Moment of Inertia with Variable Density Function
2 replies · 12K views · last reply
Piamedes
There are two parts to question, the first asks for you to find the moment of inertia I for a thin disk of uniform density, a relatively trivial problem.
My problem centers around that second part, "Repeat the case where the density increases linearly with r, starting at 0 at the center, but the object has the same mass as the original disk."
[tex]I = \int_{object} \rho (r,\theta) r^3 dr d\theta[/tex]
Assuming that the density function is p=kr, where k is some constant I'll work out later, then the moment of inertia would be:
[tex]I = \int_{0}^{2 \pi} \int_{0}^{R} k r^4 dr d\theta[/tex]
[tex]I = k \int_{0}^{2 \pi} d\theta \int_{0}^{R} r^4 dr[/tex]
[tex]I = 2 \pi \frac{r^{5}}{5} ]_{0}^{R}[/tex]
[tex]I = \frac{2k\pi R^{5}}{5}[/tex]
With this in mind I now would need to find k. I know that it must have units of kg/m^3 in order to make the moment of inertia have the proper units. My guess on how to do this is to integrate to find the total mass, which I know to be M, solve for k in terms of M and than back substitute:
[tex]M = \int dm[/tex]
[tex]M = \int \rho dA[/tex]
[tex]M = \int_{0}^{2 \pi} \int_{0}^{R} kr * rdrd\theta[/tex]
[tex]M = k \int_{0}^{2 \pi} d\theta \int_{0}^{R} r^2 dr[/tex]
[tex]M = 2\pi k \frac{r^3}{3} ]_{0}^{R}[/tex]
[tex]M = \frac{2k\pi R^3}{3}[/tex]
Solving for K:
[tex]k = \frac{3M}{2\pi R^{3}}[/tex]
Now plugging that back into the equation for I,
[tex]I = \frac{2\pi R^{5}}{5} k[/tex]
[tex]I = \frac{2\pi R^{5}}{5} \frac{3M}{2\pi R^{3}}[/tex]
[tex]I = \frac{3MR^{2}}{5}[/tex]
Is this the proper way to solve a moment of inertia problem of variable density?
Thanks for any and all help.
