Minimizing poster area with fixed printed material region
2 replies · 5K views
Asphyxiated
The top and bottom margins of a poster are each 6 cm and the side margins are each 4 cm. If the area of printed material on the poster is fixed at 384 cm2, find the dimensions of the poster with the smallest area.
Area of a rectangle is length times width
So I assumed that the 384 cm2 formed a constraint like so:
[tex](a-6)(b-4)=384[/tex]
and then using this equation I solved for a to be able to substitute it into the area formula:
[tex]ab-4a-6b+24=384[/tex]
[tex]ab-4a=360+6b[/tex]
[tex]a(b-4)=360+6b[/tex]
[tex]a= \frac {360+6b}{b-4}[/tex]
so then i can substitute a in A=ab so that A will be a function of b:
[tex]A=ab[/tex]
[tex]A=\frac{360+6b}{b-4} b[/tex]
[tex]A(b)=\frac{360b+6b^{2}}{b-4}[/tex]
ok, so then i take the derivative of this A(b) now which turns out to be:
[tex]A'(b)=\frac {6b^{2}-48b-1440}{(b-4)^{2}}[/tex]
then i take the top, complete the square and then set it equal to zero:
[tex]6(b-4)^{2}-1536 = 0[/tex]
[tex]6(b-4)^{2} = 1536[/tex]
[tex](b-4)^{2} = 256[/tex]
[tex]b-4 = \sqrt{256}= \pm 16[/tex]
[tex]b= \pm 16 +4[/tex]
I chose to leave out the negative square root as it makes no sense when we are talking about lenth, so with b=20, take that back and plug it into the a=b equation:
[tex]a = \frac {360+6(20)} {20-4} = 30[/tex]
and I get a = 20 and b=30 and if you take off the margins and multiply them at 16*24 you get 384 cm2, but alas, this is not correct. Where did I go wrong at?
[tex]A=ab[/tex]
Right near the beginning (emphasis added).
Your equation (a - 6)(a - 4) = 384 doesn't take into account the two horizontal and two vertical margins.
thanks, came out right this time, now i got another question posted though... lol
