Finding the Parameters for the Curve y=asin(x-b)+c
The discussion revolves around the curve described by the equation y = asin(x-b)+c, with a focus on identifying parameters a, b, and c based on the minimum point of the curve and transformations applied to it. The original poster presents a diagram showing the curve and its minimum point at coordinates (–2, –1), and seeks clarification on how transformations affect these coordinates.
  • Participants explore how transformations such as horizontal shifts and vertical scaling affect the coordinates of the minimum point. Questions arise regarding the interpretation of the transformations and their impact on the function's parameters.
Some participants provide hints and guidance on understanding the transformations, while others question the original poster's assumptions and interpretations. There is ongoing exploration of the correct values for a, b, and c, with no clear consensus reached yet.
Participants note that the original poster's answers may not align with the expected outcomes based on the transformations described. There is a suggestion to separate different parts of the question into distinct threads for clarity.
Natasha1
<Moderator's note: Member has been informed to separate different question into different threads in the future.>
1. Homework Statement
Please see picture attached...
The diagram shows the curve with equation y = f (x)
The coordinates of the minimum point of the curve are (–2, –1)
(a) Write down the coordinates of the minimum point of the curve with equation
(i) y=f(x–5)
(ii) y = 0.5 f ( x )
The graph of y=asin(x–b)+c (please see graph on picture)
b) Find the value of a, the value of b and the value of c.
(i) y=f(x–5) Does the -5 move the graph 5 units to the right? Why is this? So the coordinates are (-7, -1)
(ii) y = 0.5 f(x) Does the times 0.5 widen the curve and has no impact on the minimum point so would stay (-2, 1)
Is a the magnitude? so a = 1
Is b the phase shift so -b shifts the graph by b units to the right so b = 360
Is c the vertical shift which is c = -1
Please explain :). Thank you in advance...
(i) y=f(x–5)
Even though these are shown as parts (a) and (b) on the image, the parts have almost nothing in common and it would make sense to post each part in a separate thread.
Graph for part (a):
Graph for part (b):
Hint for Part (a):
You should know the value of ƒ(−2). Right?
So, what value must x have in order for ƒ(x − 5) to give the value of ƒ(−2) ?
Graph for part (a):
View attachment 239951Graph for part (b):
SammyS said:
Hint for Part (a):
ƒ(−2) = -1
So, what value must x have in order for ƒ(x − 5) to give the value of ƒ(−2) ? I don't know ƒ(x − 5) = -1
Natasha1 said:
ƒ(−2) = -1
Then, what value must x have so that (x − 5) = −2 ?
x = 3
x = 3
Natasha1 said:
x = 3
Right.
So, if you are graphing ƒ(x−5), then when x = 3, y = ƒ(3 − 5) = ƒ(−2) = −1 , does it not?
Thus, the graph of y = ƒ(x−5) is just like the graph of y = ƒ(x), except that
the graph, y = ƒ(x−5) is shifted 5 units to the right as compared to the graph of y = ƒ(x) .
Thanks SammyS but what about the rest of my work?
Most of your answers are incorrect.
(a) : (i)
It is true that the graph, y = ƒ(x − 5), is obtained from the graph, y = ƒ(x), by shifting the latter by 5 units to the right, which is what you said, but then your answer of (−7, −1) for the coordinates of the vertex (a minimum) is incorrect. You need to shift the graph, not the coordinate system. Also, I gave you some idea of how to think of this as a shift.
(a) : (ii)
While it is true that multiplying ƒ(x) by 0.5 gives a graph that appears to be widened (at least for this function), what multiplying by 0.5 actually does is to "shrink" the graph vertically. This is because for any particular x value, the y value for y = 0.5ƒ(x) is one half of the y value for y = ƒ(x) .
Part (b) answers are incorrect.
Are the answers correct please?
(i) y=f(x–5) Does the -5 move the graph 5 units to the right? Why is this? So the coordinates are (3, -1)
(ii) y = 0.5 f(x) Does the times 0.5 widen the curve and has no impact on the minimum point so would stay (-2, -1)
Is a the magnitude? so a = 3
Is b the phase shift so -b shifts the graph by b units to the right so b = 60
Is c the vertical shift which is c = 0 (as there is no vertical shift)
  • · Replies 19 ·
