 1 iteration need to be added, and that has to be used as the result.
That should match the MATLAB output.
Hmm, sorry I had removed that in a recent debugging session. I have put it back in, and attached again the first three iterations, but its still not right
I have changed the sum code to
Code:
        printf("sum= %f\n", sum);
  • Console output listing Fitted_Curve, Error_Vector and running sum values, printed as text lines on a black background.
All right.
Now it shows the same result for the first iteration as matlab.
As you can see, it also converges.
But it converges much faster than the MATLAB version.
This suggests that you're using a different algorithm.
Since you've presumably used a function with the same name (fminsearch), do you have the option of giving method-parameters?
What you have in C might for instance be the Conjugate gradient method.
(You did use a function by the name of fminsearch didn't you?)
The function for the C is called NelderMead.c. Fminsearch is a built in MATLAB function that according to Matlab is the Neldermead method. I'm not bother how fast it converges if the answer isn't correct though...
There could be more than one solution.
Could you show the final a, b, c, and sse to judge that?
And perhaps you could also show the a, b, and c in each iteration to see how the algorithm progresses?
I just checked.
Your problem does have multiple solutions.
So perhaps you want the solution closest to your initial guess?
Or doesn't it matter to you?
really, mulitple solutions? i tried the values i earlier posted and it did not produce a solution - I am looking for a curve to fit data points, and the curve those values gave did not fit the data like the matlab
Ah, I missed your solutions for a, b, c before.
They are both solutions.
The MATLAB version has an sse = 0.0037.
The C version has an sse = 0.099
This suggests that the C version stopped at a tolerance of 0.1.
You can probably tweak your parameters somewhere.
Btw, you should know that your data is almost on a straight line, and that whatever parameters you feed your formula, it's also almost a straight line.
So I think you shouldn't expect very interesting solutions.
What are you using this for?
My boss wanted me to research finding parameters that will fit the curve to an equation. I agree the data is basically on a straight line, however the Matlab code gets the solution I am expecting the C goes off in a completely different direction, even though the methods are supposed to be the same. If it is as simple as the c is finding a different route then what can I do about it - the MATLAB is finding the right one?
By the way I have attached two graphs, the left is the atlab the right is the C, MATLAB is a much better ft...
  • Two side-by-side line plots of data points with fitted red curves: left, a slightly curved fit through points near the line; right, a straight-line fit with a flat segment from 0 to 0.5 on the x-axis.
Guys what do you reckon. My graph above shows that my code may be finding a minimum of sorts, but that is not a good curve. I think it is finding a local minimum as supposed to the global minimum. Interesting that the MATLAB implementation finds the global minimum. The following website states that nelder mead method can fail in simple situations. i wonder if MATLAB is doing "more" than just a nelder mead. i have heard the rosenbrock algorithm can find global minimum, anyone used it? Or an ant search or something? anyone used that?
Ok i have noticed something. In the file neldermead.c on line 29 it says
Code:
static dbl	al = 2, bt = 0.5, gm = 1;
these are parameters that control the adjustments made by the algorithm.
Matlab has a similar line, however the variable names are different. I fiddled with the values (just changing which one was equal to 1,2 and 0.5) and I get the correct answer for the three parameters I have been looking for, however using an alternative function to solve for, and it gives incorrect results again.
My last post tho - about the parameters in NelderMead, swapping this around got me a solution to the function - the correct one, however for another function I have written it does not solve it correctly once I change these values.
When I change them back (static dbl al = 1, bt = 0.5, gm = 2, the second function works!
I think the method may be finding local minimums and when i swap the parameters it adjusts to a global minimum! Wotz goin On!
I can think of 2 things.
First your C version uses a threshold of 0.1.
You should be able to find this threshold somewhere and adjust it.
Then you can probably get a better fit.
Second the MATLAB algorithm has an "options" parameter.
Among others it specifies an algorithm to use (I think).
With the right option, you should be able to get a fit that is as close to the initial guess as possible (I think that would be something like Levenberg-Marquardt).
Finally, you just have a formula for a curve that just won't fit very well when the curve is almost a straight line and you data points are almost a straight line.
did you look at post #21? the image of the MATLAB fits is great, the C one not so good. I am working on it, I'll see if i get anywhere...
Yes, the C one has a tolerance of 0.1, which is bigger than the MATLAB one...
And apparently the algorithm doesn't try to stay close to the initial gues...
Have you seen the 0.1 tolerance anywhere, because I can't find it.
I only saw it in the result (as posted earlier).
It has to be somewhere in your neldermead.c file, or another one that is used by it.
Since I do not have access to this file I can't tell you.
would you like access to the files? i only haven't put them because its quite a lot of code. right now i am trying to get rid of all my global variables so it doesn't compile right now, because i have an error I am not sure about. but i can give it to you if your knowledge of c is any better than mine?
