Modular mathematics - what is 7^(-1) mod 10
  • Thread starter Thread starter Woolyabyss
    Mathematics
5 replies · 7K views · last reply
Woolyabyss
Sorry,
This isn't a homework question. I'm just having trouble understanding some of the notes I've taken down.I'd really appreciate if some of you could help me understand this.
________________
1/3 is that number with the property
(1/3)(3) = 1
what is 7^(-1) mod 10?
7^(-1) ≡ 3 mod 10
because 7 * 3 ≡ 1 {21 - 2(10)= 1}
____________
Is it ≡ to 3 because 7 by 3 gives you 1 like in the case of 1/3.
but I'm not multiplying 7^(-1) by 3?
If someone could help me understand this it would be really appreciated.
Woolyabyss said:
Sorry,
________________
(1/3)(3) = 1
7^(-1) ≡ 3 mod 10
____________
Well, the explanation depends on what you want to use a starting point. If you want to start from the answer, [itex]7^{-1} ≡ 3 mod 10[/itex] and just check that it is correct, it is quick. We just multiply both sides and check if they are equal, modulo 10. The left side is [itex]7 \times 7^{-1} =1[/itex]
and the right side is 7 x 3 = 21 which is indeed 1 modulo 10. So that checks out.
Now, let's say we did not know the answer. Then we could start with
[tex]7 \times \frac{1}{7} =1 \text{ mod } 10[/tex]
We want an integer value for [itex]1/7[/itex] modulo 10 and of course it won't work if we use 1 as the right hand side. So we now try the next possibility for 1 mod 10, which is 11. So we have
[tex]7 \times \frac{1}{7} = 11 \text{ mod } 10[/tex]
Again, we get a non integer solution. We try the next possibility for 1 mod 10, which is 21. So now we have
[tex]7 \times \frac{1}{7} = 21 \text{ mod } 10[/tex]
and we get
[tex]\frac{1}{7} = 3 \text{ mod } 10[/tex]
and we get
Thanks, I understand it a lot better now.
To check if 7-1=3 mod 10, apply modular arithmetic when multiplying i with 7:
3(mod 10) x 7(mod 10) =1 mod 10 ehild
Another way of doing it: if x= 7-1 (mod 10) then 7x= 1 (mod 10). Now you could try x= 0 to 9 to see which works.
Or you could write 7x= 1+ 10n for some integer n. That is the same as 7x- 10n= 1, a "Diophantine" equation.
Use the "Euclidean algorithm" to solve that equation-
7 divides into 10 once, with remainder 3: 10- 1(7)= 3.
3 divides into 7 twice, with remainder 1: 7- 2(3)= 1.
Replace that "3" with "10- 7" from the previous equation: 7- 2(10- 7)= 3(7)- 2(10)= 1.
So one solution to 7x- 10n= 1 is x= 3, n= 2 which tells us that 3(7)= 1 (mod 10) and that 7-1= 3 (mod 10).
Thanks, my lecturer just showed us this method today.
