Motion in 1D-Graphs: Is Option D Correct?
18 replies · 2K views
SpectraPhy09
All the graphs below are intended to represent the same motion. One of them does it incorrectly. Pick it up (Please see the attached Image)
v=dx/dt
a=dv/dt
I think Option C should be correct
since the body has two velocities in the same position which is not possible. They even didn't show an arrow that could tell it has which velocity at its starting point and at the ending point
But the given and in my textbook is Option d ( It can have an error also).
Plz, can you also give your opinion? Which option do you think is correct also please give a reason.
If you have a pendulum clock, can the velocity at the bottom of the arc be different for the forward stroke compared to the return?
No, it should be the same, but in opp direction. Is that correct?
Oh! so that graph in which the Velocity is different at the same position is correct. I actually thought that it can't have different velocities at the same position at the same instance but it can happen at two different instances.
But how is the option d correct then? Cant we draw a distance Vs Time graph like that? Also, distance is not decreasing with time so it should have been the correct graph.
Two exercises:
1) Sketch the four corresponding graphs for a ball thrown initially vertically upwards and then falling back to its start point.
2) If graph a) is correct, what should graph d) (the distance-time graph) look like?
I think graph a is correct because
So distance would be just flipping the graph from That point where the derivative becomes zero to the point where it intersect X-axis
It would look something like this
Also by first equation of motion Graph of V vs t would be similar to that in the option and Graph of V vs position would also be similar to that in the option
Now i think all graphs given in the ans are correct . None of the option is correct.
Is it so?
Is it so?
I agree with your graphs (for the case of a ball thrown upwards). But note that your distance-time graph does not look like graph (d) in the question.
For example your distance-time graph, at the instant height is maximum, has a gradient of zero. This is not true for graph (d) in the original question. (And note the gradients of these graphs have special meanings.)
That is correct. And since velocity is a vector, that means that you have one position where the velocity has two values.
Yes, I got the answer now(it should be d)
Thanks for Help 😊
Thanks for Help 😊
Can you explain why d is wrong? I don’t get it.
Also how the graph c describes the pendulum motion? At t=0 velocity will be zero then it will increase and again zero and then it will change its direction
Compare the first half with the first half of graph a. How should those two compare?
Not according to the velocity/time graph b.
I guess the position doesn’t change as soon as time starts
graph b says velocity decreases becomes zero and then again increases in reverse direction.
Whereas graph c says there are two velocities at an instant.
What kind of motion does all this?
Do these graphs describe pendulum?
You can make a much stronger statement about how the first halves of those two graphs should compare. One is displacement, in one direction, while the other is distance. For 1D motion, what is the difference between displacement and distance travelled?
Graph c is velocity against position, not against time.
For motion in one direction s=d whereas for other directions s<d
Ok as soon as time starts s is not zero whereas d=0
One dimension, not one direction. Think about that difference.
No, both start at zero here.
No I meant motion in 1D in one direction s=d whereas in other case s<d.
I mean for some time d is not increasing as displacement is. It is flat whereas s is rising after t=0
@rudransh verma - this exercise should help if you work through it:
Sketch these 4 graphs:
position vs. time​
velocity vs. time​
velocity vs. position​
distance traveled vs. time​
for both of the following cases:
1) a ball thrown vertically upwards at t=0 and then falls back to its start point; ignore air resistance; take ‘position’ to be the height above the start point;
2) one full cycle of a pendulum, released from rest from at its maximum negative placement, at t=0; take ‘position’ to be the x-coordinate with x=0 as the centre of oscillation;
If you post your 8 sketches, we might be able to help you clear up any misunderstandings (or confirm you have the correct understanding).
Edit - minor typo's corrected.
position vs. timevelocity vs. timevelocity vs. positiondistance traveled vs. time
1. Ball
2. Pendulum
I don’t know about the motion of a pendulum. Excuse me for wrong graphs
1. Ball
2. Pendulum
For the ball, your first 3 graphs look good. But you have drawn your distance-time graph as a straight line. Are you sure?
Is the distance-time graph related to the position-time graph?
What does the gradient of a velocity-time graph tell you?
What does the gradient of a distance-time graph tell you?
For the pendulum, you have only drawn graphs for half a cycle and (apart from velocity-position) the graphs are wrong. If you are interested in finding out why, it would probably be best if you started a separate thread as we have drifted away from the original topic.
An interesting exercise would be to make a simple pendulum, watch it carefully, and see if you can get the shape of the graphs directly from your observations.
Go from A to B in a straight line; s=d so far. Now go back to A. That's all 1D, but what about s and d now? Maybe try graphing those for constant speed.
That is certainly a difference between the two graphs shown, but should they differ in that way?
