Minimum energy uncertainty from lifetime using uncertainty principle
SAT2400
Uncertainty Principle Questions!PLease HELP!
1. Since a charged pi meson at rest exists on average for only 26 ns, its energy cannot be measured with unlimited precision. Determine the minimum uncertainty in the meson's rest energy.
2. Determine the minimum uncertainty in energy of an atomic state if the state lasts for .10 us?
delta(E) *delta(t) = h/2pi
1. answer is 2x10^-27J..but I don't know how to get this answer.
2. answer is 5.3 x10^-28J..I don't know how to get this answer using the equation above.
I used h=6.63 x10^-34...but didn't get the right answers..
Please help!
Go back and check your references on the uncertainty principle; you have the equation wrong. It should be
[tex]\Delta E \Delta t = \frac{\hbar}{2}[/tex]
ok. but h=6.63x10^-34Js? right? 26ns should converted into what?
Again just make sure the units balance
energy (J) * time (s) = h_bar (Js) / 2
So you just need time in seconds, 26ns is 26x10^-9 s
Note that h_bar is h/2pi
There should be an approximate sign in the above equation, not an equal sign.
[tex]\Delta E \Delta t \approx \hbar[/tex]
There is a more formal equation for the minimum uncertainty (and it is slightly different than the above equation). It involves the the standard deviations of E and t (normally represented by [itex]\sigma _E[/itex] and [itex]\sigma _t[/itex] respectively), and it contains an 'equals' sign*. There is also a unit-less constant involved too, but you can look up the equation and you'll know what I'm talking about.
*The general form of the formal uncertainty equation involves a [tex]\geq[/tex] sign, but since we're talking about minimum uncertainty, it reduces to an = sign for this special case.
(By the way, [itex]\hbar = h/2 \pi[/itex].)
2. answer is 5.3 x10^-28J..I don't know how to get this answer using the equation above. I used h=6.63 x10^-34Js and .1x10^-6s?...but didn't get the right answers..
Please show your work. :-p
Okay, somebody has essentially given you that
[tex]\sigma _E \sigma _t \geq \frac{\hbar}{2}[/tex]
and [itex]\hbar[/itex] = 1.054571628×10-34 J·s.
So you know [itex]\sigma _t[/itex] and [itex]\hbar[/itex], so the minimum possible [itex]\sigma _E[/itex] must be... :wink:
