Minimizing function in Matlab and C
  • Topic: MATLAB
  • Thread starter Thread starter a.mlw.walker
    Function Matlab
78 replies · 20K views
According to the web page:
reason 7 = stopped by invalid (i.e. NaN or Inf) "func" values; a user error
return value -1 = no iterations performed.
As you can see you have a Fitted_Curve of 1#.QNAN0, meaning your calculation failed.
You're somehow feeding your function data that it can't calculate.
I see no reason for that, so I think you made a programming error.
Can you show your function as it is now, and also the values you're feeding it, and the Fitted_Curve/Error_Vector results, when it gives the 1#.QNAN0?
Note that the only possible reason that you might not be able to calculate the result, is if you have either parameter a or b given as zero.
definitions out side of functions:
Code:
#define pi 3.141592653589793238462643
double Input[5] = {0, 1, 2, 3, 4};
double Actual_Output[5] = {1.2, 2.693, 4.325, 6.131, 8.125};
Function
Code:
static double function(double *p, double *x, int m, int n, void *data)
    double Fitted_Curve[5] = {0};
   // double Error_Vector[5] = {0};
    int i;
    double a, b, c;
a = p[0];//parameters
b=p[1];
c=p[2];
  for (i = 0; i <= 4; i++)
    Fitted_Curve[i] = (1/(a*b))*(c-asinh(sinh(c)*exp(a*Input[i]*2*pi)));
    x[i] = Actual_Output[i]-Fitted_Curve[i];
    printf("a(x[0]) = %f, b(x[1]) = %f, c(x[2]) = %f\n",p[0], p[1], p[2]);
    printf("Fitted_Curve= %f\n", Fitted_Curve[i]);
    printf("Error_Vector= %f\n", x[i]);
main:
Code:
int main()
register int i;
int problem, ret;
double p[3] = {0,0,0};
double x[5] = {0,0,0,0,0};
int n = 5;
int m;
double opts[LM_OPTS_SZ], info[LM_INFO_SZ];
char *probname[]={
    "function"
  opts[0]=LM_INIT_MU; opts[1]=1E-15; opts[2]=1E-15; opts[3]=1E-20;
  opts[4]= LM_DIFF_DELTA; // relevant only if the Jacobian is approximated using finite differences; specifies forward differencing
  //opts[4]=-LM_DIFF_DELTA; // specifies central differencing to approximate Jacobian; more accurate but more expensive to compute!
  problem=
		  0; // Can have more functions if user requires
#ifdef HAVE_LAPACK
#else // no LAPACK
#ifdef _MSC_VER
#pragma message("LAPACK not available, some test problems cannot be used")
#else
#warning LAPACK not available, some test problems cannot be used
#endif // _MSC_VER
#endif /* HAVE_LAPACK */
  switch(problem){
  default: fprintf(stderr, "unknown problem specified (#%d)! Note that some minimization problems require LAPACK.\n", problem);
           exit(1);
    break;
  case 0:
  /* function */
    m=3;
    p[0]=1.0; p[1]=1.0; p[2]=-1.0;
    for(i=0; i<n; i++) x[i]=0.0;
    //ret=dlevmar_der(ros, jacros, p, x, m, n, 1000, opts, info, NULL, NULL, NULL); // with analytic Jacobian
    ret=dlevmar_dif(function, p, x, m, n, 100000, NULL, NULL, NULL, NULL, NULL);  // no Jacobian
  break;
  } /* switch */
  printf("Results for %s:\n", probname[problem]);
  printf("Levenberg-Marquardt returned %d in %g iter, reason %g\nSolution: ", ret, info[5], info[6]);
  for(i=0; i<m; ++i)
    printf("%.7g ", p[i]);
  printf("\n\nMinimization info:\n");
  for(i=0; i<LM_INFO_SZ; ++i)
    printf("%g ", info[i]);
  printf("\n");
  return 0;
For some reason I'm not able to look at your attached screenshot.
Can you view it yourself?
Can you perhaps upload it again?
First things that attract my attention, is that the return value of your function is 'double', while it should be 'void'.
Then, I recommend initializing the info-array to zeroes.
Furthermore, you should pass the info-array as a parameter, if you want to inspect the output results.
Finally, your compiler can warn you of mistakes like these.
You should increase the warning-level of your compiler and fix mismatches such as the prototype of your function.
Which compiler do you use?
I just changed the prototype to void, and initialised infor to zero's by putting it equal to {0}.
It runs much more succesfully now - 174 iterations, but stops due to reason 2 - stopped by small Dp.
The solution isn't correct though.
I have two warnings from GCC Compiler now, but both are generated due to warnings within the code such as
#warning LAPACK not available, some test problems cannot be used.
p[0] should = 0.025
p[1] should = 1.8944
p[2] should = -0.369
The solution it has found I think is the solution from when I was using neldermead. Now I am questioning the function
I believe you used a different Input[] array before.
Shouldn't you use Input[] = {1,2,3,4,5}?
I believe an Input[0] value of 0, yields a Fitted_Curve of 0, but that was never in your output before.
Btw, it has to be a different solution than the one from Nelder-Mead.
It reports an SSE=0.0015893 which is even more accurate than what you got from Matlab!
What do you get with the Input[] array of {1,2,3,4,5}?
And if you want even more accurate results, you should use dlevmar_der() with the Jacobian specified.
Do you know how to calculate the Jacobian?
Hey, sorry I did use the correct input, i just showed you the wrong one.
So now I am confused, the MATLAB produces a different result, but not a hugely different result. Those values produce a really good fit (matlab plotter). But the original author did not get those numbers.
Now to get rid of my globals...
Well, you can expect an even better fit from your new solution. ;)
You should try it.
I have the green line is the new fit, the red is the matlab. I trust our new levmar one now more!
So this *data pointer can pass the variables required by the function. Do you know how its used?
Also I have another minimization I would like to use levmar for, however it is the sum of the modulus of the function as supposed to the sum of the squares, I know that if you square and squareroot a function it is like the modulus, but will it make any difference?
You seem to have left out the picture...
To minimize the sum of absolute values, I guess you can make it work by returning the square root of the absolute value of each Error_Vector.The *data pointer should be used to pass your Actual_Data[5] array.
It's like this:
Code:
void function(..., void *adata)
   double *Actual_Data[5] = (double *)adata;
main()
   double Actual_Data[5] = {...};
   int ret = dlevmar_dif(..., Actual_Data);
forgot graph...
Im getting an error on this line:
Invalid Initializer.This function (my other function) runs but produces very different values from the matlab
Code:
void function2(double *p, double *x, int m, int n, void *data)//equations for parameters eta, phi and omega^2 that hold wheel properties
double c1[23], x_coeff_2[23], v1[23], v2[23];
double eta = p[0]; //parameters
double phi=p[1]; //parameters
double omega_2=p[2]; //parameters
int i;
a_global = 0.025;
b_global = 1.8944;
//c_global = -0.3690;
for (i = 0; i<23; i++)
    v1[i] = (exp(a_global*2*pi)-cosh(a_global*b_global*init_T[i][0]));
    v2[i] = sinh(a_global*b_global*init_T[i][0]);
    x_coeff_2[i] = v1[i]/v2[i];
    c1[i]= b_global*b_global*(x_coeff_2[i]*x_coeff_2[i]-1);
    x[i] = sqrt(fabs(c1[i]*exp(-2*a_global*init_T[i][1])+eta*((1+0.5*(4*a_global*a_global+1))*cos(init_T[i][1]+phi)-2*a_global*sin(init_T[i][1]+phi))+b_global*b_global-omega_2));
I had to adjust it from the nelder mead (where it ran) because of the way levmar wants x[] passed back to it however the nelder mead matched the matlab. This issue is reason 2 (small Dp) again
Sorry, I intended:
double *Actual_Data = (double *)adata;
Well, is it a good solution that it found?
What is info[1], which is the found SSE?
To be honest, I'm not sure Levenberg-Marquardt will work as intended with your function, since it is not intended for a sum of absolute errors, but for a sum of squared errors.
I believe it should still work, but it may not find an optimal solution.
Nelder-Mead may be a better choice for this problem (minimizing the sum of absolute errors).
Hi so I have integrated the levmar and neldermead into one program so that I can use levmar to solve function1 and neldermead to solve function 2.What about prototypes tho? When do you need them and when do you not. For instance my functions function() and function2() don't have prototypes, however some other functions do have prototypes.
My third function:
Code:
static double rotor_function(int n, double z[],float ti[6])//equations for parameters eta, phi and omega^2 that hold wheel properties
double kappa = z[0], sum = 0,Rotor_Curve[6], Error_Vector[6], v0; //parameters
int i;
v0 = (1 + (kappa/2)*ti[0]*ti[0])/ti[0];
for (i = 0; i<6; i++)
Rotor_Curve[i] = (v0*ti[i]-(kappa/2)*pow(ti[i],2));
Error_Vector[i] = (i+1) - Rotor_Curve[i];
    sum = sum + Error_Vector[i]*Error_Vector[i];
printf("\n z = %f v0 = %f, sum = %f\n", z[0], v0, sum);
    return sum;
doesnt have a prototype - however it also doesn't receive the initital guess at the parameter.
It is called like:
Code:
case 2:
  /*  function 2*/
    z[0] = 0.004;
    n=1;
    fopt = 0;
    //This is still not running correctly, check MATLAB for correct parameter values:
    if (NelderMeadSimplexMethod(n, rotor_function, z, length, &fopt, timeout, eps, ti) == success) {
		printf("reaching to minimum ");
	} else {
		printf("timeout  ");
    kappa = z[0];
i need to pass the parameter as an array though I think not a variable
As long as you define your function (including the body) before using it, you don't need a function prototype.
If you need a prototype, you'll know, because the compiler will complain he doesn't know the function.
a.mlw.walker said:
I need to pass the parameter as an array though I think not a variable
I can't recall the list of parameters to your Nelder-Mead function.
But if it doesn't have a "void *data" pointer as a parameter, you need to use a different mechanism, which is as follows.
The way to do it, is to define a global variable to pass your Actual_Data[] array.
You use this global variable in your function.
And just before you call Nelder-Mead, you copy your Actual_Data[] array into the global variable.
Neldermead function is like this:
Code:
status NelderMeadSimplexMethod(n, f, xinit, length, fopt, timeout, eps, array1)
my function that is failing is like this:
Code:
int i;
    return sum;
I am calling both like this:
Code:
z[0] = 0.004;
    n=1;
    fopt = 0;
	} else {
		printf("timeout  ");
    kappa = z[0];
It seems to me like function2 however this one doesn't ever have a value for z[0]
I found the problem. z is getting there howere the maths is going haywire! v0 is not being calculated correctly - is this because of a problem with multiplying floats and doubles?
It's weird to see a parameter like "float ti[6]".
I suspect it should be "double ti[6]".
The mismatch could cause your problems.
Don't you get a compiler warning?
What is the prototype of your Nelder-Mead function, and what function prototype does it expect exactly as a parameter?
Hey how are you, been a while.
I am working more with the levenberg marquardt code now.
I am trying to get it to use just single precision - this is an option in levmar.h
Out of interest, what happens if a variable has been declared as double but in levmar.h i state i want single precision?
when I choose single precision I get an error - a strange one at that.
Axb_core.c|1103|error: 'FLT_EPSILON' undeclared (first use in this function)
It works fine with double but not with single. I find this odd considering the author offeres single precision accuracy.
Any ideas what the problem could be?
