Motion of a Particle: Solutions & Examples
The discussion focuses on understanding the trajectory of a particle given its acceleration in a specific format. The user is exploring the condition where a constant vector 'a' satisfies the equation a•r=constant, which would imply conical motion. However, there is skepticism regarding the validity of this conclusion, as the proposed equation suggests spherical symmetry rather than a defined cone orientation. The conversation highlights the need for further examples or resources to clarify the relationship between acceleration and trajectory in this context. Ultimately, the inquiry emphasizes the complexity of deriving motion patterns from acceleration data.
Einstenio
Show that a point with acceleration given by:
a=c*((dr/dt)×r)/|r|3
where c is a constant, moves on the surface of a cone.
v=dr/dt
This is jut an example to illustrate my doubt. I don't know how to obtain the tracjectory given only the acceleration in this format. I realized that if i can show that there is an constat vector 'a' that satisfy a•r=constant, than the motion would be on the surface of a cone. So i tried to make use of some vectorial identity multiplying by cross product on both sides and try to use the 'BAC-CAB' rule, but that didnt lead to anywhere.
Is there any example similar to this case or anywhere i can study to have a better understanding?
Seems to me that would be motion in a plane normal to ##\vec a##.
##\ddot{\vec r}=c\frac{\dot{\vec r}\times\vec r}{|r|^3}##?
Seems most unlikely that would give a cone. A cone's axis has an orientation in space, whereas that equation appears to have spherical symmetry.
  • · Replies 62 ·
11K
30K
