Minimum Velocity only given distance
  • Thread starter Thread starter tripletrouble
    Minimum Velocity
5 replies · 16K views
tripletrouble
Minimum Velocity only given distance!
A soccer ball is kicked by a goalie to a position that is 65 meters down field. What is the minimum velocity necessary to achieve this feat?
v2=vf2+2a(x-xo)
v2=02+2a(65m)
Assuming no air resistance, the velocity required will be a minimum what the launch angle is 45 degrees above the horizontal. Use the range equation.
But no degree angle is specified, does it still have to be 45 degrees? you can still kick a ball and have it roll horizontally
True; I thik the statement of the problem implies that the ball is kicked at some angle above the horzontal and when it returns to the ground, it has convered a horizontal distance of 65m.
But to use an angle you need an initial velocity, no? None is specified. My professor said that this problem was very difficult and had a trick to it. There's a part b) that says "if it was kicked at 50 degrees instead" where would the ball land?
that might be the clue, so perhaps there's an implied angle?
Well, how about this. The range equation is
R = [tex]\frac{V_{0}^{2} sin 2\theta}{g}[/tex]
If you solve the equation for Vo and differentiate the result with respect to theta (dVo / dtheta), set it equal to zero and solve for theta, you get 45 degrees. That proves that the min speed for a given range occurs when theta is 45 degrees.
If you then solve the range equation for Vo and substitute 45 degrees,
([tex]V_{0}[/tex]) min = [tex]\sqrt{R g}[/tex]
