Minimum Applied Force for Block and Cart Dynamics Problem
  • Thread starter Thread starter Felafel
    Dynamics
4 replies · 2K views
Felafel
I've solved it already, I think. I'm just not sure about the result.
There is a block (B), which is touching a cart (C) on one side.
Let an external force, parallel to the surface, ##\vec{F_a}## be applied on B
mass of B = m; mass of C = M; static friction coefficient between B and C = μ.
Taking no notice of the ground's friction, what is the minimum value of ##\vec{F_a}## such that the block doesn't fall?
After drawing the free-body diagram for B, i see:
##\vec{F_s}## (static friction force) ##\leq m \cdot \vec{g}##
and being ##\vec{F_s}=μ \cdot \vec{F_N}## i get ##\vec{F_N}= \frac{m \cdot \vec{g}}{μ}##
##\vec{F_a}=\vec{F_N} + \vec{F_f}## the latter being the force applied to C, which makes it move.
##\vec{F_f}=\frac{\vec{F_N}}{M} * m## . So,
##\vec{F_a}=\frac{m \cdot g}{μ}+ \frac{m^2 \cdot g}{μ \cdot M}##
is it okay?
You made some little errors.
##\vec{F_s}## (static friction force) ##=-m \cdot \vec{g}##
##{F_s}\leq \mu \cdot {F_N}##
is it okay?
The minimum value of Fa is the question. So ##F_a\geq\frac{m \cdot g}{μ}+ \frac{m^2 \cdot g}{μ \cdot M}##
ehild
##\vec{F_f}=\frac{\vec{F_N}}{M} * m##.
Can you explain these two steps? I don't follow what you did here.
As vela notes, this is wrong. Try introducing an unknown for the acceleration of the system and developing the F=ma equation for each body separately.
Felafel said:
{μ}##
is it okay?
You meant by Ff the resultant force acting on B instead of C, didn't you?
haruspex: The OP solved the problem, but made some little errors when typing in. The result for the minimum applied force is correct, except the vector sign.
ehild
