Module Over a Division Ring - Blyth Theorem 1.1, Part 4
11 replies · 3K views
Math Amateur
MHB
I am reading T. S. Blyth's book "Module Theory: An Approach to Linear Algebra" ... ... and am currently focussed on Chapter 1: Modules, Vector Spaces and Algebras ... ...
I need help with an aspect of Theorem 1.1 part 4 ...
Theorem 1.1 in Blyth reads as follows:
In the above text, in part 4 of the Theorem we read:" ... ... when ##R## is a division ring
(4) ##\lambda x = 0_M## implies ##\lambda = 0_R## or ##x = 0_M## ... ... "Blyth proves that if ##R## is a division ring and ##\lambda x = 0_M## with ##\lambda \neq 0_R## then we have that ##x = 0_M## ... ...But ... ... Blyth does not show that if ##R## is a division ring and ##\lambda x = 0_M## with ##x \neq 0_M## then we have that ##\lambda = 0_R## ... ...Can someone please help me to prove this ...
Peter
micromass said:
Contrapositive.
Sorry Micromass ... I do not follow you ...
Can you explain what you mean more explicitly ... ?
My apologies for not following you ...
Peter
Math Amateur said:
Hi Micromass ... I understand the meaning of "contrapositive" ... but fail to see exactly how it applies to the problem that I posed ...
Can you be more explicit in what you mean regarding the specific problem ...
Peter
Come on, think a bit about it. You answered merely 6 minutes after me. I'm not here to spoonfeed you the answer.
Proof of (4).
Case 1: ##\lambda = 0_R## ##\checkmark## by (2)
Case 2: ##\lambda \neq 0_R## - see Blyth's proof
fresh_42 said:
Proof of (4).
Well ... thanks fresh_42 ... that is an easy resolution to the issue ...
BUT ... still reflecting and wondering about Case 1 ...
... indeed ... does ##( 0_R x = 0_M )## ...
... imply (or mean) that ...
##( \lambda x = 0_M \text{ and } x \neq 0_M \Longrightarrow \lambda 0_R )##
is true ...But why exactly ... ?(Not quite sure why this logic bothers me ...)
Peter
Thanks for th
Peter
micromass said:
Contrapositive.
micromass said:
Contrapositive.
Thanks for the hint, micromass ...
in (4) Blyth has shown the following:
##( \lambda x = 0_M \text{ and } \lambda \neq 0_R ) \longrightarrow (x = 0_M)## ... ... ... (1)
So ... contrapositive of (1) is as follows:
##\neg ( x = 0_M) \longrightarrow \neg ( \lambda x = 0_M \text{ and } \lambda \neq 0_R )##
But ... how do I progress from here ...
Can someone help further ...?
Peter
We have ##\lambda x = 0_M## as a fact.
(2) is needed to show that ##\lambda = 0_R## is a solution at all.
Since there are only the two possibilities for ##\lambda## - either being zero or not - and the first solves the condition according to (2), it is sufficient to consider the other case, ##\lambda \neq 0_R##.
You may write the whole thing as:
##[\lambda x = 0_M] ##
##= \; (\lambda x = 0_M) \, ∧ \, \text{ (true) }##
##= \; (\lambda x = 0_M) \, ∧ \, [(\lambda = 0_R)\, ∨ \, (\lambda \neq 0_R)]##
##= \; [(\lambda x = 0_M) \, ∧ \, (\lambda = 0_R)] \, ∨ \, [(\lambda x = 0_M) \, ∧ \, (\lambda \neq 0_R)]##
→ (now I use (2), i.e. if ##\lambda = 0_R## is true then ##\lambda x = 0_M## is also true)
##= \; (\lambda = 0_R)\, ∨ \, [(\lambda x = 0_M) \, ∧ \, (\lambda \neq 0_R)]##
Therefore if ##(\lambda = 0_R) = \text{ (true) }## we are done and we may ask when ##[(\lambda x = 0_M) \, ∧ \, (\lambda \neq 0_R)]## will be true without ##(\lambda = 0_R)## being true, i.e. ##(\lambda \neq 0_R)##. Now Blyth has shown
$$[(\lambda x = 0_M) = \text{ (true) }] \,⇔\, [(\lambda = 0_R)=\text{ (true) }]\, ∨ \, [((\lambda x = 0_M) \, ∧ \, (\lambda \neq 0_R)) \,=\, \text{ (true) }]\, \overset{Blyth}⇒\, [(\lambda = 0_R)=\text{ (true) }]\, ∨ \, \; [(x=0_M) \,=\, \text{ (true) }]$$
Thanks for that fresh_42 ... most helpful ...
Much appreciate your assistance ...
Peter
